Everything posted by rodneywt1180b
A Collaboration on a Cane
rodneywt1180b replied to rodneywt1180b's topic in Leatherwork Conversation
I actually finished this Monday. Then I got sick with a fever and nasty headache and haven't really had the energy to do anything until today. I'm doing better. I finished sewing it, wrapped a piece of painter' tape around it to get a somewhat straight line and trimmed the bottom. A few learned lessons. There's a bit of bagginess between the wood and leather. Contact cement would help immensely with that. Wet leather is extremely fragile. Just look at it wrong and you'll leave a dent where you don't want it. Next piece I'll trim closer to the finished size and shape, pad it with foam and wrap elastic around it to form the leather. I'm hoping the foam will equalize the pressure of the elastic enough that it doesn't dent. The clamps didn't work great. Oh yeah, I'll also make sure I trim my nails. YinTx and I need to figure out what to do with the area where the two pieces meet. Right now it's wide open. Maybe butt them up and call it good, maybe sew them, maybe something else. Skiving the bottom edge may not be necessary. On this piece I didn't skive the bottom edge. In the future one solution (untried) might be to stop a few stitches and holes short, trim to length then take it off, skive and burnish or whatever edge treatment is appropriate, then put it on for real. That would allow the stitch lines to stay even. The walnut is still soaking up oil like a sponge. I've lost track of how many coats it's taken so far.- 41 replies
- cane
- walking stick
(and 2 more)
I use a pair of pliers to pull the needle and knot through. It should go easy after that. Are you using waxed thread?
I don't think they would hand sew it. Takes too long and long straight runs are what machines do best. Here's my thoughts. I think Stetson912 is on the right track. Machine stitch the panel flat with the folded edges at the seam. It would be easy to leave long tails at the hole location to tie the ends off after the hole is cut. The hole wasn't pre-punched because the shape needing to be cut isn't a perfect half circle. It's possible it wasn't cost effective to make a die the correct shape. It's also a detail that no one but a leather worker would notice or really care about (sacrilege, I know). Cutting after the fact also ensures good alignment. That explains what we can see. I think the leather was stitched and glued on by hand using something along the lines of a quick and dirty ladder stitch . It wouldn't show with the edges butted up against each other so it doesn't need to be pretty, it doesn't even need to be all that strong (more sacrilege). It may be a high wear location but it's not a high stress location. The glue is doing most of the work. The stitching is just keeping the edges from separating. There's also a tiny bit of white showing at the top where the edges meet. I think it's more than where they tied it off. I think there's a third line of stitches there.
Cool! That's an awesome looking Betta. I can see why she loves it.
Upholstered Motorcycle Seat
rodneywt1180b replied to Handstitched's topic in Motorcycles and Biker Gear
Separated by a common language... The seat looks great! -
Beautiful work Mike!
I haven't tried that type of stitch on my canes. Looks like it might be worth experimenting with. I like the look. If you don't glue the area under the stitching down you will have enough room to work your needles.
I was getting an error earlier for too much data/file size on my pictures earlier so I'm trying again. I forgot to mention in my last post that the cane I'm using is just a straight grained maple handle and alder shank that I put together so I could practice my leather work before tackling the real thing on YinTx's cane. I figured it's better to make my mistakes where it doesn't matter. I'm cutting and sewing this one dry. I'm also punching my holes with a round awl not much bigger than my needles. I have to use pliers to pull the needle and thread through the leather. In the above picture I've pretty well got the front trimmed and ready to sew. The tape is just helping to hold things for the picture. I've got the front sewn. Since I don't know exactly how the back is going to line up yet I'm leaving the bottom untrimmed for now. My stitches are about 1/4" apart and about 3/16" away from the seam (eyeballed, not actually measured). I'm starting to sew the back portion now. This is where I've stopped for the night. I didn't glue this leather down and I'm starting to get a little bit of slack where I stopped. There's a small bobble in my cut line right in the corner too. As I work the slack out I'm hoping I can trim more of it away. The leather, even after molding it, is not wanting to get tight against the wood in that inside corner under the handle. I may end up rethinking things a bit to get it tight. Glue would help but I don't want to glue this one down.- 41 replies
- cane
- walking stick
(and 2 more)
The walnut handle is beginning to develop a sort of blotchy shine in places. I'm hoping it will be ready in a couple of days. The maple and oak handles are pretty much done. I started wet forming some 7oz Tandy veg tan several days ago and finally got up enough nerve to start sewing it on. That's how it looked when YinTx saw it last. Out of the clamps. It's not a great fit at this point, particularly at the bottom where I couldn't clamp it close enough to form around the shank. It is at least more disposed to taking the shape of the handle though. Here I've skived the back edge to about 1/2 it's thickness and am starting to shape the front. The front edge is skived. When wrapping leather around compound curves like the front of the cane your cut lines are anything but straight. Continued.- 41 replies
- cane
- walking stick
(and 2 more)
All very true ComputerDoctor but what's the fun in that? There are people out there who will pay for custom items. You may have to look a bit harder to find them, but they are there. YinTx I went back and looked at your table. I didn't see any business cards or portfolios of past work. Those two things can result in sales after the show.
