Everything posted by Dwight
whats a good leather and thickness to wet mold?
Dwight replied to ToddW's topic in Leatherwork Conversation
That's basically 7/8 oz . . . my usual holster making material . . . I double it . . . contact cement the two together . . . and mold the holster from that. I also make a lot of other stuff out of it . . . probably my favorite thickness . . . makes great CCW or cartridge belts . . . Vacuum forming rig helps out. May God bless, Dwight -
ST leather in St Louis . . . or Tandy Leather . . . both sell on line . . . https://stleather.com/ https://tandyleather.com/?utm_source=GMB&utm_medium=Yext&y_source=1_MjM3NjIzNTItNzE1LWxvY2F0aW9uLndlYnNpdGU%3D I buy from Tandy . . . have no complaints on the stuff I've gotten from them. May God bless, Dwight -
Lots of us on here make those things . . . This is my most popular one . . . hangs off your belt . . . strap goes up and over the top of the phone . . . then down between the phone and the outside of the case . . . very secure. May God bless, Dwight -
Unless requested by the buyer . . . I only make 2 1/2 belts. Adding 4 inches is the "standard" . . . and it don't make any difference where or how you measure it . . . so long as the regular belt the buyer wears and the gun belt are measured the same way. Measure the buyer's belt to the "most used" hole . . . it'll be the one that is wallered out. But as a practice . . . I always measure from the edge of the buckle . . . That does not appear to be a money belt . . . but most of the reason it curves is his pizza belly and the weight of the cartridges. They are some kind of heavy when you put a bunch on a belt like he has. The holster can be stopped from pulling up with a thigh strap . . . or sometimes folks will sew in an extra piece of leather that goes up and pushes against the belt so the holster can't pull up. May God bless, Dwight
Some time back . . . I filled a quart jar with steel wool . . . poured in the suggested apple cider vinegar . . . and waited a while for it to work up. Brought the jar into the shop . . . liquid is some kind of super dark black . . . BUT . . . put a piece of veg tanned leather in it to check it out . . . it turns the leather a very pretty dark grey . . . but it ain't black. Did I miss something in my journey??? AND . . . what is the preferred final step to get the vinegar acid out of the leather???? Thanks, may God bless, Dwight
Absolutely beautiful . . . thanks for the look May God bless, Dwight
Beautiful leather and metal work . . . but I'd love to see the knife May God bless, Dwight
When I do zippers . . . I use Weldwood and contact cement them into place . . . Works great. You just have to be sure to use two coats most of the time . . . May God bless, Dwight
Stiffening Crazy Horse leather for a sunglass case?
Dwight replied to AWORKOFMARC's topic in How Do I Do That?
Kydex is the word there. With a heat gun . . . you can virtually form it into almost any shape you want. Give it a good sanding before forming it (whole lot easier while it is still flat) . . . and then you can contact cement your liner and your outer cover to it . . . holds good. May God bless, Dwight -
My gun belts are all of 7/8 oz leather . . . exactly 8 oz is 1/8 of an inch . . . so a double layer is 1/4 inch if both pieces were a full 8 oz. Usually the leather I get tends to be a bit shy . . . so my total thickness usually runs in the .200 inches or thereabouts. I generally cut both pieces from the same hide . . . if there are any small blemishes . . . they go to the inside. And yes . . . if the money belt were curved . . . it would fit better. The last couple I made were of 5/6 oz and I did them rough out . . . so they would cling a bit better to the wearer. Again I did not get any complaints . . . but I'm sure I know what happened . . . they cinched them up good and tight to start with . . . and the body heat and perspiration tended to re-mold them . . . similar to that which occurs with regular work belts. I've played a bit with using two different thicknesses . . . and never really liked the feel or the look . . . just one of those things on me. The big aggravation is that using a thinner lining . . . it will tend to bubble and buckle . . . looking wrinkled . . . I try to stay away from that look. May God bless, Dwight
It is probably the same product as Deanr mentioned . . . Tandy sells a "bag stiffener" . . . I've used it on numerous projects . . . strong, lightweight, not extremely expensive, cuts with a razor knife . . . It can go inside your liner . . . and / or can be fabric covered for a "different" look inside the bag . . . as well as making little pockets to attach to it for ink pen, scissors, compass, envelopes, credit cards, or whatever. May God bless, Dwight
I learned to make gunbelts and holsters from John Bianchi . . . a premier leather worker. I watched his lessons on making western drop down gun rigs . . . and while he told you how to do it . . . he did not supply any pattern ideas. I guess he figured if you were hoss enough to jump into it . . .you'ld figure it out. I had to do a bunch of "print screen" shots . . . then print them . . . and measure them and scale them . . . to figure out how to do a bunch of things . . . the belt curve was one. I made a pattern as you can see in the pictures . . . that will open up for bigger or smaller patrons. Look at the edge of the big picture . . . and you'll see the numbers that correspond to the size belt I'm making at the time. For your example . . . I picked a 42 inch belt . . . which is the gun belt size for a person whose normal belt size is 38. In the close up . . . you can see that there is a 4 1/2 inch difference on the curve. I have used this pattern for 20 some odd years now . . . never had anyone complain about it . . . And yes . . . you can save yourself some stitching by making money belts . . . and I've made a few . . . and the sorry things would never stay up like I really wanted them to . . . unless I put them on like a girdle trying to hide 50 lbs of pig fat. They are not one of my favorite items to make. You also have to glue the moneybelt layers together just like a regular gun belt . . . or otherwise it will roll and flop up and down if you are in a truck or car seat. Making a full open money belt might be "authentic" of a few folks from back then . . . but certainly not many. AND . . . I don't make gun belts that are anything but lined. I started that way . . . plan on continuing. May God bless, Dwight
