Dwight
Everything posted by Dwight
  1. Get yourself a cup of good strong coffee . . . and turn off the TV . . . radio . . . and send everyone out of the house. It needs to be done by you . . . and it takes serious concentration. Take a piece of a manila file folder . . . draw lines on it EXACTLY THE WIDTH of your belt or collar. Draw a line down the EXACT center. Measure off and mark EXACTLY where the left edge of each hole will be on that center line. Lay your punch on that center line . . . next to the left edge mark . . . punch out the hole in the file folder. Continue until you have all of them punched. Take a razor knife and a straight edge . . . cut the outsides of the pattern. Now all you have to do to make straight punches is lay it on the leather and very lightly lay your punch in the hole and lightly tap it to mark where the hole should be. Remove your pattern . . . punch the holes. So help me it is a whole lot better than that overpriced thing from weaver. May God bless, Dwight
  2. If you remove the square "arm" that travels up and down . . . you can then take it to a drill press . . . and drill a hole in it about an inch and a half deep . . . the size of the diameter of the punch handles . . . and by putting a piece of saran wrap (or 2 or 3) over it . . . it will stick in the hole. Put the leather under it . . . pull down the arm . . . presto a hole. DON'T waste time messing around with cleaning it out . . . you punch the leather . . .it'll clean itself out . . . they are designed to do that . . . and they will do that. ALSO . . . make sure there is another piece of ugly old leather under the piece you are punching. THAT is where you are probably dulling your punch. I've got punches I have never sharpened . . . have used since 2000 . . . they still punch pretty round holes . . . and I just hit em once or twice with my mallet . . . belts / sheaths / slings . . . and I've even done a couple of dog collars. May God bless, Dwight
  3. Not sure what Handstitched meant by "flexible" . . . but here are a couple of double layer belts I've made . . . both are set up for a 36 inch waist . . . and obviously I've pulled them much smaller in the picture . . . probably in the 32 inch waist category as they lay there on the bed. The brown one is a standard double layer belt. The black one is steel lined from the screws you can see by the belt keeper . . . the lining goes all the way around to about 1/2 inch from where the first buckle hole starts out. I wear both . . . the steel lined is to me quite comfortable . . . and when I get up . . . I thread a cell phone holster on the left side . . . and a 9mm holster on the right side . . . Hope this helps clear up how well a lined belt can actually be. May God bless, Dwight
  4. JRodz uses nylon webbing . . . I use 3/4 inch stainless steel. They do not bend . . . or at least the ones I have access to seeing do not. Haven't tried going thru airport security with one on though yet. May God bless, Dwight
  5. Uhh . . . no . . . May God bless, Dwight
  6. Actually . . . the most important part of any video . . . is not the video itself . . . but rather the editing. It is actually the editing that MAKES the video. Anyone can set up a camera . . . run their mouth about all the great things they are doing and want to show . . . and it is not quite as boring as the democrat convention . . . but it is close. If you want to captivate your audience . . . it needs to be short . . . kill the idea of telling everyone about your great aunt's berry patch that let you into leather work 32 1/2 years ago. Stay away from long winded descriptions of this / that / and the other thing. State what you are going to do in all of about 10 seconds . . . then do it. Keep any instructional video at 5 minutes or less. Make a "Part 2" or a "Part 3" if necessary . . . you are not making 60 minutes documentaries. This is especially important if it is the same process over and over and over. For example . . . if tooling a large holster for an old black powder pistol . . . break it up into border . . . flowers . . . stems . . . fill in . . . etc. State what you are doing . . . then do it . . . and shut down. Tell interested folks to subscribe . . . that way they'll be notified of the next one. You might also look into Cyberlink Power Director 10 / 12 / 14 / or 16. They are some of the best personal use editors out there . . . there is a learning curve . . . but it is not a hard one. Cyberlink is trying to go "MicroSoft" and make the new subscribers rent their product . . . look on Ebay . . . you can buy these self contained programs at reasonable prices. PD 16 was the last full self contained . . . so if you can grab it . . . it is the best of the bunch. Finally . . . if you really . . . really . . . want to do this . . . invest in several cameras . . . at least 2 . . . 