Everything posted by Thor
Yeah interesting design, even though I don't see a real purpose for it. Anyhow, you need better tools and stop chewing on your liner. Looks like you ripped the leather which I feel makes the overall appearance not so great.
Para-Cord Stitched Knife Sheath
Thor replied to Instinctive's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Neck knives have their use and simply adding a belt clip could turn it into a nice boot knife or wherever you want to carry it. Shortening the para cord and adding a snap hook wouldn't hurt. This way you can have a strap for the neck or one for over the shoulder, or simply hang it from your vest or backpack or whatever. Besides that, the sheath looks good to me. -
Sneaky Pete Type Holster
Thor replied to Chief31794's topic in Gun Holsters, Rifle Slings and Knife Sheathes
To be honest Chief, compared to your other work it looks like you rushed this one. -
Scissor Tool Belt
Thor replied to Manypawz's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That would probably work for hair stylists as well. Very nicely done! -
This is the artist https://www.facebook.com/StanleyauLeatherart you just send him a message and ask.
A piece of old hardwood or barn board. This is just stamped with something like that. Too many actual real detail in there to be made with a leather stamp. Where the board is "broken" it was cut and stamped. The rest of the texture was probably modeled after "stamping". I believe we had this in another thread before. The softer portions of the wood can be removed with a "brush". You'll need a machine for this. It will bring out the wood texture a lot more and you'll have a negative for this. You can tell on the picture that this is what was used here as the indention is where one would expect a rise. He then touched it up here and there and that's the whole trick. I'm quite certain you'll find an old barn board at your location some place. Good luck with it.
Fountain Pen Case
Thor replied to FidesLeather's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
If you take a close look at the front you'll see a single lace over each of the middle pieces. I would expect a second one where it's covered and then being simply glued in place. -
It probably depends on what your favorite topic is and how much detailed information you want or need. I like this guy here: https://www.youtube.com/user/cheaneysaddles/videos may be better for your wife, too
Fountain Pen Case
Very nice! Thanks for sharing. -
I have seen some on Google Documents recently. I believe my search phrase was "service dog harness" and led me to i. e. http://www.google.de/patents/US7281363. Other than that, you could use the current vest as a reference and build one from scratch.
- 1 reply
- veteran
- service dog
(and 1 more)
Attaching Native American Bead Strip To A Carved Leather Belt.
Thor replied to Leather Maid's topic in How Do I Do That?
https://youtu.be/mkqwROOr8bg Hope it helps. -
Aren't you going to France sometime soon? Stop by in Germany and buy your tools here. Power converter alone doesn't work as we are having a different Hertz frequency as well. Shipping within Europe isn't an issue. If you need help finding something, let me know Mike.
If I dye, and I'm not an expert on dyeing, I do it after all mechanical work, but before setting hardware and before burnishing. I will buff it again after all hardware is in place. Hope this answers your question or someone else has a better explanation.
The problem is that it is water soluble. I had those issues as well and at times I'm making use of this issue to give it a more vintage look. I haven't found a reproduceable solution, but what I do is letting it cure for a few days and go very gentle about the finish cote and give it a good polish after another few days. Other than that great job on the cover.
Fiebings has a product named bag kote which is pretty much what you're looking for.
Couple Of Knife Sheaths
Thor replied to Boriqua's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I believe the technique is called sunburst. You can either achieve it with airbrush or with very careful use of a brush. Very nice job on those sheath! -
One Professionally Designed Tool For Cutting Leather
Thor replied to rnuo2011's topic in Leather Tools
Or 5 mm which many of us are using... If I'd go electrical I'd buy something more heavy duty and professional looking at least. -
Kabar Sheath For A Friend
Thor replied to druid's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Guess I have to throw this in there. It would have been good if you added a welt. The way this is now, cutting the stitches may be the result. -
My First Flask....
Thor replied to Jon P's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
The only thing that could really be argued with are the walking marks caused by your beveler. In this case I'd be using a smooth beveler and not a textured one. -
It may be easier seeing pictures to at least get an idea what it might need. Hanging for x years and not being treated at all brings up the question if it dryed out to a point where it's beyond repair or not. I generally oil my tack from both sides (grain and flesh). If I would do the same in this case? I don't know. Definitely I wouldn't do it all at once. I'd ad a layer at a time and let it cure to avoid getting too much oil on it. On chaps I would only add a thin layer on the inside as I don't like it on my jeans. If it comes to the oil being used... personal preference! To some it's like a religion. I read that some people like using olive oil, others used canola oil... I usually stick to products I'm getting with my local leather wholesaler.
Raisin Mahogany Dye
Thor replied to seabee's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
How badly do you want it? Looks like the manufacturer is Fenice in Italy. Tandy seems to just sell it under his own name. On the other hand it looks like Raisin Mahogany is just reduced Dark Mahogany with a very slight touch of purple. If you really, really need it, here's a supplier in Germany still having it https://www.rickert-werkzeug.de/de/Farbe-Pflege-Kleber/Leder-Antik-Finish-Eco-Flo-Hi-Lite-Stain.html?c=119. They will ship to anywhere in the world, but I wonder if that would be very economical. -
I don't buy there. Too expensive for what I need and want. Most of my veg tan comes from Spain, which is top notch quality. The last double-bend I bought through my wholesaler was 1.6 m² and 5 mm thick at 120 EUR. We should see a little price drop by the end of this year in Europe. I doubt it will last for very long, but this should be the result of this year's dryness.
Very nice work the bag as well as the pictures! Some things are really expensive in Poland. Is that including shipping or the price at your local wholesaler?
