It seems that UV light darkens leather, yet leather that is behind glass seems to fade. So it must be just the heat (infrared energy) that causes the fading to occur. Whether you can use open sunlight (UV rays) to darken the leather again, is questionable. You could repeat this as an experiment on the same type of leather before you decide to try it with your saddle bags. As an option, you could try oxalic acid to see if you can bleach the leather all to the same colour, then try dyeing it. Again, try on some scrap of the same leather first to see the results. When you re-dye, you'll have to dye the thread at the same time. So no white thread accent. Last resort, dye them a darker colour, dark brown or black. Dark brown might be able to cover the differences you see now. With an air brush, you might be able to compensate for the lighter and darker areas of the leather. You could dip dye. Hope something here helps and works for you. But you will have to experiment a little to see what the best route will be, especially concerning the time it could take to fix up the saddle bags. Tom
As wyomingslick says, for a knife sheath, should be able to do it with no joins. However on longer stitch lines, you will need to learn how to join. Not only does it take you longer to pull all the thread through each stitch, but the thread starts to look kind of ratty after a while. I second Al Stohlman's books. Tom
Take a look at this http://www.tandyleatherfactory.ca/en-cad/search/searchresults/4044-01.aspx In some respects, it is similar to the truckers wallet, no zipper, no chain. Tom
The name seems to get lost. Are you going to use some dye to highlight the name? If not, I would try to open the design up around the name a little bit. Not very much though else it will look like something is missing. You've done a lot of very good work on the design. Tom
There are lots of threads here on what is needed for a leather sewing machine. Go to the pinned topics in the sewing machine forum. Also do a couple searches for leather sewing machine Tom
The latex water based contact cements are all good for leather. Do a search, there are other threads on this subject. Ordinary PVA glues are okay. White glue is flexible after it sets. Yellow glue used for woodwork is not flexible when sets. So when you bend the item, you will hear it cracking. Still holds the leather together. Won't be as strong a joint, and is a bit disconcerting to hear the cracking sound. After several bends, most of the noise stops. But, just use white glue and avoid the issue. Tom
The longer brown stitches are probably what are called basting stitches. They are put in first. Long stitch length means easier to pull out if you need to make adjustments. Once it is basted together, then the finish sewing is done. The jacket is assembled in sections, not all basted together first before final sewing. Most are not glued before sewing. Super glue may be used so you can assemble pieces since you can't always clamp or use pins like tailors do. Where you can get away with it, you can use a stapler to "pin" pieces together. Put them a little ways away from your stitch line, on the hidden edge, so you won't have staple holes showing. I did a leather coat many years ago on a home sewing machine. Used lamb skin glove leather. Wasn't fancy but was nice and warm with a quilted lining. Tom
Here's a thread you should read http://leatherworker.net/forum/index.php?showtopic=50439&hl=%2Bwashable+%2Bleather Tom
Bonded doesn't mean lubricated. It means the fibers are bonded together to reduce fraying of the thread. Bob Kovar at Toledo Industrial Sewing Machines http://www.tolindsewmach.com/thread.html has pre-lubricated nylon thread. Tandy has (or had) some too. I have a couple spools of white lubricated thread I got from them some time ago. It is lubricated with a silcone based lubricant. Bob (cowboy bob) may have polyester too. Give him a call. Tom
Read post 127, and any of the subsequent posts listing the url for the patterns. Always a good idea to go to the end of a thread to see the latest info. Tom
My Very First Browband Headstall Ever!
Northmount replied to LeenieBean's topic in Saddle & Tack Maker Gallery
Pretty nice. Tom -
Tooled Car Dash Must See This
Northmount replied to goodfella's topic in Satchels, Luggage and Briefcases
For his full post here on LW, go to http://leatherworker.net/forum/index.php?showtopic=23901 Tom -
http://elfitakorea.blogspot.ae/ This link works better.