3 is a lot better . . . we use this one at our church every Sunday . . . we record on 4 cameras . . . take out the SD chips . . . go home and edit for an hour or so. https://www.ebay.com/itm/195172099088?hash=item2d7129e410:g:tt0AAOSwsEBiuedc Also if you want to put in a page of written instructions . . . use Power Point . . . you can import it directly into Power Director and drop it where ever you want. Finally . . . build an introductory screen . . . a short one . . . that tells who you are . . . and what you are doing . . . AND THEN . . . after the video is done . . . list the tools you used . . . the leather type . . . the dyes . . . the finish . . . give the customer a succinct place to come and get that info. Trying to go back and find it . . . even in a 5 minute video can be a real pain. Have fun . . . may God bless, Dwight
  7. Dye is a funny stuff . . . and it is a runny stuff. If and when you use it on leather . . . two things you can be sure of: if it is not sealed with something like Resolene . . . it WILL BLEED . . . and if it is properly sealed . . . it won't. You can rub a dyed piece of leather until the cows come home . . . and it will not bleed . . . then you get all hot and sweaty . . . transfer that sweat to the leather ( or just get some water on it ) and here comes the bleed. If you want to darken it . . . after you have tooled it . . . lay it outside in the sun for a day . . . two days . . . three days . . . and I guarantee it will darken . . . you may get it exactly where you want it. From there a light coat (on the hair side ONLY ) of neatsfoot oil . . . followed by a good rubbing of saddle soap and buffing . . . you will have a beautiful and useable sling. I do dye mine . . . then I put a light coat of resolene on them . . . and it works every bit as good . . . other than it will be somewhat stiffer. May God bless, Dwight
  8. On jeans belts . . . the loop free floats between two chicago screws . . . the ends of it sewn together in a loop. On a gun belt . . . I put the bottom end of the loop in place . . . and sew 3 or 4 stitch holes in front of the loop . . . thru the loop and one hole past . . . but there is no thread in the machine . . . it is just punching holes. I then thread the machine . . . sew the belt all the way around to the loop on the other side . . . stop the machine . . . pull out about 18 inches of thread from the spool and from the bobbin . . . then I basically saddle stitch the loop in . . . plus 4 or 5 stitches on the other side . . . Have never had one come apart on me yet . . . that I know of. May God bless, Dwight
  9. OK . . . I'll bite . . . why does it have to be one piece? May God bless, Dwight
  10. Here you are . . . double layer belt . . . The next step would be to sew them . . . that is what the whole conversation has been about . . . May God bless, Dwight
  11. Add to it . . . Toledo industrial did me right. The servo motor on my 4500 will go so slow that I can move the leather so it goes EXACTLY where I want it . . . which was the one thing I truly loved about my Tippmann Boss. Bob tops it off with a couple spools of thread and a two spool thread holder . . . Had a couple screws come up missing . . . called Bob . . . they were in the mail . . . wicky wicky. May God bless, Dwight
  12. With a double layer belt . . . you have to cut both pieces . . . then cut the stitches . . . so you can slip something between the pieces so you can cut the under side piece . . . and then you cut it off square . . . so it looks dorky the rest of it's adult life . . . plus you will then also have to re stitch each end over top of the place you cut . . . so the threads don't come out. All in all . . . I'm thinking the tongue end has to be faster unless you sew them up to say a 36 . . . and you get a guy coming in who wants that 47 . . . which means you have to hand sew about 61 inches of belt altogether. He would get his belt in the mail. May God bless, Dwight
  13. Well . . . you could stitch the top and bottom up to a certain point . . . in my case if I did it . . . most of my customers are in the 38 inch or bigger category . . . so I would stitch them up to maybe where the next to the end hole . . . and tie them off. Then you only have to stitch the tongue area. If you are careful in how you do it . . . saddle stitching with only one piece of thread . . . your knots would be on the bottom . . . mostly un-noticeable if you are careful . . . Secondary part is . . . that is a very good way to do the tongue . . . you could also impress them with the extra effort you are putting in to their product. But like Lobo said . . . no matter what we do . . . we'll wind up with "extras" in the shop . . . I had to make one for a girl the other day . . . 3 times . . . and her sister ate a couple extra pizzas or something between fitting and delivery . . . hers was not as well fitting as the others. But that is all part of the belt industry . . . Have fun . . . may God bless, Dwight
