Northmount
Moderator
  1. Reinforcement tape from Lisa Sorrell sounds great. Another option would be fiberglass window screen, or even aluminum wire screen if you really need additional strength. Either can be cut to whatever width and length you need. Tom
  2. Have you tried replacing the needle since the jamb? May be bent or point damaged. Tom
  3. Welcome to the forum. Whereabouts in Canada? Try this search on Google. "site:leatherworker.net bifold wallet pattern". Drop the quote marks. Tom
  4. Attempted to do some more work a few days ago with the Chinese Skiver / Paring machine. Attempted to skive the edge of some 8/9 oz. Chrome tanned. It just kept digging in deeper. Changed the angle of the knife, but didn't improve. I went back to one that I made modelled on the Scharf Skiver. Works much better. Tom
  5. Fibreglass tape, like used for drywall repairs works too. May need more than one layer depending on the amount of strain. Tom
  6. A piece of garden hose or similar used like a stethoscope works well too. Helps determine direction nose is coming from. Tom
  7. Google has much larger servers and more refined indexing in their search database. Do a Google search specifying site:leatherworker.net followed by your search words. No spaces in site:xxxx. You can limit your search to any site you wish by using the site parameter. Tom
  8. Are you still looking for someone to do this work, or is this a dead end? Tom
  9. Might be a good idea to tell people where on earth you are located! Russia, China, Germany, South Africa? This is a world wide forum. And by the way, welcome to the forum. Tom
  10. Usually more top tension required to pull the knot up. Make sure the thread is between the tension disks, that it hasn't jumped out and riding on top. Try a larger needle size if the top tension is already quite tight. Need a large enough hole to be able to pull the thread up. Tom
  11. Moved to leather sewing machines, so you will likely get more response here. Help wanted is like newspaper classifieds advertising for employment purposes. Tom
  12. Are you looking for a portable package that will be used for vibration data collection route, or stationary use for vibration analysis at a machine location? For a data collection route, are you looking at carrying the package on one arm, or on shoulders with tablet in front of your chest. I have several years experience with vibration data collection routes using various types of data collectors, some integrated with pen tablet PCs. Will need more information about how you want to integrate the system for easy and safe carry working around operating equipment. Often in tight locations in close proximity to other machines and moving parts. PM me and provide your email address so we can discuss the requirements. Tom If PM doesn't work for you, go to https://tomscrafts.com/contact and fill in the contact form. Photo of a recent project.
  13. You could try burying it in cornstarch, or floor dry, or kitty litter and let the oil leach out into it for a week and see if there is any appreciable improvement. Guys that have over oiled leather have been successful in removing some of the oil. Stir it up a couple times each day. Tell us if it works for you. Tom
  14. Likely not enough top tension, or top thread not seated between the tension disks. I don't have a cobra, but from many comments here, the thread is supposed to go around one of the pairs of tension disks one and a half times. You can search the forums here for more comments and problems to clarify the proper threading route. The mess on the bottom is often called a bird's nest, so you could include that in your search parameters. I see you are new here. Welcome to the forum. Lots of great experience and information here. Tom
  15. I just cut up a side of cowhide I was given. The cowhide was sent to a tannery by the ranch owners. Then after it was tanned, it sat for many years and travelled across Canada and back. Then sat in my storage for another year or so. Seemed to absorb water somewhat, but not like vegtan. Could stamp it, but didn't leave good crisp impressions. Had been drum dyed, but centre was blue grey. Also could not wet form the leather. The blue grey colour in the middle clinched it for me. Chrome tanned. If struck through, the other behaviours here may help sort out the type of tannage. Finally used it to make a set of saddle bags and gave them to the fellow that donated the hide to me. He has MS, can still do some riding. When he can't ride anymore, he can through them over the back of his wheelchair, or I can remove the yolk and split them into two separate bags with whatever type of handles he wants. Tom
  16. I was shaking up a bottle of dark brown dye a few days ago. Suddenly saw lots of black spots appearing before my eyes. Thought for a second it was more eye trouble! Dye hit the white fronts of the cabinet doors, the front of the deep freeze with a wrinkle finish, the floor, ... It sure set fast, really hard to get out of the wrinkle finish paint. Took some scrubbing on the vinyl tiles too! Finally used ethyl alcohol on the cabinet doors. Softens the paint too. Good thing I hadn't given them the finish coat yet. Tom
  17. Where did you order yours from? Tom
  18. Do a google search like this "site:leatherworker.net leather hat" without the quotes. Google has much greater search capability having indexed most of the available web. Site: limits the search to the specific site. Tom
  19. A photo would help. Some bags have handles on both sides. Might fit for yours too. Another possibility could be to attach it to diagonally opposites spots on each side of the bag. Tom
  20. Bob has this chart posted on his site. http://www.tolindsewmach.com/thread-chart.html Tom
  21. Moved to help wanted. OP's IP address is located in Winfield, West Virginia, 25213 Tom
  22. According to the IP address, poster is located in North Dakota. Tom
  23. You definitely don't want mould in your shop, so need to get it cleaned up. I found oxalic acid removes the mould and stain. Some people put plain old listerine mouthwash in their casing solution to help prevent mould and fungus while tooling. Tom
  24. Thanks from all. Great list to have available. Tom