- 8 replies
- leathercraft tools
- tools supplier
- (and 4 more)
Had a look at the new printing by Tandy. It is a large book, will cover a lot of your coffee table. Screw post binding on the long side. Portrait printed for the single sheets. About an inch thick. Some sheets fold out 4 times, so need the be taken out of the book to work with. It's more than I want to pay for. But would make a good present for a leatherworker! I made a suggestion, now see what happens at Christmas! Tom
How To Remove Excess Contact Cement
Northmount replied to biker55's topic in Leatherwork Conversation
Some contact cements can be removed by letting a puddle of cement dry in a cup or some disposable dish, then using the solidified wad to press against and pull off the errant cement on your leather. You keep pressing and pulling it off, move to a new surface on your wad, and keep repeating. If you are familiar with using tape to pull of adhesive residue from left price tags, you already know the process. Just keep repeating until the job is done. Using a solvent spreads the stuff around and gets more of it into the leather surface. Tom -
If the white stuff happens to be wax ... You can test for wax by warming it up some. If it melts easily, it's wax. Can probably rub it with your fingers to work it into the leather, or buff off the excess. There was another thread a few months ago about wax forming on the surface after doing some finishing work. Try a search for it. Tom
A couple spots look like they are undercut. Hold the knife so the blade is always perpendicular to the leather, so it doesn't slide under the edge of the cut. I think you cuts are really pretty good. Mine are getting worse due to medical problems, so yours are much better than mine are now. Tom
- 4 replies
- help
- swivel knife
(and 2 more)
I use transparency film on a laser printer. Works well. Tom
Knife Sheaths With Stingray
Northmount replied to malabar's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Very nice! Tom -
Make a small platform that clips over the bottom cross braces at the height you want. Chances are a chain will work for your speed pedal. Then when not in use, move it up to the top braces. Using chains, you won't have to disconnect anything. Tom
- 181 replies
- diy sewing table
- industrial sewing table
(and 3 more)
Had a Tandy email today where they are clearing out the key posts. So try the Tandy site. Tom
As mentioned above, reduce the top tension. It is too tight and pulling the knot right through. If the tension disks are loose, remove a wrap from around a guide post too. Make sure the thread is pulling off the spool and not getting hung up. Tom
If the iPhone has a magnetic switch in it (like the iPad) to blank the screen when the cover is closed, that is the only effect that magnets will have on modern solid state devices. Does not affect memory, etc. as magnetism is not used for storing information. It is easy to test, just move a magnet around the front and back surfaces to see if it triggers any switches. Some models of Blackberry phones use a magnet in the case to switch the screen off automatically when the phone is holstered. The one thing to watch for with phone cases is that they are not so tight as to hold push bottom switches in the depressed position. Software can get mixed up with the "unusual" condition and require a hard re-boot, taking the battery out and replacing it, to restart the phone. Some after market cases were being blamed for these software problems, blamed on the magnets, but really was the case was too tight. Tom
Try reducing the time you have the stamp on the leather. Just want to burn the impression, not cook all the leather under the stamp. Tom
You need to buff off all the "loose" pigment on the top of the leather after it dries. That's the stuff that didn't soak in. That will reduce the amount that gets spread around when applying a finish on top of it. Water based dyes dissolve easily with water based or alcohol/acetone or other strong solvents. So as you say, air brushing is you best answer to avoid mixing it up again. But really buffing the surface stuff off will help reduce the spread. A waxy finish is really a conditioner, not necessarily a sealer. But might be adequate for what you want. Mop n Glow is just an acrylic floor wax/polish used for vinyl tiles and such. Should find many other brands that you could use. There are some additives in the acrylic floor wax that helps to clean the floor. So rubbing it around on your dyed surface will lift the dye as well. You may be able to find an atomizer spray bottle that will work for you to spray the finish on with. It needs to emit a fine mist. Any droplets will leave marks on the leather. Windex window cleaner spray bottles are supposed to be good. The misting type for plants or ironing that I picked up are not fine enough. Tom
