Dwight
Everything posted by Dwight
  1. Down thru the years I've accumulated the quart bottles that originally had dye or reducer or something similar. They are all Feibing's bottles, . . . and after I dye a belt or holster or whatever, . . . I just pour it back in the bottle. Bottles are labeled and kept on the shelf in a certain order, . . . so it works out well for me. Hope this helps. May God bless, Dwight
  2. Shoot me that picture, Brian, . . . Add how you would want to be paid, . . . AND, . . . thank you, . . . many times over. May God bless, Dwight
  3. Thanks Big Sioux, . . . I'll give Texas Custom Dies a shout. May God bless, Dwight
  4. I'm looking for someone to make a clicker die for me, . . . just one simple little die I can use to pop out leather key fobs, . . . 1 at a time. The overall pattern looks like the image below, . . . 1 3/8 inches wide, . . . overall length is 5 1/2 inches. Anyone with a reasonably priced source? It cannot be anything expensive, simply because the final product will more or less be for give-away, . . . vs, . . . a profitable venture. Thanks, may God bless, Dwight
  5. Do yourself a favor, . . . this set of DVD's will save you a ton of guessing, . . . and get you started out right. http://www.ebay.com/itm/John-Bianchis-The-Arts-and-Secrets-of-Advanced-Western-Holster-Making-/112511827522?hash=item1a323a3e42:g:w1IAAOSwjTlZhkcJ You will have to do a bit of "remodeling" in order to get what you want for CAS and SASS, . . . but the basic technique and leather workmanship starts there. May God bless, Dwight
  6. Honestly, . . . I do not know, . . . but when I saw that particular one on Ebay, . . . and it being called a Shawnee pattern, . . . I just kind of linked in with it, . . . I assumed, . . . as is done with most things, . . . a person will develop a pattern of things he likes to do, . . . and how he likes to do it, . . . I figured it was probably that way even with the Indians, . . . perhaps they found a blacksmith who would make theirs a certain way, . . . as his trademark, . . . and is became associated with them. Anyway, . . . I liked the looks of it. I'ts really not a lot different from yours, . . . the blade is probably only an inch or so wider, . . . but I like that pattern. May God bless, Dwight
  7. Thanks, Dave, . . . it's close, . . . but the Shawnee pattern had a slightly wider blade, . . . that's the one I'm hoping to find. One was on Ebay a few months back, . . . and I got outbid on it. May God bless, Dwight
  8. Hey, Dave, . . . can you show us a pic of the tomahawk? Reason I ask, . . . I'm looking for a certain pattern, . . . this looks like maybe the right one, . . . Thanks, may God bless, Dwight
  9. I cannot find the picture right now, . . . but I made several burnishers that I use with my Dremel. I took a 1/2 inch dowel rod, . . . drilled a hole in the end of it in the center, . . . forced a finish nail in the hole, . . . cut the head off the nail, . . . put it in the Dremel, . . . took a file or two and shaped the burnisher the way I wanted it. I would not be without mine, . . . May God bless, Dwight
  10. It's a toss-up to a large degree. Because I do belts, . . . and have been known to do a 53 inch Western belt that was 3 inches too short when he came to pick it up, . . . I usually buy the whole side. The price for me works out about the same, . . . and I get belt material. May God bless, Dwight
  11. OK, . . . now we can do something. I make a shoulder holster that is worn so it points the muzzle down, . . . and is a re-work of an older design. It, I think, would be perfect for this application. The next problem will be getting the pattern to you. If you want, . . . send me a private message, . . . use the little envelope up in the top right hand corner, . . . and I'll see if I can't make a workable copy for you and mail it to you. The shoulder straps will simply go from the front of one to the rear of the other, . . . and the whole thing will have belt clips, . . . one on each side, . . . as does the one in the picture. It does not have the "H" harness in the back, . . . but rather a simple "X" where the two shoulder straps cross, . . . Let me know if you are interested. May God bless, Dwight
  12. Exactly where on the harness do you want to carry the radios? Front, . . . where your shirt pockets are? Under each arm? Behind your back? How big are they? Lots of information needed to be able to help you. May God bless, Dwight
  13. (continued from above)....... Next time you are there, . . . his customers will give your product a better look, . . . they bought once for price, . . . and now that it is probably broken, . . . or otherwise almost unuseable, . . . they will be more demanding. Always take the high road, . . . be the gentleman, . . . focus on the positive. It pays great dividends. May God bless, Dwight
  14. I've done several shows in the past, . . . and usually only do it when I'm bored. I'll make up a few belts, . . . typical holsters I sell, . . . and throw in a few "unique" pieces just for kicks and giggles. I've actually sold as many of the "unique" pieces as I have the regular stuff, . . . and belts are simply for show. The belts always seem to be the wrong size, or color for that particular person. But I have gotten some good orders, . . . and some good exposure, . . . which never hurts. Make sure as stated above, . . . you know YOUR product, . . . and don't bad mouth the other guy that's cutting his leather with a chain saw, . . . using a baking oven to melt his kydex, . . . and fastening em with aluminum washers. Next time you are there, . . . his cu
