kgg
Contributing Member
Everything posted by kgg
  1. The more coils the servo motor has the better the the low end torque range and lower startup speed. A lot of the six / nine coil servo motors have a higher startup speed. A speed reducer between the servo motor and the sewing machine will help to smooth out the startup speed on the six to nine servo coil motors. The Sailrite Workhorse at $225 USD or $321 CAD plus you can count on at least another $150 for taxes / brokerage / shipping is the same as the Reliable 6000 at $259 CAD plus 13 percent tax and whatever the shipping cost within Canada. Are you planning on putting the servo motor on a $100 Chinese Patcher or the Singer 29K Patcher clone machine? kgg
  2. I would be interested in knowing what the Techsew 2750 Pro goes for at auction. kgg
  3. Since I'm in Ontario, Canada I went with KOBE which was considerably cheaper then what a Cobra, Cowboy or even a Techsew would have cost.
  4. Sounds like the lady is emotionally attached, which is understandable, but I think she is being unrealistic as you can get a new one for $2900 USD plus shipping. At auction I think she would be lucky to get 50 to 70 percent of a new one, $1500 to $2100 (pristine condition). As a note I am selling my 2750 Pro in pristine condition and less then 3 years old for $2800 CAD ( $1940 USD) which is about 63 percent the cost of a new one. kgg
  5. You got to be very careful these days and go with your gut. Sad thing is if it is a scam which I highly suspect it is how many people are going to get suckered? kgg
  6. This may give you some idea as to what they would cost new and from there you could decide what they would be worth to you. The embosser is from Ivan Leathercraft out of Taiwan and can be bought new on sale for $405 USD (https://www.ivan.tw/products/final-sale-professional-leather-strap-embossing-machine-1 ). A similar splitter to the one in the photo can also be bought Ivan Leathercraft for $350 USD ( https://www.ivan.tw/collections/machines/products/deluxe-leather-splitter ) What are they asking for the embosser and splitter??? kgg
  7. Here is a link to a good chart that cross references needle size to thread size ( https://www.tolindsewmach.com/thread-chart.html ). I have owned a Reliable Barracuda, Kobe LSZ-1 and the Sailrite® Ultrafeed® LSZ Sailright with the their "new servo motor". The main difference would be maybe in build quality as the price varies from $500 to about $2500 CAD. These portable walking foot machines are in my opinion: i) not meant for leather work as they were designed to do sail repair work on the ocean. ii) in reality the take up thread arm isn't really meant to work consistently with V138 and you may run into needle to hook clearance problems using V138. iii) has a very small Singer class 15 bobbin. Those can be purchased off places like Amazon, Temu, Aliexpress iv) stitch length is not consistent and will shorten as the thickness of the material under the presser foot increases. v) increasing the lift can be done but there can be major drawbacks and takes about an hour of fiddling around in the head. I was able to increase the factory setting of a Kobe LSZ-1 from 6.35 mm to about 12mm but that little machine did one task, edge binding and was reset before I sold it. vi) the presser foot and feed dog are pretty rough and the original ones will leave impressions in veg tan. You can get after market smooth ones. vii) the holes for mounting edge guides and binding attachments may require the holes in the bed to be threaded as I have see that problem on a number of the Sailrite portable walking foot clones. To get your speed down you can add a Sailrite® WorkerB® Power Pack Motor System for about $300 USD ($450 CAD) but by the time you get it into Canada with the rate of exchange / shipping /taxes you would be looking at about $600 plus CAD. Which would be about two thirds of what you paid for the machine initially. Another option would be to add a custom speed reducer using the existing 90 watt motor and some inexpensive pulleys. kgg
  8. And Happy New Year to everyone. kgg
  9. That's a shame. But aren't knitting needles pointie on one end with some made out of metal (stabbing instrument) and isn't boiling hot water needed for tea (scalding potential). Imagine if you wanted to bring a class 441 machine to class someone could sew their hand to the machine. Damn bleeding hearts. kgg