That's good about no rush because the walnut is still soaking up the oil like a sponge.- 41 replies
- cane
- walking stick
(and 2 more)
Suggest a first project for a beginner
rodneywt1180b replied to BorisBaddenov's topic in Member Gallery
Welcome aboard Boris. Maybe not a special trip but if you find yourself in an area with a Tandy store it's well worth setting aside an hour or two to check it out. Being able to see and feel the differences in different types of leather is a huge plus. For me ordering online without having handled a lot of different types of leather was a crapshoot. I'm slowly learning what works and what doesn't for my needs. From my personal experience I would say start with smaller projects first. It's less frustrating to screw up plus closer to instant gratification when things go right. Don't be afraid to experiment and make mistakes. Learning what doesn't work is important too. Spend a lot of time reading here. There are a lot of very talented leather workers here. Ask questions. Someone here will be able to at least point you in the right direction. -
The leather squashed up more at the ends. On the end farthest from the shank I think it was because I put too much tension on the thread. At the end closest to the shank I think it was a combination of the leather being thinner, wet and my not trimming it correctly (I thought it was until I got to the end) to fit before I punched the holes. I ended up trimming the leather and re-punching the last 3 or 4 holes on one side because it didn't fit tightly enough. It was a good learning experience so not a total waste. I should be able to avoid at least a few of the mistakes I made on the next one. I'm inclined to set this one aside and replace the leather at some point. The original leather will make a good pattern anyway.- 41 replies
- cane
- walking stick
(and 2 more)
What's it been? A few weeks, a month, or even longer since I posted my last cane with a leather handle? Anyway, at that time YinTx mentioned commissioning one for his dad and after talking back and forth we decided I would do the wood and he would do the leather. So the collaboration began. Things have been moving slowly along since then. YinTx sent me a goody bag full of veg tan of different weights and brands along with a couple of tooled pieces to practice with and we decided on a shank and a handle style for the cane. This wasn't all the choices but the picture does show the one he chose. The left hand stick is a nice rustic black walnut sucker with a very small and even taper at the top and some nice knots in the bottom for a bit of character. We're still working on the final wood choices for the handle but it will be a Fritz style similar in shape to this one. Right now the hold up is on my end. I have three handles I'm currently finishing but with the weather getting colder it's taking forever to build up a good shine. YinTx can't do a whole lot on his end until that part is done so he knows how big his tooling area is. We're almost literally sitting around watching paint dry. While I've been waiting on that I've started practicing wet forming with the pieces of veg tan YinTx sent me, mostly trying to figure out what works for this application and what doesn't. At this point it's mostly what doesn't work. Here's my first completed wet formed handle. The cane is a one piece cane made from a dead oak branch. I decided this was a good practice piece because of the nearly round handle. Honestly I think it could have been done without wet forming. The leather is Tandy 9 oz. veg tan. I chose the thicker leather because the branch making the grip was a little small so it needed something thick. I skived the front and back edges down to get rid of the pig in a blanket effect and stitched the leather on wet with 1.4 mm Tiger thread. After I thought I had things trimmed to fit I tried pressing a decorative line about 1/8" from the front and back edges and next to the stitch line. The more I look at my stitching the less I like it. I have to get over the idea of using the stitching chisel I have as anything more than a spacing device for my stitch holes. A round awl is much better for this kind of work. Stitching the leather while wet was a mistake too. It stretched the already too-big holes and even tore one a bit. I also had to re-work the stitches closest to the shank and messed that up. Lesson learned. That pretty much brings things up to date for now. More later.
- 41 replies
- cane
- walking stick
(and 2 more)
Will the edge of the canvas show? If not, if you have access to a serger, serge it first or even a domestic sewing machine with zigzag stitch a tight zigzag stitch next to the edge will keep it from fraying. Some domestic sewing machines will have other stitch patterns that will work too. A single layer of canvas will add less bulk at the seams. Another thought would be a solid piece of canvas clear to the edges or seams of the bag with the leather sewn onto the canvas. Without a picture or plans of the design I'm sort of guessing. Your edge treatment on the leather depends on the leather. Veg tan leathers will take a burnish, other types, not so much. Edge paint before assembly might be an option too. My experience as a newbie is getting clean folded edges is tricky at best.
You're one of the reasons I love this forum. There are so many people doing so many creative things with leather that I would never have imagined. I love the wood textures on the cabin and I love the piano too.
Welcome aboard. The term for what you want to do is "skive" or "skiving" There are several different ways and tools for skiving leather. This is what I use. I'm still a beginner and have found it simple to use and sufficient for my needs. https://www.springfieldleather.com/Beveler-Safety
What machines are these and any worth getting?
rodneywt1180b replied to myjtp's topic in Leather Sewing Machines
I don't know any models. 3 and 5 look like your best bets for a walking foot machine. I can't see quite well enough to be sure though. Given all the disclaimer that was just about useless.... -
A great looking piece. It looks like it could be a sampler of different designs. Many would make great border treatments.
Thank you Harry. Do they have to be black walnuts or will English work? I don't have access to any black walnut trees near me. I may have been carefully storing a jar full of black yuck the last few weeks for no good reason then. I'll continue with what I have just for educational purposes. I won't be out much but time. Next year I'll get some green ones and try again.
