Gezzer
Everything posted by Gezzer
  1. Gezzer
    Tallybook
    Nice work !!!
  2. Absolutely !!!!!!!!!!!!!!!!!!!!!!!!!!!!! Nice job .
  3. Very Nice !!! The pivots really make these comfortable . I use 5 oz for the strap and also connect with Chicago screws to let these be pivots as well , just kind of molds to the wearer .
  4. Gezzer
    The Wizard
    That is NICE work on both !!!!!
  5. My theory ............... maybe your support table is not wide enough to support the hide ( assuming both ends are clamped and the middle is not ) # 2....... or maybe your lighting in the center is giving a false " on the mark " I have had that affect a lot of things in carpentry work over the years . Any way good luck figuring it out !!
  6. Gezzer
    Key clips ?
    Well if you do Amazon here are some . https://craftmemore.com/product-2pcs-metal-snap-hook-sling-clip-spring-gate-quick-release-ca-id-119.html
  7. .............
  8. Gezzer
    Key clips ?
    Not sure what they are called in Oz and this is not in Oz but you could order if you don't find any . https://www.aliexpress.us/item/2251832683620568.html?gatewayAdapt=glo2usa4itemAdapt Good luck !
  9. Looking good Frodo . I am using a Craftjapan # P367 which some call a thumbprint and put my pinkie finger on the tip to keep from rolling .
  10. This probably won't help since you already have leaves but I use long pear shader tilted quite a lot on just a swivel cut to make my vines . Like I said probably not much help .
  11. Wow !!!!!!! Both are very nice but the snake skin is awesome !!!
  12. I know this is a few years old but I have got to say THANKS !!!!!!!!! This is just the look I am wanting to achieve .
  13. Thanks @fredk .
  14. Nice work !
  15. Back at the experimenting . I am lookin for old aged look , not quite sure how to get what I want . This is in the neighborhood , just not the right house . suggestions appreciated .
  16. Looks like a fine start and she will love it !!!!!!
  17. That does look good .
  18. Very nice
  19. Nicely done !!!! Pretty good disguise . I assume the notch is for first grip finger ? I am so glad that it's unloaded , wouldn't want to get shot through this screen . LOL !!
  20. Todays iteration working on Chucks idea kind of ( still can't find my Sam Brown buttons ) and without a real hair band . I think this will most likely work with a real hair band except it will just loop over the rivet . If anybody else tries this ...... post it up , I ain't above coping a good idea
  21. I can't wait to see , you always amaze me with your stuff .
  22. I cut 1/4 inch strip from the leather I am going to use and wrap around the thickest part of the object , 2 pen marks , lay out flat and add whatever for stitch lines . Th is will be my total width .
  23. Chuck ............. you Sir are what is known as Mensa material !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks
  24. O K , thick haired lady said that she couldn't quite snap it . Her 16 year old daughter with not quite as coarse hair was able to and it worked well for her. So my take away is it might work for most ladies , also being veg tan you could wet it and stretch it over a broom handle or something . Well you never know until you try ............. so back to the drawing board !
  25. Let me know how it works for you please . I have a woman trying this one out and should hear from her tomorrow but a larger sample size is always better
