fredk
Contributing Member
Everything posted by fredk
  1. I've read most of this discussion. I think I'll add my perspective now. Just the way I find it all and how my family, my friends, associates and the general public in N.I. view it Since about the early 1970s 'Hand made' has become the short-hand way of indicating that something is made by a crafts person/people and hasn't come out of some mass-producing factory Yes, a crafts person will use machinery to make the parts he/she needs to make that final product. But he/she will, maybe with one or more helpers, will make that item My father was craftsman of sorts. He was a fully trained and qualified cabinet maker. He used to use drill presses, a planer-thicknesser, a Shop-Smith lathe, electric planers and more. He got the raw timbers in, worked them on his machines as needed and built the cabinet as was required. Even though he sometimes made a dozen of a certain style of bathroom cabinet no two were exactly the same, because they were 'hand made'. You want exactly the same? interchangeable parts? buy one made in a mass-producing factory Its a habit of English speakers to reduce some concepts and ideas down to certain terms, even if that term is wrong, or to reduce phrases down to the least number of syllables thus its quicker and handier to say 'hand made' than 'craftsperson made'
  2. A few years ago Tandy did some free Christmas themed patterns. A different set each year. They could be adapted to put on just about anything
  3. Thats basically how I sew. I only look at one side of my project, usually the right hand side. No ows! cos I pre-punch my sewing holes and only very occasionally need the awl to open up a hole if a needle won't go through cleanly
  4. I think they could be used, but as far as I can see, only the roller on the outside can be changed so you'd be limited to what can be fitted on there
  5. I can still find them on ebay-uk https://www.ebay.co.uk/sch/duckcreektraders/m.html?ssPageName=STRK%3AMEFSXS%3AMESOI&_trksid=p2053788.m1543.l2654
  6. Muchly thanks for the new link. My old link wasn't connecting any more and I couldn't find if the Library was in a new place
  7. yes, but limited use. I use Swann & Morton scalpels and blades. I use them for cutting threads, trimming lace to a fine point for the brass round lacing needles, for trimming badly cut edges. . . . No good for main cutting or cutting for tooling instead of a swivel knife
  8. Thats an excellent summary Only other thing I can add for now is I like my stitching holes pliers These; They are available with four teeth and two teeth. Only really suitable for a maximum thickness of about 3.5mm tho They make the making of a long run of stitching holes a real doodle. Not too long ago I made a book cover, like this one, It took me about 5 minutes to make the stitching holes all round it. Down side of these pliers is the stitch spacing and the size of the holes is fixed to one size. afair The teeth are about 2mm wide and 2mm spacing, gives about 6 or 7 stiches per inch, which is ok for many things Spyros mentions an anvil. For years I've used a lump of steel that I got from somewhere. Its round, about 4 inches diameter and 2 inches thick with one square edge and one bevelled edge. Still serves me well but I also have a 3kg anvil - that is small. The anvil has a horn on it which is useful for setting ready rivets inside something
  9. The frog on the web page you linked to looks like a 'general purpose' frog. It holds the sheath loosely. Its alright for when you are upright but I think it'll be too loose a fit for a sheath on someone clambering about a boat. If you are making the frog, wet mould its loop on the sheath with the blade in it When I made this frog / hanger for a stiletto knife sheath I wet moulded it to the sheath. The sheath could never be pulled out
  10. imo the pitting is part of the history of the blade To remove the corrosion - a conservator at the RAF Museum, Cosford showed me how just leaving the metal in a weak solution of citric acid for a long-ish period removes the corrosion. He showed me before and after examples of aluminium alloy, brass, copper, steel and iron. I've used the technique using lemon juice in water and leaving an old rusted up tool in it for a couple of months, renewing the solution periodically though. Cleaning the blade back to shiney metal - various grades of wet & dry grit paper, starting with rough, 320 grade, thru to 2000 grade then polishing with toothpaste 2nd vote for JB Weld - if you really must
  11. I reckon a brown oil dye and a real good coating of a beeswax/nfo/carnauba wax mix applied and rubbed will in and buffed. Maybe a few coats of the wax mix
  12. sometimes ya just want to save something. try adding alcohol, eg, IPA or meths and some water. Shake and leave for a couple of days, shaking it real good every so often. If that doesn't bring it back - dump it mop & glo floor 'polish' or just a beeswax/nfo/carnauba mix
  13. afair I got some from https://www.ebay.co.uk/itm/152729174649?hash=item238f5e4279:g:Y4cAAOSw52tbZCiU yes, as long as you've not used a wax to burnish, and yes
  14. budget for a stitching pony or clamp
  15. One less step. Get stitching chisels, sharpen and polish them and they'll make your stitching holes in thinnish leather in one job, - no marking and then carefully piercing with the stitching awl. Also, in my case, I find it hard to see where the marks are, especially on dark leather
  16. 1. get a couple of better knives. a. minimum of a box cutter/utility type knife and a box of blades, and b. a rotary blade knife of 45 or 60mm diameter example of a b also get a set of wing dividers
  17. What about using thick(er) leather and making a 'book' of leather sheets/leaves. Sewn along one edge with the first or last having a flap sort of thing to fold over the rest of the 'pages' to keep the 'book' closed
  18. y'all (except chuck) are missing the OPs question He doesn't want to buy white leather, or how to dye it white, he just wants to know how its made! afaik modern white leather is produced by using strong acids and chemicals during the tanning
  19. I have several ideas on this. #1 Apply some beeswax to the snap and the leather around it. Make a coffer dam around the snap, about 1/4 inch out from it using something like bluetac. Paint on mould making latex. Put on plenty of layers of the latex to build up the thickness. When the latex is completely dry peel it away. Now you have a mould you can make copies of the snap cover. Try this out on a test piece first. Once you have the mould you can make copies of the cover for further work, eg just cast a copy in a resin material and use that on your replica, or use a copy to get a brass copy cast from
  20. Use thin veg tan leather. Cut it to size for the gusset. Wet it and fold down the middle. Sew one side edge to the back panel then sew the other side edge to the front panel. If you sew it whilst its still damp / not fully dry you can then press the front and back panels towards each other and the gusset will take on the fold more permanently
  21. Try Le Prevo http://www.leprevo.co.uk/eyelets.htm
  22. With buying scraps, or 'project sized pieces' off the likes of ebay or amazon, unless its coming from a regular type leather supplier, you are going to get someone's left over scraps. Even with a known retailer you can get rubbish sometimes, eg I once bought a couple of 'project piece' bellies from Tandy ~ I got a couple of pieces that were absolutely no use at all - they were just scrap
  23. or draw-string money bags
