CowboyBob
Contributing Member-
Everything posted by CowboyBob
Yes,it should handle that thickness max thread size is #92 on it.You should take some samples of what you want to sew with you & try it b4 you buy it.We stock some parts,needles & thread for it.You might want to do a search on them,it's on the upper right hand corner of this page.They also have an issue w/marking the top of the leather since the bottom of the feet have teeth on them to grip the leather to feed it .
We have the plates & etc listed here;http://www.tolindsewmach.com/cb-acc-pack.html
When you stop sewing have the take-up lever all the way up.This is the chrome part you thread through that goes up & down while your sewing.That will put the hook in a position where that thread is released.
You need to hold on to the needle thread for the first 3 stitches when you start sewing,also looping underneath is almost always either top tension too loose or threaded incorrectly.
How's it working? Usually I tell people when it loops underneath to double check the threading or tighten the top tension alittle.Looping is almost always loose upper thread tension.
You can also use a #20 needle w#92 thread & would need alittle less foot pressure to hold it down.The larger needles create more friction.
- 6 replies
- 5oz
- english bridle
(and 1 more)
I checked with one supplier & it shows it's discontinued.
I checked that part# out w/my supplier & they say Brother has discontinued it,so maybe someone has some old stock?
We stock needles for the 45K, but your size # are way off the smallest you can get is a #21 for cloth & #22 for leather.
Welcome,it's nice to see another leatherworker from Ohio.
Techsew 2600 Pro - Is there a similar machine in the UK?
CowboyBob replied to Emmers's topic in Leather Machinery
Yes,Hightex has all the models. -
These Chromebooks are terrible,luckily I have a better puter @ work. Go here & scroll down for Singer.http://www.supsew.com/catalogs-reference-materials/
file:///home/chronos/u-fb0e68cf593b2bc6570aebf31e13a1dcc163c845/Downloads/Singer%20138W101.pdf I guess you'll have to cut & paste.
A Pfaff 335 is the same. -
Adler 205-370 kicking out of gear
CowboyBob replied to ScarlettStarlett's topic in Leather Sewing Machines
Yes,we get calls from people every once in a while about the lever moving on them & have to explain it.Glad to hear it helped you. -
Hydraulic shop press as a clicker press for cutting dies
CowboyBob replied to Anubis78's topic in Leather Machinery
Clickers have a short travel on the ram so you can set the depth it cuts.If you go too deep you'll cut up your board.So if you use a hydraulic press you'll need an adjustable stop maybe 4 (one on each corner) but they can be made to work.- 36 replies
- leather cutting die
- clicker press
- (and 9 more)
Yes,Greg ,Thanks now that you mentioned it I have seen the model 360 on these before.
This one looks like a bottom & top feet type of walking foot & the feed dogs will making the bottomside,the 226R has a walking foot needlefeed that will leave a lot less marking on the bottom of the leather.
You can turn it down to the lowest setting,loosen the 2-screws on the collar, turn the pointer to mittel (making sure the shaft doesn't turn), tighten screws & turn down more.
It's a model 226R,setting the way it is you can't sew on it so it might need some adjustment or parts.You will need a table,motor,thread stand, bobbin winder & light,& a drip pan.It will add up w/shpg alittle under $300.00,unless you can search around & find a used one.
This is a very easy adjustment.You need a 10mm wrench & a 2.5 mm allen wrench,take the 10mm & loosen the nut in the pic,take the 2.5 m & put inside the nut on the allen bolt & turn it alittle clockwise & check the tightness of the stitch length handle & when you get it where it doesn't move up& down by itself tighten the 10mm.
