shoepatcher
Everything posted by shoepatcher
  1. Schmetz to my knowledge moved their production from Germany to India. GB were producing needles in Vietnam as was Organ. glenn
  2. Spray needle with silicon spray. Will make the adhesive not stick to the needle. glenn
  3. Not sure what the 305 subclass. C class, M is for leather safety clutch, P is for 4 motion drop feed, N normally means 6mm stitch length. but this has a -05 on it. glenn
  4. Kwok Hing in China makes a few feet for it. Not sure if they make anything else. Only other source is Durkopp Adler. glenn
  5. Great. That part not easy to find!!! glenn
  6. Try on thing. Loosen the thumb screw in front a that lock the machine foot from rotating. Sometimes they are screw up a little to far for the foot to rotate. glenn
  7. What do you want to use for binding? That is the question. All of the mentioned items above can be made into binding. glenn
  8. No Steve at Cobra is in Northern California. Bob at Cowboy is in Toledo Sewing in Toledo, OH and Neel at Neel's Saddlery, the Cowboy dealer is also in Ohio.
  9. The rust on the stand should be wire wheeled or sandblasted. You also should try Evapo Rust. Great stuff. If it was me and I rebuild these machines, I would disassemble the stand, de-rust it, get an automotive paint mixed to duplicate the color, paint it and re-assemble it. Looks great and increases the value of the whole machine. It needs a drawer and i have the plans to make one as well as a couple on the Adler stands I have, glenn
  10. Some parts will fit from one machine to other. Parts from the 335, 345, 545, 1245, 595 and 1295 are interchangeable. What parts are you looking to see will work from one machine to another. I can tell you the feet are interchangeable. glenn
  11. Contact Eli Schlabach in Aurthr Illinois. He works on them, rebuilds them and manufacturers parts for them. I think his company is Landis? Some jump in here and help me. glenn
  12. I agree Bob. Put the oil to her and let it sit. The penetrating oil will loosen up any old oil, grease, dirt. etc. glenn
  13. Constabulary, Those covers will not fit a Pfaff 345. Also, 335 Pfaff cover will not fit 345. Pfaff 335 has the bobbin on the end of the arm, glenn
  14. That is the wrong needle set screw in the machine! glenn
  15. Constabulary, Those covers will not fit a Pfaff 345. Sorry. glenn
  16. A Consew 229 is a copy of a Singer 168. The bobbin caps should be interchangeable. In the picture shown, your bobbin case tab is not in the slot on the underside of the throat plate. Yours will need the bobbin case cover. Should thread the same as a Singer 168. Hope that helps. I may have a bobbin case cover around here. glenn
  17. nice old machine!!!! glenn
  18. You are missing the slide cover. Pfaff quite making the 345 some years ago. there is a possibility that a slide plate from an Adler 269 might fit. Contact Strima in Poland. They have a web site and they carry parts for old Pfaff's. glenn
  19. buy it and get a hold of Eli Slibach in Arthur, Illinois. He is at Landis Sales i believe glenn
  20. make sure your needle system is system 81 NOT 81 x 1. glenn
  21. The price is what would determine my answer. What is he or she asking? I would consider it if price is cheap. Just my opinion. Definitely a German made shoe patcher. glenn
  22. Go onto Kwok Hing web site. They have Ffaff clone parts glenn
  23. Get someone to help you with putting machine on base> Trust me!!! glenn
  24. Needle to me looks a little off line with awl in photo. Call Eli and talk to him. glenn
