DieselTech
Everything posted by DieselTech
  1. You just pull your thread thru your needle eye & leave a 4-5" tail of thread, then you pierce your thread with your needle. Then from there just pierce your thread again, & it will create a "S" on you needle. Then grasp the "S" & pull it over the eye over your needle. Lmao I hope you can understand my jibberish.
  2. If you get a amazon machine, like a shoe patcher or whatever it's called. Is going to take a bunch of hand finishing work to get it up & sew consistently & smoothly. The cheapest options I can think of is. Weaver 303 Cowboy 797 Sailite leatherworker/fabricator.
  3. I dont think this is obtainable at $200.
  4. Looks great! Nice work.
  5. Yeah I wish they made the rocky mountain thread in some larger diameters. I think the .55mm thread is in that 207-277 thread size.
  6. Yeah this was labelled as a grade 1 whole hide. Lmao but I think someone stole his head. If that hole would not have been there I could of got 5 nice wallet backs. I think I'll make me a wallet back from its glory hole part of the hide & have a eye looking thru it. I'm not to mad, I bought the hide cheap enough & think i could double my money on it.
  7. Lmao I thought when you buy a whole hide, you get a whole hide. They robbed his head & the piece that is there has a dang hole right smack in the middle. Like a bullet hole.
  8. No problem with it knotting up while sewing. I'm not trying to sell you on it. But it is worth trying. Polyester is the name I was trying to remember. Lmao.
  9. No it's a braided poly thread. Uv resistant, unaffected by moisture. It seems to be good stuff. Everything I sew is with poly thread. Sorry kinda absent minded temporarily.
  10. Looks good! So does item that hold a box of shotgun shells? Thanks.
  11. Thanks Frodo, next time I'm shopping for stamps I'll pick them up. Looking good there. Nice wallet.
  12. Here is some of that Rocky Mountain Poly-Braid. It is .55mm diameter or they say its similar to 532 linen. I think it is in that 207 maybe 277 thread size.
  13. Yeah I was going to buy the fancy brass weights, Till I seen they cost $50-$80each. These are doing just fine. I should cut them in half to make 4 weights of 1.8lbs each.
  14. No Bob that is my Wuta alcohol spirit lamp in the upper left hand corner. Here is a better pic of it. Now here are my leather weights! Caterpillar piston wrist pins. 3.8lbs each. Covered with some 8-9oz veg-tan.
  15. Will just put this sucker here!!!
  16. I have yet to try Ritza Tiger thread. But I have some similar flat style threads & I cant seem to get the same consistency with flat thread as a round thread. Now I recently started using some rocky mountain braided poly thread & I really like this stuff. Wax is about perfect, tightly braided, lots of colors, UV protected. Might be a bit pricey at $9.00/roll if bought in bulk.
  17. I may be totally wrong, so keep that in mind. But to me it looks like you are scratching your leather with 1 side of the beveler leg. To me it looks like you need to roll/lean your edge beveler away from the leather. Towards the outer edge. Also to me them bevels show classic signs of a dull beveler. Like I said I may be totally wrong & off my rocker. Hope I helped in some constructive way.
  18. Might look into some of this leather. Its soft & a 3oz calfskin leather from italy. I would think some leather like this would be ideal. This is the pebble finished stuff, but they make it in a smooth calfskin as well
  19. I'm thinking the sawtooth bevels are from a dull edge beveler. Another trick to sharpen a edge beveler is: Lay a harness needle on the table & cover the needle with a piece of sand paper of fine grit. Then pull your edge beveler over the top of the harness needle & sand paper. Then you can flip your sand paper & add green rouge to the sand paper & pull your beveler back over it, till its polished.
  20. Looks great! Love the colors.
  21. Yeah I bought them things too. Lol I cant think of the name of them. I thought i would use the heck out of them, ha! Used them once. I dont think they are that handy. I could see them maybe good for bag making when gluing up a bag or something.
  22. Looks great! Nice work. Really like the dye on the trapper pancake sheath.
  23. Thanks. That looks sharp. So I want to make sure I'm thinking right. I just use plain old white printer paper. Also let me ask? 1858 Remington or 1860 Walker? Thanks.
  24. Thanks for the tip. I'll try that.
  25. @DavidK did you resolve the splotchy dye problem you ran into. Tell us how things went. Thanks.
