Hildebrand
Everything posted by Hildebrand
  1. I have gotten 2 sides of Herman Oak from them, both were "branded" sides, I think grade A/B. I have been pleased with both, they are large sides(sold by the side not square foot) and other than the brand the leather has been very good at least to my hobbiest eyes. Todd
  2. I have had good luck with Montana Leather in Billings, MT. Get on their email list, they have specials frequently on different types of leather. Todd
  3. Very nice holster, as others said very clean. Hopefully the other shop doesn't completely ruin the look. Todd
  4. I use the double sided tape with zippers to hold them in place, when I use it I run a strip full length of the piece. If I were doing 1/2" strips I would be tempted to run 2 strips, one down each side just inside where I planned to sew. Todd
  5. I have only done one so far but I used the double gusset method shown in the YouTube video by Makers Leather and Don Gonzales, it is fairly simple once you watch them do it a couple of times and it worked well. Todd
  6. I would really look a the 3-d printing angle, I know you can print things in pieces and put them together, that would help with the size issue. Todd
  7. If this is something you are looking at as a show piece for your work replace it. Todd
  8. I have gone to just using a groover that puts an indent in the leather, doesn't scratch or cut the top layer. I found this works better oops situations and if I groove after I die there is not a white streak to possibly show under the stitches. Todd
  9. I have pretty much quit stitching backward. To backstitch when I start, I turn the piece around so I am sewing forward toward the starting point, I usually try to mark about 3 stitches out, then when I get to the starting point I turn the work around and still sewing forward go back over the 3 starting stitches and sew it the rest of the way, when I get to the end I again turn the piece around and backstitch 3 stitches sewing forward along the stitch line. Todd
  10. Good start, it looks like your leather was a little to dry when you were tooling, there are several good posts on here about casing leather for tooling. Keep practicing and in a month look back at this one and compare it to what you are doing then. Todd
  11. Just beautiful, very nice work. Todd
  12. Thank you both for the kind words, the scabbard is for a Thompson Center Encore. Todd
  13. I usually carry a knife and leather man combination when I am working outside or camping/hunting/etc. I have 2 sets one stays on the work pants the other moves depending on what I am doing. Both needed new leather so I took the leather man pattern from the Leather Crafters Journal and modified it to hold both. The scabbard is to carry a single shot pistol in a backpack, you could also carry it on a saddle but I don't have any stock so backpack only. The zipper keeps it pretty weather tight. It is based on the scabbard build in The Art of Making Leather Cases. Todd
  14. This topic comes up frequently where to buy the metal portion of the clip to hold the tape measure. I made a holder recently, this one has a pencil pouch also, and decided to try just getting a conduit clip with 2 holes in it and bending it into the right shape. It worked great, they are cheap and easy to bend with just 2 pairs of pliers, I was ready to put it in the vice but they are really pretty soft metal. Todd
  15. I usually sand by hand unless it is a multi layer knife sheath, holster or scabbard. If the edge is pretty square I use 200 then 600, if it needs a little squaring then I start with 150, and that usually gets me a nice smooth slick edge. I use water and saddle soap for the slicking part. Todd
  16. I generally put a coat of NFO on and let it set 24 hours before dying. I finish with Resolene diluted 1:1 with water and have never had a problem. I use a wool pad for the NFO just putting enough of a coat on to see the color change, I am not soaking it with the NFO I think you can over do it and make your leather too soft. Todd
  17. @kgg hit it on the head on all points, nice assessment Kgg. Todd
  18. I use that same method, I keep some scrap around and make a piece the same thickness I am going to sew then sew a line of stitches on it. Does two things, makes sure everything is running right and it gives me a way to measure 3 stitches. I use my wing dividers set them in the holes and make a mark 3 stitches in on the project and start there and sew back to the start point then forward over the 3 stitches and on down the project. Todd
  19. Looks like a good start, 2 things I would look at when you make your next one is grip clearance, looks like it might be difficult to grab the grip of the gun, second is make sure you don't cover the magazine release. Todd
  20. I can’t help on the thread issue but, yes you have to back stitch to lock the stitches.
  21. I like the discussion @bruce johnson I will throw out there, slicking or burnishing really only matters to us leather workers. Most customers don't even notice the bright shiny, glass smooth edge on a piece unless you point it out and then they usually just glance at it and say, that's nice. Todd
  22. I use water and saddle soap, Don Gonzales has a great YouTube video showing how to do it. I tried all kinds of things before I started doing it this way and this is the best I have found. Still takes good square cutting and some sanding but makes edges you can be proud of. Todd
  23. Saw the beautiful work by @Stetson912and decided to give the pattern a try, I am not a floral carver so I went with a basket stamp. I really like the pattern it is a great fit for the weatherman tools. Todd
  24. One issue I have had with the Aquillim 315 is it is difficult to get good smooth edges. It's like it leaves a rubber cement type of substance on the edge when you are trying to sand it. I have not been able to get rid of it. Which is too bad because and odorless contact cement would be awesome especially in the winter since I have to go out to the shop to use the regular stuff due to the fumes. Todd
