That is not a 1541, even though it says that on the label. The 1541 has a horizontal hook with an end loaded bobbin accessed under the sliding plate on the left of the machine bed. This is a Juki DNU-1541:
Most people who sew leather, vinyl and canvas use synthetic thread that has been coated in a polymer or resin that bonds the filaments together so they don't untwist as you sew. Some threads are more heavily bonded than others. But, any bonding is better than none. Glazed thread is smoothed out and the little cotton or linen fibers don't stick out. It is better than just mercerized, but not as strong as synthetic bonded thread. Here is a definition of Mercerized thread.
Those threads are glazed, or mercerized, but not bonded. You will have a hard time using cotton or linen thread is a normal sewing machine. The shoe threads are usually waxed before you sew. In the case of a sole stitcher, the wax is in a pot that feeds to a barbed needle. This strengthens the fibers. If you run this thread through a standard sewing machine, without wax, it will probably break during the take-up cycle. At least that was my experience with Barbour's Irish Linen glazed thread when I last tried it.
Regarding the "shoe thread," ask the seller to check the label to see which way it is twisted. Most single needle sewing machines with hooks spinning clockwise require left, or reverse, or Z twist thread. But, some shoe sole stitchers require right twist thread. If you use right twist in a standard sewing machine it may unravel as you sew. Note, some twin needle machines may require right twist for the outside needle if that hook spins counterclockwise..
$1500 will get you a Consew 206RB-5. It won't sew 7/16 inch out of the box, but it can use #207 thread top and bottom. The machine might could be altered to sew higher by a dealer.
You have a couple of options to sew 7/16 inch with a flat bed machine. Juki LU-1508 NH (high lift version that accepts #207 thread out of the box). Adler 696 ECO (Not a flat bed. Cylinder arm, sold by our advertiser, Weaver Leather) Cobra Class 20 (sews up to 1/2 inch. Flat bed, 207 thread.)
There are a couple things you should know about those machines. First, they are all compound feed walking foot machines. Your Mercury is a dual (top and bottom) feed machine. Second, they may lift higher with the foot lifter, but are still limited to sewing 3/8 inch of material. Third, if you start sewing without holding back the starting threads, you will have an instant thread jam. In your video you started sewing without holding back the starting threads. Fourth, These machines have a normal upper limit of #138 bonded thread, top and bobbin. You may be able to get the Juki and Thor to sew with #207 on top, but not the Singer. How thick do you need to actually sew? What materials will you be sewing at this thickness?
Help needed with tension issues on 441 clone.
Wizcrafts replied to Watts's topic in Leather Sewing Machines
It could be. I got an extra heavy spring for my Cowboy CB4500 for use with hard and extra thick leather. The stock spring was too weak in some leather, but not in others. Note, that an extra heavy spring leaves extra deep tracks in the leather! I use bonded nylon 99% of the time and bonded polyester 1%. I have none of the problems your machine is giving you. Have you tried contacting the seller/dealer? The thread shredding can be caused by a burr on the hook, or throat plate, or feed dog. The hook may be too far from the needle, or the timing advanced or retarded. If the machine was purchased from a dealer I would be on the phone with them. -
Nothing in these photos is of any help.
- 3 replies
- reverse stitching
- topstitching
(and 1 more)
Consult this thread and needle chart to find the range of needles best used for a particular size of thread (top and bottom). If you run smaller thread in the bobbin, use the smaller needle listed. If you use the same size thread on both sides, use the larger needle listed. -
I take issue with this recommendation. That size needle pokes a hole that is much too large for the combined size of the overlapping lockstitches. I normally use a #19/120 needle with #92/T90 thread. Sometimes I use a #20/125 for difficult material or sewing through double sided tape. I would not use a #23 needle unless I was sewing with #138 thread, top and bottom and the leather is medium to hard temper.
I know of several clone brands that are top quality. But, their availability depends on your location. You are in the Netherlands so you may not have dealers selling and supporting the brands I am familiar with. I recommend buying any brand you like from an authorized dealer who will setup and service the machine as needed. Chances are good that unless you make a rookie mistake and jam up the bobbin case and shuttle, the machine could outlast you. Talk with your industrial sewing machine dealers!
Seiko STH-8BLD-3 - Help diagnosing noise at low speed
Wizcrafts replied to pgc's topic in Leather Sewing Machines
FYI, a type 3L v-belt is 3/8 inch wide at the wide top side. Most auto belts are type 4L, which are 1/2 inch wide. There is a big difference in applied pressure between the two sizes. With the proper length 3L belt you can probably tighten it back up to 1/2 inch deflection.- 8 replies
- noise
- consew 206
(and 1 more)
I would still replace the belt.- 8 replies
- noise
- consew 206
(and 1 more)
Sewing with the thread sock on?
Wizcrafts replied to JHLeatherwood's topic in Leather Sewing Machines
Your assumption is correct. If you leave a thread sock on while sewing, adjust the top tension to compensate for any additional drag on the thread. -
Sewing machines do not form saddle stitches. They are either lockstitch - with overlapping knots that need to be buried inside the material, or chainstitch - with a looper forming a thread chain on the bottom. The latter is only useful if you can't see the bottom of the work and heavy duty chainstitch machines are not easy to find. Briefcases were sewn with Puritan chainstitch machines back in the day. Everything else is done on lockstitch machines. The type of sewing machine you need to sew leather depends on a number of factors. It could be a flat bed, post bed, or cylinder arm. It all depends on how the work needs to be stitched. Belts, straps and flat items are best sewn on a flat bed. Hats and bags are better sewn on a post bed machine. Sleeves, cylindrical items and things the hang down on the bottom are best sewn on a cylinder arm machine. Many cylinder arm machines have accessory table attachments for sewing flat work. The things you describe don't require a super heavy duty machine. Show us some pictures of the things you are making and we may be able to recommend specific machines.
The belt may be bad. Try another belt.- 8 replies
- noise
- consew 206
(and 1 more)
Singer 111w155 feed lift eccentric - balance wheel?'s
Wizcrafts replied to Wyowally's topic in Leather Sewing Machines
Oooooooo! -
Just given singer 241-2. Have questions
Wizcrafts replied to BikerNettie's topic in Leather Sewing Machines
Do NOT run this machine a high speed without oil in it. It could seize. You may run it very slowly by feathering the clutch. -
That's where I buy my motors and reducers.
Singer 111w155 top arm shaft belt pulley
Wizcrafts replied to Hddodge's topic in Leather Sewing Machines
LOL Order from CowboyBob. He is an industrial sewing machine dealer. His phone number is in his signature under his name. -
I am currently using Barge all purpose, clear, TF, quick dry cement in a 32 ounce can with a brush. It is available in larger containers too. But, it costs less to try a quart!
Try Masters quick drying cement and/or Barge super speed toluene free contact cement.
JRM Clips makes them as the 3000 series, in New Jersey. I recommend calling them rather than submitting the contact form.
Inline Cowboy presser feet on Cowboy CB4500
Wizcrafts replied to Wizcrafts's topic in Leather Sewing Machines
I bought my inline feet from Toledo Industrial Sewing Machines. Their number is: 866-362-7397.