  10. Very cool machine, definitely made for volume and consistency not as automated as some belt machines. The way I figure it there are two basic levels of handcrafted just depends on the market you are going for: i) Belt blank cut and dyed by hand, sewn by hand, belt ends cut by hand, holes punched by hand and embossed by hand. Should command the highest price for a quality belt as each one of the same style will be slightly unique and the labor / skill involved with making it. ii) Belt blank pre-dyed, cut with a strap cutter, sewn by machine, ends and holes punched with a machine and embossed by machine. Provides consistency and improves efficiency which reduces the cost per belt.The drawback is the cost of equipment. kgg
  11. My thoughts are the Artisan Toro 3200 is a class 441 machine with a chopped down cylinder arm as the original Juki TSC-441 machines have a 16" cylinder arm. When I was looking for a Class 441 clone machine, couldn't justify a true Juki TSC-441, I drove myself nuts looking at the specs of a lot of machines. I finally just went with a standard Juki 16" clone using standard readily available parts that can be had from a lot of suppliers and figured it would be a lot easier to sell down the road. That said if the price was right and it was in great shape it maybe worth a consideration. What are they asking for the machine???? kgg
  12. The 14 oz is just shy of 1/4" and should be no problem. The max size of thread for your machine is V138. As far as whether the smaller bobbin will do your belts and slings is going to depend on their length, what size of thread you are using and your stitch length. A prewound bobbin of V92 will have about 25 yds of thread verses about 12 yds of V138. Probably not going to be able to handle that thickness of leather. Your machine is rated for V138 with a 135 X 16 X #23 or #24 needle depending on how thick / tough the leather is. Even though the #24 needle can take V207 you may have problems with head space clearance when using V207 in the bobbin. kgg
  13. If I am keeping for myself I buy mostly new but occasionally near new machines. Based on my experience if it's a Consew or PFAFF they are going to be hard to resell down the road and you have to almost give them away.
  14. The size 23 /160 needle is only good for V138 max so changing the needle up to #24 or a #25. However this maybe difficult as the 767 is only rated for a 134-35 #22/140 needle as per the spec. which means it is only rated for a take V138 in thin stuff or V92 in thicker /tougher stuff. The reference I used was the Duerkopp Alder manual located on page 8 ( https://partner.duerkopp-adler.com/commons/download/public/767/B_767_EN.pdf ). kgg
  15. For the last six months in Ontario there have been very few used industrial sewing machines for sale and most of what's around looks like they were rode hard and put away wet. The cheapest prices are for the Consew and PFAFF machines as both have always been hard to sell at any price irregardless of condition or age. The ones that sell fast are the older Juki's and Singer's but are commanding a premium prices if in fairly decent shape. Then you have the portable walking foot machines like Sailrites / Sailrite clones and those are the easiest / fastest selling. kgg
  16. The Consew 277RB-1 is about $3000 USD or $4400 CAD plus by the time the main dealer in Ontario adds other cost it probably would top out at around $5500 plus tax so the finial price would be $6200. For that price he could get a brand new Juki. kgg
  17. Sorry to hear about your hospital stay. Wish you and everyone a Merry Christmas and a happy new year. kgg
  18. The Consew T-1919 is just another knockoff portable walking foot sewing machine of the Sailrite LS. You can get either a Reliable Barracuda ( $779 CAD) with zig zag or a KOBE LSZ-1 with zig zag for about $500 CAD. Over the years I have owned the Sailrite, the Barracuda and the KOBE. The last one was a Sailrite LSZ-1 and it had their new "servo" motor and may have been slightly better build quality then the KOBE ???? I would not recommend any of the portable walking machines regardless of price but I can assure you you will not be pleased with either of them as first / only machine for leather. The main drawback is that the machine will have a small "G" bobbin. If the machine is in good condition with a servo motor in Ontario it usually goes for about $600 to $700 CAD. If you have to replace the old style clutch motor with a servo motor to get speed control then add to whatever price you pay an additional $150 -$200 CAD to the price. kgg