  15. There are two "rules of thumb" here with your questions. The flatter the back is, generally the more comfortable the holster is. This is more noticeable on skinny or bony people, . . . those with "ample" padding don't seem to be quite as affected by it. Personally, . . . at 6'1 and 180, . . . I like it REAL flat. The more the gun moves into the front panel and the rear panel, . . . the more retention that can be molded into the holster. AND the retention will be longer lasting. You just have to make up your mind about how much comfort is required, . . . vs . . . how much retention is required. The more you go for one, . . . the less you get of the other. Generally when I do a flat back pancake for a customer, . . . I put a thumb break on it also, . . . if they want to disable the thumb break some day down the road, . . . that is their decision, . . . but at least when it leaves my shop, . . . the retention factor is built into the holster. May God bless, Dwight
  16. I've used a bunch of stuff, . . . Weldwood puts two pieces of leather together so that it becomes one piece. You CAN take it back apart, . . . but you will rip fibers from both pieces, . . . inherently "ripping" the piece apart. Have never had any issue with it except that if I'm doing a number of pieces, . . . there needs to be some consideration fro ventilation, . . . what I mostly do is just get it on the pieces, . . . and leave the shop, . . . go do something else somewhere else that I've been putting off. It is also more economical than Barge in my area. May God bless, Dwight
  17. Biggest disadvantage is over time the single layer wings will get floppy ane sloppy, . . . not hold the gun up like it should. AND, . . . there really is no ADVANTAGE to it other than having saved a few square inches of leather, . . . that would probably not be used anyway, . . . just because of the way it is cut. I would not make one like that for myself, . . . and a REALLY would not make one for a customer. May God bless, Dwight
  18. Thanks, Cowboy, . . . like I said earlier, . . . not sure how many times I may ever use it, . . . but I'm sure glad I got it. I will definitely do the pattern just for practice though. May God bless, Dwight
  19. Vice grips and Cheerios there bikermutt07, . . . , . . . actually I have a time with mine as well, . . . but when it is done, . . . it is so, so, so much easier than trying to thin down a piece of leather with hand tools. I'm too old to spend the money that would get me a machine that would do an 8 or 10 inch piece, . . . cannot justify it, . . . but it sure would be nice to have one. Put the leather in, push the button, . . . catch it so it don't hit the floor and get dirty, . . . yep, I'd love that. May God bless, Dwight
  20. Thanks, Gary, . . . we all learned something today..............
  21. If I dye it, . . . I dip it, . . . don't have any questions then about the coverage, . . . go over it then (or before) with a coat of neatsfoot oil, . . . use only Feibings Oil dye. Basically no problems with my process. The dip dye process takes more dye, . . . but when you are done, . . . you are done. Ya don't have to question and don't have to worry about scraping it and the color scraping off. May God bless, Dwight
  22. I waited for Tandy to do their Black Friday special, . . . got a small one for $199, . . . no way I could have engineered and manufactured something that works as well as that little jewel. Be warned up front though, . . . while it is "sharp" from the factory, . . . the blade needs a good 100 stroke dressing from a home made "strop on a board". Oh, . . . and that is 100 strokes on the top, . . . AND, . . . 100 strokes on the bottom, . . . + / -, . . . to get that razor edge that lets you cut really well. While for the most part, it is only used for belt blanks, . . . I have cleaned up holster parts with it, . . . Watch a couple of Youtubes on how to sharpen the thing, . . . it is a good investment IMHO. May God bless, Dwight
  23. I really don't like most of Tandy's craftaids, . . . but that is one I would love to have in my drawer. I would use it at least once a year I am sure. You did an excellent job on that CowboyCurry. May God bless, Dwight
  24. Do a search on here for a member named Katsass, . . . he was THE progenitor for M&G, . . . and if I recall correctly, . . . his process was equal parts of M&G and tap water. He did the "dunk and shake" routine, . . . and I believe at times it was multiple coats, . . . although I'm not certain on that. I'm happy with Resolene, . . . and other finishes, . . . so I don't use it myself. May God bless, Dwight
  25. Would I also be wrong in guessing that this was a post from something like Etsy or Pinterest, . . . and that the poster was most likely a young female? It has all the look and feel of something you would see on there, . . . not a serious attempt as a "holster". May God bless, Dwight
