TomG
Everything posted by TomG
  1. Can you tell us the setting you used? I have a 40W as well and wanted to do the same. %power, speed, etc. Thanks
  2. Looking for one. I'm in the Atlanta area. Thanks Tom
  3. Contact cement the edges together and sew inside of the cement line. Check out Arthur Porter on YouTube
  4. I'm interested in getting these. I'll even pay for shipping <g> Tom
  5. But... It's more FUN to bitch
  6. Hey Grumpy, Toss some Resolene in your morning coffee and all will be well in the world. I haven't seen the catalog yet, but I'll take a look in a sec. You have my curiousity peaked. MY only gripe, and it's petty, is the user who asks questions and obviously has not bothered to do even a rudimentary search to see that it has been asked and answered 100 times. But, life's too short to let stuff like that really bother me
  7. Thanks Max. I'll check into that
  8. I seem to recall they said to wet them with saddle soap and do what you said. I'm trying to figure out how long a strap I can get out of a side and minimize my waste.
  9. 5/8" to 3/4"
  10. Some time back, I found a method of cutting long, continuous straps from Latigo. It involved rounding the corners on a side and cutting non-stop around the perimeter. But I don't remember the details such as how to straighten the curves, limits to the curved portions, etc. Anyone have the info? I've searched here for over an hour with no luck.
  11. That's what I'm thinkin But I'm trying to figure out why it got out. This machine is only about T months old and has only infrequent use so far... about 125 of these straps and some.lighter weight stuff. Guess i'll have to do some searching for the procedure to adjust it.
  12. I need some advise on a problem I've developed. I was sewing the edges of some hand hold straps and things sort of went to hell all of a sudden. These are 6oz, folded in half to form a loop and then the opposite end folded back through a snap swivel, and sewn down. That's 3 layers. Those ends are skived down to about 4oz.. may a bit less. The stitch length suddenly started getting short at the thick end. Then, the needle began hitting something under the strap. I found the tip was getting dinged. If I took the strap out and ran the machine without thread, no hitting. Looking at the hook and needle, it looks like in have almost no clearance between the hook and needle. It I put the strap in place and move the needle down with the handwheel, the hook catches in the eye of the needle. I've tried new needles. Usually 138 thread, size 22 needles. Any ideas how I can fix this? Thanks
  13. Try this video. I know Chuck and he is a true master craftsman. Pay attention to how he holds the cut strap as he pulls the cutter. And a sharp blade is a MUST.
  14. Proper casing is essential. Too wet and the stamps mush. Too dry and the impression doesn't set into the core properly. See Bob Parks tutorial on it.
  15. Harbor Freight has a split leather welders apron for $10 http://www.harborfreight.com/split-leather-welding-apron-45193.html
  16. If you're using bottles, make sure the little bleeder hole in the lid is open, if you have one.
  17. Haha.. I got the ego too , but I've just learned over time what's worth the extra effort. I think that you are going to find that the "buckle it up and let it hang" method is going to be about the best "practical" method with the best accuracy. I like Dwights idea, but not sure I'd have the patience to make all of that balance out. Especially 5 or 10 times a day.
  18. Well, although I also like to be as accurate as possible, it honestly does not really matter. I do hundreds of collars. I use the exact method as shown in the image above and It comes out close enough. I have never, ever had a customer say "great collar, but the name is 1/2" off center". Different buckles, different sizes, customer mismeasurements that cause different hole used (as pointed out by Big Sioux), and other factors beyond your control make, it almost impossible to be super accurate every time. But, if you insist on making it "dead nuts on", using Big Sioux's preassembly method is about the only practical method. It takes all factors in to account automatically... assuming the same hole is used. Good luck
  19. Never thought of that! Good idea. Thanks. I wonder if they make a gum eraser pen? I know they make eraser pens for use in drafting and so on... If I DO get stray cement on it, it's usually right there at the outer edge of the stamped groove on letters, for example.... But no scratch is much better than maybe scratched <g>
  20. We've used the acrylics from Hobby Lobby with no issues. I have a key fob that my wife painted a dragon on using the $1 a bottle stuff. I've carried it in my pocket daily for 2 years and it still looks good.
  21. Yup. Use some Denatured alcohol or rubbing alcohol. You can even use water if you have to.
  22. Believe it or not, 2 things work really well, but are a but awkward to apply. The first is liquid latex rubber. I got mine from Hobby Lobby. It's kind of pricey at $19 for 16 fluid oz. They often have 40% off coupons that help. It has a VERY strong ammonia smell and has a shelf life of maybe a year or so. Then it begins setting up in the bottle.. like contact cement does. The second is rubber cement. Sounds weird, but it works just like the latex rubber and a heck of a lot cheaper. I apply a couple of coats. Most of what I do is stamping and I apply it with a brush. I have some that I only use with the rubber cement. Clean up with DA or Acetone. If you get it where you don't want it, let it dry and scrape it off with an xacto. You don't want to scrape the leather if you can help it. As for the awkward to apply part, you need to try to get it down into the recesses of the stampings or cuts. If you don't, the dye will flow down into the grooves and seep under the resist at the edges. And of course, you probably don't want to dip dye as you have a good chance of seeping through from the back. Good luck and let us know how it works for you.
  23. There is a 2 page thread about dip dying at the link below. It goes into lots of detail about different techniques and ideas.
  24. Tandy in Atlanta has it, although it's not in the catalog. It is the Pro OIl dye
  25. They have a walnut dye. Looks pretty good
