Fire88
Everything posted by Fire88
  1. Thank You, you’ll see some more got a couple guys requesting some. Thanks
  2. Thank you it was definitely a fun test of my abilities, as i'm still new to tooling.
  3. This was my first commissioned piece
  4. Looks good, where did you get the canvas at?
  5. I could add a holder for those but it’s generally frowned upon to mix the two. Thank you, it just came to me as I was assembling the first one that I now needed to make another belt and not everyone would want to do that.
  6. Yes rivets each end and sewn with 138 thread, I’ll try 207 ok the next one that’s in the works
  7. Thank You Thank you It’s 5/6oz Herman Oak
  8. Worked out a pattern for 12ga shotshell pouch, made a second back piece that snaps over the belt your wearing. No tooling in these as I was building to check the patterns and for samples.
  9. Beautiful bag and will definitely garner attention
  10. Beautiful slings
  11. Try it on some scrap first but yes it shouldnt be a problem.
  12. How’d it come out?
  13. I got some 5/6 laying around and it seemed too light, I’ll make another just cause before this one ever falls apart. The outside dye is chocolate a couple coats cause I dilute it, basketweave is one light coat of diluted chocolate with dark brown antique, bag-kote as the resist and final finish. Than You Sir
  14. Went from seeing a picture through 3patterns 1 prototype to this. Made from 8/9oz leather sewn with 207 white thread which I thick makes it pop.
  15. No got a little over zealous with the edge dye, and it’s only a light coat of walnut dye on the main leather.
  16. Thank you and absolutely easiest way to show others. I have corner chisels I got from Springfield leather 10,20,30mm or something like that. I cut almost everything square and then use them to nip the corners before sewing. Thanks, there are mistakes in the square stamp somewhere but I fixed most of them with a modeling tool. That square stamp is easy to screw up.
  17. Welcome, I pulled the one off my helmet since it’s good and traced it on graph paper. This gave me the basic outline and then tweaked it from there. I haven’t made it yet, need to find my pattern or make another one.
