Michiel
Everything posted by Michiel
Yes i did Some werk on it Here you find the service manual (which helped me with everything) https://www.duerkopp-adler.com/commons/download/download-text-attachments/Vintage_Manuals_Adler/Serviceanleitung_169_DE.pdf It is in german, there is also an english version on that site but that is from the singer 169 which is the same as de Adler 69 (yes that is strange) regards, michiel
- 23 replies
Hi georgi, As far as i know There are a lot of Adler 69 around and there are a lot of aftermarket parts avalible. the Adler 169 on the otter hand is rare and it hard to fine parts i have both machines but only use the 69 for binding. I would like to know Adler 269 binding kits fit Regards, Michiel
- 23 replies
Are the inner and Outer foot both rising not high enough? or is one doing it beter than the other ? btw: my interpretation of “ footlift “in the specifications is the Max distance between the machine bed and feet and not the movement of the feet While sewing (but That is how i read it) my adlers in that class have an footlift about 7 mm but i think the movement of the foot is also more like ca 4 mm regards Michiel
In the picture its aan rollerfoot nut its the same procedure for an walking foot and the Gauche van be a piece of wood or something else with the right size Sorry, auto correct om my ipad only does dutch so changes everything
You neef to alter the height of the presserbar from the service manual : Presser bar height adjustment Required adjusting gauge: dimension block 46 (7 mm) partNo.981130005 1. Raise lifter lever 47. Fig. 3. 2. Attach hinged foot. 3. Place dimension block 46 underneath hinged foot on to throat plate. 4. Slacken screw 48. 5. Lower presser bar 49 down to the dimension block 46. 6 . Tighten screw 48.
Yes its a adler 69 but i canot Say What subclass it is with only these Photo’s I can see it has needle transport at least ....(or triple feed but it is hard to see)
Heavy canvas/sailcloth machine advice
Michiel replied to jfhspike's topic in Leather Sewing Machines
The adler 98 is definitely stronger than an berina 217 the feed dogs are much wider and its an stronger machine, verry useful for sails the adler 266 / 166 is for heavy needles and threads (needles 140-230) but like wiz says : for boat covers and other stuf which does not require zig zag an triple feed machine is better (i use an adler 167 for stuf like that) michiel -
Cowboy CB3200 forward and back Stitch misaligned
Michiel replied to palvim's topic in Leather Sewing Machines
If you turn the machine by hand (slow) you can see if the stitch in reverse is longer or constabulary is right (my guess would be you are missing stitches in reverse...) regards michiel -
Hi nick, i have an 98 too and never found a manual..... beware: on the back side there is a cover, if you open it you will find yourself with some loose parts! i just wanted to take a look but it toke me some efford to get everything back in place the right way (and with the timing right) but if its not working properly maybe some did the same and did not succed to get it right again. Kind regards michiel
Adler 167 - Timing Belt Replacement
Michiel replied to Constabulary's topic in Leather Sewing Machines
Every time I need a part for an adler i think about you and your singers constabulary (but i still keep buying adlers) -
ther are no timing marks, but when you put the neelde and hook in the right position for timing the hook you only have to put the belt on its place -
this post was verry helpfull when i had to replace the timingbelt of mij adler 169 when I did it again with an adler 67 I made some photo's of how i got the belt through the gap.... -
The post of an one-needle machine is significant smaller and you can sew closer to the edge (of the post)
If you cannot find an service manual i would try it with an other brand postbed sewing machine the adler 68 looks not verry different to me http://www.duerkopp-adler.com/commons/download/download-text-attachments/Vintage_Manuals_Adler/Manual_Adler_68.pdf if that doesnot work you could use the partsmanual for your machine and for the adler to find out how it is for your machine it might be a puzzle but if you print them all and do some close reading you can do it (for me this method works) http://www.duerkopp-adler.com/commons/download/download-text-attachments/Vintage_Parts_Books_Adler/68.pdf
Best walking foot sewing machine for thread size 138
Michiel replied to siddiqui2008's topic in Leather Sewing Machines
I made a case which fit an industrial sewing machine head the same way they are used for domestic sewing machines (just a litle bit bigger most of my adlers fit in it... -
My adler 69-373 likes thread 20 (which should be about 135 i believe) bottum adn upper thread. But its seems a machine with a lot of "historie" / pre owners so maybe someone tinkered a litle bit with it
Did you read this thread?
Adler 69-72/E 42 Needles - Help please!
Michiel replied to TomSchell's topic in Leather Sewing Machines
Adler 69 should use system 134 but sometimes they are changed to system 134-35 (both are used on adler 67 ,167 69 etc) they differ in length so if you want sure to order the right ones: messure the needle wich came with the machine and compare it to the specs of system 134 if you google you will find the length regards michiel system 134: -
Can Anyone Recommend a Small Roller Foot Post-Bed Machine?
Michiel replied to pgb123's topic in Leather Sewing Machines
I have an old adler 68 which is a nice machine i have used to repair some shoes. (made it portable so i van use it at home) but they may be hard to find
