Northmount
Moderator
  1. @Silky You must post a price and give clear information about the condition of the machine(s). Read the rules for the marketplace and comply.
  2. @DustyBench Moved your post to leather sewing machines.
  3. @ValinorKings Moved your post to leather sewing machines. This is a case where it helps to take photos or make notes as you are disassembling the wiring, etc. Then you can simply follow your notes/photo to reassemble. This is a double pole single throw switch (DPST). It breaks or closes both the supply and neutral lines at the same time. Can't see the switch rocker as there is no photo to compare the orientation of the rocker compared to the orientation of the terminal tabs. So that makes it difficult to accurately describe what to do! This switch looks like yours. (If the tabs are inline with the rocker, the diagram is still accurate for the connections.) Start with the cable that comes from the plug. One wire is hot (red), the other is neutral (blue). (The green safety ground wire is attached to the housing somewhere and you can ignore it as it isn't switched.) So follow the diagram. Input is from your plug cable. Hope this helps.
  4. Bleepingcomputer.com update "We are reviewing log files which we have received from affected customers to further characterize the attack and the mechanism of access. The log files we have reviewed show that the attackers directly connected to the affected My Book Live devices from a variety of IP addresses in different countries. This indicates that the affected devices were directly accessible from the Internet, either through direct connection or through port forwarding that was enabled either manually or automatically via UPnP."
  5. Don't want too heavy a weight, and don't want to place anything with a texture on the leather. So a piece of poly and a book works fine.
  6. @jynelle Hasn't been on the site since May 10th. Since I tagged her/him you may get an answer back.
  7. You should provide some method whereby you can be reached if you are really interested in working with them.
  8. Not very likely as the link is dead! This thread is now archived.
  9. Add some photos and more description and you may get some attention. You should also read the Marketplace Rules and comply. The post above really doesn't do justice.
  10. @Sasho Moved your post to leather sewing machines.
  11. Over-size so you can trim all edges evenly. Can also use staples to hold pieces together as long as you leave the little extra space to trim if off after.
  12. @Jerrysleathercrafts moved your post to Leather Sewing Machines.
  13. Hey @Willyac, to get someones attention, use @gottaknow and click on the name in the drop down list. Then they will get a notification. See how it works?
  14. @JB0090 Moved your post to Marketplace used sewing machines.
  15. Start a new thread in https://leatherworker.net/forum/forum/89-wanted/ I'm archiving this old thread.
  16. Contact @Johanna
  17. This is a world wide forum, so you may have queries from Europe for example.
  18. I'm not in the market for them. I was giving you some direction in my capacity as a moderator for this site. You may have interests from other locations too.
  19. @Mike Craw Please identify where you will ship to and who pays shipping costs as per the Marketplace Rules. Thanks.
  20. @Warre Moved you post to the Marketplace. You need to provide photos, etc. Please read the Marketplace rules and comply. Shipping info - will you ship, who pays, etc.
  21. @Bee00 Moved your post to the Marketplace.
  22. @Ulrika66 Moved your post to the Marketplace. Please read the marketplace rules and comply. You need to provide a selling price and should state who pays shipping.
