Gezzer
Everything posted by Gezzer
  1. Now that is thinking outside the box !!!! Very cool and stylish idea .
  2. Looks good .
  3. I blew up the drawings and it looks like the handle end has a shoulder down in there that's attached to the end cap you can see . The nut I think is on a collet part of the main sleeve . Good luck with restoring it .
  4. @DwightT and @Wepster good ideas all around !! If the friction fit loosens over time a simple wrap of masking tape on the candle tin would work . I think it will take a small boat load of candles before it is a problem but I may be wrong .
  5. Hey ......... what's that nylon sheath doing on a leatherworkers belt ? Looks good Chuck !!
  6. That is how I got the " speckled " effect on this , but I had to cut out a negative to cover for over spray . I wasn't too picky about nozzle size and just used one from the house and held it a couple of feet away .
  7. Take this with a pound of salt ......... but looking at patent #662,691 , I would think loosening the nut and placing a rod that just goes in the hole on the handle end and tapping that rod would start it apart . Again I do NOT KNOW , might need someone with a little machinist knowledge to look at the drawings . https://patentimages.storage.googleapis.com/08/d5/50/ad30f9cac6db57/US662691.pdf
  8. If I tried to carve that ...................... I'd be so jacked-up I couldn't sleep for days Nicely done !!!!!!!!!!!
  9. No firsthand experience ......... but a quick search brought this up . You ma have already seen it .
  10. If I had a clicker press , I think this might be one to get a die for . I would have never made a carpenter if it were not for Geometry class !!!!!!!!
  11. Well I didn't either
  12. They might at that . Might need leather already cut to speed it up just a little or at the very least patterns if you are talking about the guy doing the 4 hour classes .
  13. @Wepster Thank you ! and I agree the taller one does look better . Go for it , the friction fit isn't that hard and if you do miss the block is a fine idea . As for google not knowing about " ringing " I am not surprised LOL ! It's just something we have always done ( don't even know where I got it ) , it's just a deep depression right around the wick . On a flat top candle they seem to melt all across the top , the depression lets what melts stay more in the center which seems to make a little more flame . Here is a picture of what we do to new candles .
  14. Thanks ! The base did not change , only change was in height .
  15. Wow ! That is nicely done .
  16. @fredk Thank you Sir ! @SUP I agree .Changed from 1 3/4 height to 2 1/2 and it is more pleasing . @MarshalWill You are exactly correct , when I increased my border width that portion turned into a cylinder and as you say, does help the look . @Klara Thank you very much !!!!!! don't know how long they will be a tight fit but I really think it will be quite a long time, I am sure one could make some sort of ledge inside ( silicone or hot glue or something ) when they are made to insure no problems . Let me know how yours turn out please .
  17. O K I had to try another size just to see how they might look in a bunch . Had to wet the top as it was just a little too tight and it spread my top stitch in the back. I won't bore ya'll with any more as you get the idea . Thanks for all the kind words everybody !!!!!!
  18. That looks very good !!! What is it lined with ?
  19. @Frodo that is thinking outside box
  20. Brilliant idea !!!!!!! You know an adjustment to size and invert it , might make a flower pot wrap.................
  21. @chuck123wapati Thanks you and they should be useful for some other things .
  22. Excellent idea about the arrangement !!!! and the airspace
  23. Nice work Chuck and I like the modeled look !! Now don't shoot all of those at one elk Good luck
  24. @Dwight Really nice set up !!!!
  25. I may be wrong but I think dry leather is a poor conductor of heat but always be careful and do your own research and test . And @SUP be sure if you do make some wraps please post some pictures , I love pictures
