BlackDragon
Everything posted by BlackDragon
  1. I would use Neatsfoot oil and either wax or a couple of coats of Resolene 50/50
  2. These are two separate items; a grommet and a brass chain link. The grommets you can find pretty easily. The individual brass links are going to be harder to source. You can buy a brass chandelier chain and take off links as you need them. Make sure you get a good thickness so it doesn't pull apart.
  3. There are no State or Federal exams or licenses here in the US. There are trade schools, apprenticeships, and self taught. I'm one of those self taught but I wouldn't take on jobs that are critical unless I know what I'm doing. I focus on small repairs and if I see something that needs a pros hand I'm not afraid to admit it. There's a couple saddlers in my area. One is an old timer that's been doing it since he was a kid and his father showed him. Another is around 30-40 and he was taught by his father and he was taught by his father. I tell people to go to them for major repairs.
  4. I recently got a saddle into the shop for cleaning, inspection, and repairs along with a breastplate. I let the owner know about any the issues they don't know about. When it came to the breastplate I explained the bottom strap was severly cracked and should be replaced. They asked if I could just patch it and move on. I explaind that if one part of a strip is bad the rest is on it's way out. The cost to replace the whole piece and patching it would wind up being the same but with the patch there's a chance the old leather will fail. They agreed with the repair.
  5. All the sites I find these are Japanese. One name I found them under is pattern clip but I cant find them in the US
  6. You can use a utility knife and make multiple cuts to make straight cut appear curved. Instead of doing 3 or 4 cuts, which makes it look boxy, use 10.
  7. The curb strap attaches to each side of the bit and sits under the mouth to apply leverage when the reins are pulled, amplifying the rider's signal. Yes, thank you. Many years ago I rode Hunt seat over fences and was getting into saddle seat but left the sport because life got in the way.
  8. So is this nose band essentially like what a curb strap does, adding extra pressure around the muzzle instead of chin for better control?
  9. It looks to me like the two circles the leather goes through are grommets that were painted. If you look at the edge of the patch there is a spot where the leather is thicker. I believe that's where the loop leather is anchored, much like you make a purse handle. it's tubular in the center and flat on the ends. It just passes through two grommets. It's a neat concept but I would worry if it can take the weight of the jacket for long. I guess if it's large enough it can be ok.
  10. This is a great setup! Yes a laser cutter did the cutting but YOU told the laser where to put everything, YOU did the stitching, YOU put in the hardware, YOU worked the leather, and most importantly YOU came up with a great design.
  11. Really great work!
  12. @Northmount Great catch! When I worked at Toyota in KY I have to wear that type of belt for that exact reason. The ones we used had two prongs.
  13. Quick note on airbrushing with ANY type of oil. Use a respirator because oils, when atomized, can cause lung issues. When I dye it's oil, dye, buff, finish. I oil with neatsfoot oil and let it sit until the oil is absorbed. How long it sits depends on the thickness of the leather. This allows the dye to spread evenly when applied. I then dye and let it sit for a day so the dye has time to spread evenly. I then buff any excess dye off. I then add my finish, usually Resolene diluted with water 50/50 or a wax.
  14. That's not a work belt, it's a display belt. Beautifully done! When I first started making serious belts I made my brother-in-law a belt, it was one of my gun carry belts, but he wouldn't wear it unless he was going out somewhere nice. I told him to just wear it while he worked because I wanted it to be tested in the field. He has an excavating business so he's literary in the trenches all day. I finally just made him a second one and put some scratches in it so it didn't look as nice. lol
  15. Another tip on searches. Most search engines have tabs under the search field. The first one is usually "All" this is the default tab, the second is usually "Images". Click on that an it'll show you the image search.
  16. You can look up bag stiffeners in google. Here are a couple links that may help. https://www.rmleathersupply.com/collections/lining?utm_source=chatgpt.com https://springfieldleather.com/products/bontex-bag-stiffener?_pos=1&_psq=bag+sti&_ss=e&_v=1.0
  17. The bridle looks beautiful! When it comes to keyboard warriors, there's always someone that says how awful something is and how devastating it'll be if you continue the practice. The sky will always be falling for them. A very wise person once said "Haters gonna hate, hate, hate. So, shake it off, shake it off."
  18. Yes AND you can cuss out your leather all day long without repercussions.
  19. Some people hate AI but for things like this it's pretty awesome. I told ChatGPT5 what I was looking for and attached your image and it came up with a few things. Some were nothing close but a couple hit directly to what you need. The first close match was the entire belt with that buckle out of Germany. https://www.guertel-nach-mass.de/belt-with-matt-silver-coloured-3-part-buckle-set-4cm-wide.html Another was a wholesale company in Spain. You can probably call or email them to see if they have some one in your area to buy from. https://zamakcerdan.com/gb/home/1907-hebilla-senora-pase-40.html
  20. It came out really well. As far as cost you need to consider cost of each material. In your case 400cm for outer materal + 400cm of inner material, + thread, glue, dyes/paint, hardware, etc. You should also consider your overhead costs. What does it cost for rent, power, shipping costs (items you ship and items shipped to you), etc. And you need to consider man hours. What do you need to get paid hourly. So you need; Materials cost + Overhead cost + Time The biggest issue people have is figuring out what their time is worth. What you charge per hour should depend on on your level of ability. A person just starting out can't charge what a person doing this for 20 years could charge. So, If it took you one hour to make this then, with what you charged, your time is worth 9.50 an hour. If it took you 2hrs then you valued your time at 4.75/hr. You also have to figure out what people would be willing to pay for the item. For that same item if you were to charge $40/hr USD and it took 2hr to make, most people wouldn't buy it. You would have to market it to select few that have the money to spend. It's a delicate balance you have to find.
  21. BlackDragon
    New hat.
    Hey that's pretty cool! What materials do you use? Do you have a wire in the brim? what did you do for the lining?
  22. Thanks. I tend to be nick picky with the things I make. I'm always looking to improve, not only what I do but how I do things. The suede I used for the sweatband is too soft and tends get floppy, so when I take the hat off the band turns inside out. next hat I make I may buy the correct sweatband already made.