You can do wallets and some purses with this . . . forget belts and holsters. It only takes a 17 needle . . . and 92 thread . . . holsters need a minimum of 207 thread . . . and that is the BARE minimum . . . I do 346 on both belts and holsters . . . as do others. You need a Tippmann Boss or whatever the Tandy Leather equivalent is for that . . . and you are basically looking at 1000 bucks new . . . and whatever used. They are both hand machines . . . one pull on the handle and the push back . . . gets you one stitch. A 40 inch belt at 6 stitches per inch will cost you 500 pulls and 500 pushes . . . and about 1/2 hour. 10 minutes per side with a 10 minute break at the tip of the belt. I did a bunch of em. The single most important question you need to ask whoever is selling you a machine is the maximum thread size . . . if your thread ain't big enough to do the job . . . you will just waste leather and time . . . get frustrated . . . and quit. Oh . . . both of these machines can come with a littl horse looking mount . . . takes up about the space of an end table . . . and none of your apartment neighbors would probably even know you have a machine in the place. May God bless, Dwight
Good job May God bless, Dwight
Leather Armor - Advice on Scratch Resistance?
Dwight replied to DavidK's topic in Leatherwork Conversation
Never had that problem . . . I use a cheap 1 inch bristle brush . . . slop it on . . . brush it up into a bit of a foam . . . brush it left / right / up / down / crossways . . . until I've brushed out the bubbles . . . never have had any streaking on anything I've ever done. AND . . . I always use it reduced 50/50 with water. May God bless, Dwight -
My heavens and OUCH . . . have to wait until I sell some more stuff before I can order it . . . May God bless, Dwight
- 22 replies
- rubber to leather
- glue
(and 1 more)
You quit too early on the Resolene . . . I have armor for my Centurion of Capernaum and the Ceaserean Centurion both of which I built . . . and multiple coats of Resolene have protected both. I haven't had any real problems with either one. May God bless, Dwight -
Is it possible to soften the temper of a piece of leather?
Dwight replied to SUP's topic in How Do I Do That?
When I get done with a project . . . there will always be at least parts of it that need softened up a bit . . . Belts for example . . . get rolled over a dowel . . . and it usually only takes a couple of passes . . . the new owner always appreciates it being "pre" broken in. Straps on my shoulder holsters are another that get the same treatment . . . And no . . . I don't use chemicals . . . if I do, it is only neatsfoot oil . . . and that is in very very limited quantities. My holsters (pancakes) get the eyes worked over with a board I have that simulates an 1 1/2 belt . . . makes putting it on the first time and wearing it . . . make it feel more natural. It's fairly easy done . . . and works for me May God bless, Dwight -
Ya did a good job on that billfold . . . and you took care of my only criticism . . . the corners. They'll get dog eared in a hurry. A number of years ago . . . fellow asked me to re-create a billfold he had had since his daughter was very small . . . and he could not find one anywhere like it. I told him the only way I could do that was if I had the old one to go by . . . he started pulling cards . . . cash . . . pictures . . . yanked it all . . . handed me the old one and asked how long. A short time later it was in the mail . . . and he loved it. This was my practice piece I did first . . .to see if I had it all "right" . . . before I made his and shipped it. I had asked him if he wanted any changes and I got a very quick "NO" . . . so I left the corners square like his original. May God bless, Dwight Dwight
I generally do the key fob thing with my scraps . . . If it's too small for a key fob . . . I don't have much else I can do with it . . . but thanks Bruce . . . the zipper pull thing I never thought of . . . basically because I don't use them. Never have big enough scrap for coasters . . . except for one job that I did 3 times last year . . . and hung on to the 1st two sets of pieces . . . they'll turn into something some day. Like every one else mentioned . . . thanks Bruce . . . we need your expertise. May God bless, Dwight
Forget the idea of only 2 pieces. Cut 3 pieces . . . front . . . back . . . and one piece which is the bottom and both sides. Stitch the edges . . . or lace the edges . . . makes a pretty bag. May God bless, Dwight
Does anyone like this type of belt buckle?
Dwight replied to chingyoung's topic in Hardware and Accessories
Not in my lifetime. May God bless, Dwight -
John Bianchi Holster DVD's: WTB
Dwight replied to Dwight's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Thank you Sir . . . -
Thanks, Bruce . . . could not find anything on Ebay . . . and Amazon listed them but "out of stock" . . . Was just hoping someone here had em. Thanks again . . . Dwight