  19. Yes machines can be expensive but: i) look at finding a good use cylinder arm machine that will sew the thickness of the material you make the bags out of. ii) look at one of the one armed bandits which range in cost new from $1000 USD ($1430 CAD) up like the Tippman Boss or the Cowboy Outlaw. Don't waste your money on the the Chinese patcher as they are just frustration generators. iii) the time saving would allow you make the same bag in a 1/10th or less of the time it took to hand sew with a lot less strain on the hands. kgg
  20. I have never install one myself so I just watch a video of installing conchos ( https://www.youtube.com/watch?v=NL-eW6DkCEk ). I am going to assume your concho's stem is also threaded so it is just a matter of finding the correct size screw for attachment. I would use a nut / screw thread gauge to determine the size needed. For the most common sizes I find the Chinese nut / screw gauge similar to ( https://www.aliexpress.com/item/1005007315188557.html?spm=a2g0o.productlist.main.21.79e3ZdnIZdnIxM&algo_pvid=1aca4878-402f-4f94-9b21-d996454393f2&algo_exp_id=1aca4878-402f-4f94-9b21-d996454393f2-10&pdp_npi=4%40dis!CAD!23.62!12.99!!!16.13!8.87!%402103244817345326557723276e6b56!12000040228337903!sea!CA!3463193163!X&curPageLogUid=8y7oEuQnLAr1&utparam-url=scene%3Asearch|query_from%3A ) are good enough. If the conchos were made in the US then you will probably be looking at Imperial sizes. If they were made elsewhere chances are you are looking at metric sizes. From the photo it looks like a screw in the 3mil range which is about 1/8" would work.If you don't have a thread gauge take a concho to some hardware store as most have a gauge by the nuts and bolt display. kgg
  21. Nicely done. My only suggestion would be sew a seam about 1/4" in from the edges with V138 thread not so much for adding strength but to help reduce deforming caused by stretching. kgg
  22. Beside what @Northmount has suggested I would move up to a #20 or #21 needle. I think that the thread is being caught by the canvas and there also maybe a very slight build up of wax on the thread which maybe adding to the problem. The canvas maybe being drawn down into the feed dog hole which can cause problems if that is the case you may have to put a piece of regular writing paper on the feed dog side and tear it off after. Even though canvas is a fabric sometimes you may have to go with a leather point needle so I would do a test seam and see if that solves the problem. Also what stitch length on your seam are you trying????? kgg
  23. I do think from what I have seen and heard Sailrite provides good service, good manuals and lots of video's. I just recently sold both a Sailrite LSZ-1 portable walking foot with their new servo motor and a Chinese Clone LSZ-1 portable walking foot with just a 90 watt domestic motor. The Chinese Clone costs about $500 CAD whereas the Sailrite costs about $2500 CAD when you take into account shipping from the USA / duty /exchange rate /etc. The quality of parts appeared to be better but $2000 CAD better??? Based on my own experience if I ever need another portable walking foot for whatever reason I would not bother with another Sailrite. kgg
  24. What system of needle are you using 135 x16x#18 (leather) or 135 x17x#18 (fabric). Should be a 135x16 x18. Have you tried a larger needle size as a #18 is really meant for Tex 70. here is a link to a good chart of needle sizes verses thread size, https://www.tolindsewmach.com/thread-chart.html . Like @DieselTech has said going from one type of leather to another probably will require tension adjustments do to the toughness of the leather. kgg
  25. @dikman it is Spanish and says: You have to turn on the controller with the "P" key, nothing, there you access the programming commands. Then you continue pressing "P" until the letters SL (speed low) appear, then you press P again and 16 appears, there with the button below P you can vary the number up to 03 as slow as possible then you return to Turn off the controller until all indicators turn off. Then turn it on again and check the speed. painteramirezdaniel@gmail.com kgg