  14. Now that you ask . . . yes, got a Boss . . . and yes I can do a belt in 30 minutes with it . . . but I'd much rather do it on my Cowboy 4500. If you want to do that . . . pre dye your belts . . . glue em together . . . fix the buckle end ready to go . . . For me . . . I would cut them a 56 inch long belt blank . . . the way I do it . . . that would give me a 47 inch belt blank. My first hole for the buckle is 4 inches in from the end . . . and there are 7 holes following it . . . at 1 inch intervals. If I were going to a fair or something like that using a Boss or Outlaw . . . I'd stitch the first 34 inches of the bottom side of each belt. Tie off the stitches but don't double them. Then when your customer picks his belt . . . all you have to do is cut the end . . . punch the holes . . . finish sewing the bottom . . . make the turn . . . and sew the top side. With my boss . . . I can easily do that in a half hour. And . . . your customer gets to see exactly what his/her belt will look like. AND . . . don't discount the curiosity folks . . . sometimes folks will stand there and watch you . . . just to see how it is done . . . then brag to their peers what they saw. May God bless, Dwight
  15. You can do it if you don't stitch the belt . . . fair hawkers do it all the time. With the stitching . . . take his money . . . tell him to come back in 30 minutes . . . If I go to the fair this fall . . . that is what I will do. May God bless, Dwight
  16. Dwight
    distraction
    Best wishes on your wife and her health . . . Man but do I ever hate slaving over a hot micro wave . . . May God bless, Dwight
  17. Thanks all . . . Now to just figure out what to do . . . sure wish Dixon had not gone out . . . Might just toss my hat in that ring . . . see if I can just make one for myself . . . May God bless, Dwight
  18. Took a while to find it . . .
  19. There was a short video I saw the other day . . . a Brit . . . he made belts . . . and had a rather interesting looking beveling tool. The thing had a wooden handle . . . and about 8 or 10 inches of metal came out from it . . . had a separation almost like antennae . . . and did a beautiful job of rounding the edge of that belt. Just wondering if anyone on here knows where I could pick one up. May God bless, Dwight
  20. Thanks, Double Daddy . . . That's all I'm looking to do . . . May God bless, Dwight
  21. Welcome to the forum . . . good looking work you do. And as stated . . . thank you for your PGR affiliation . . . it's good work. Also . . . for a moment I tried to figure out when I posted this . . . so I came to look at it . . . Turns out there are two of us on here . . . May God bless, Dwight
  22. Don't have a dog . . . but it would go there if I did. Now you want to hear the really scruffy part ??? I made the second one . . . out of the same side of the hide . . . was careful to make sure no defects . . . careful to make that buckle end come from the "back" . . . umm did it look good. Went out the next morning . . . checked it before dying it . . . darned if it didn't have a bad spot on it . . . picked up a small drop of contact cement . . . will not let dye thru . . . looked like garbage. Made a third belt . . . got it all sewed (double stitched all the way around) . . . dyed . . . noticed a small scar on the back side of the belt. Thankfully the final finish will cover that one . . . I am going to be glad to hand this order to it's owner . . . and he and I will laugh about the problems . . . as we are good friends. Thanks everyone for your comments and your support . . . May God bless, Dwight
  23. If you can find an old cobbler's last . . . it'll take all the pounding you want to give it I would think' May God bless, Dwight
  24. Gotcha . . . but for what I'm looking to do on the leather only . . . do these 300 . . . 400 . . . 500 dollar lasers do what I'm looking for??? Some guys use theirs for cutting . . . I'm not really interested in that . . . more just the engraving . . . decorating . . . etc. And . . . how does it do the engraving? I'm thinking it just uses the power of the compressed CO2 . . . would that be how it is done? Thanks, may God bless, Dwight
  25. And what exactly is your problem??? I asked a couple of questions . . . because I did not know the answers. If you have a problem with people asking questions . . . maybe you ought to go somewhere else where people are more like you . . . . and know all the answers all the time. May God bless, Dwight
