chuck123wapati
CFM
Everything posted by chuck123wapati
  1. i would fix the haft not monkey with the blade. you can run a small drill bit if there is a hole in the center or sand or file the slot larger or both. It shouldn't take much. I wish i had experiece to help you with those but i make my own.
  2. the holster and tooling looks pretty good to me for a first. The chocolate looks black in the pics.
  3. thats cool you could use the correct threads and spi for each needle division also as a way to remember.
  4. Welcome!
  5. That was a great way to repurpose and a great unique look, definatly one of a kind holsters.
  6. any hints where that one came from?
  7. you have the knack for sure!
  8. thats some cool history wonder what size track it is and the width between? that would tell you the age. I live in rr country also and use two anvils i have made from track. As well the spikes may be high enough carbon to make knives and tomahawks from they are quite a novelty. If i remember right the high carbon spikes had an H stamped on them. I have a spike puller i found years ago lol. looks kind of like a giant claw hammer end you can pound under it with a four /five foot handle.
  9. your welcome Freds way obviously works well also either glue it or stretch it but no need for both. lol Would love to see your work when done please post.
  10. Your welcome hope to see your work
  11. there is no bad popsicle flavor imo lol I'm partial to those orange cream things and they go great with a semi dry rose.
  12. but i use a wine cork lol.
  13. Amen!!! Amen!!!
  14. i doubt that but its your story Now back on topic please so the person asking the question doesn't think all we do is agrue about stupid shit.
  15. yup they need to be razor sharp another method that i use is to glue a piece of 1000 grit sandpaper to a popcicle stick then hold the awl still and flat and polish the edge similar to using a file on a piece of steel. then a piece odf 2000 grit. I find it much easier to keep the shape and angles of the awl that way. Good luck on whatever method you choose.
  16. chuck123wapati
    Krampus
    creepy cool !!
  17. i'm sure you will figure it out. good luck!
  18. awesome tooling there, i like the absract pattern very unique.
  19. great job!!! i make some of my own tools also, i would suggest useing stainless bolts as the steel can sometimes stain the leather black. regular small or jewlers files will cut stainless bolts just fine if you want to cross hatch and such. These are easy to make also lifters, modeling tool and stylus made with stainless all thread and brass nuts, i used leather washers for handles. i chuck them up in a drill and turn them against my grinding belt to get the nice taper.
  20. Do it how ever you want to i'm not going to argue the point any longer if you think adding a couple steps in the process is faster then go ahead and do it that way most beginers do until they get good at sewing. I did i still do but the fact reamains taking less steps is always going to be faster. As i said to tug and you probably read but decided to re state any way. i used the wrong word in enlage, you have to re open them that is what a diamond chisel does it cuts a slit but the shape opens a hole in the center after a few minutes it closes and has to be reopened either with the needles or an awl of some sort. thats what diamond awls and chisels do thats why the hole closes after you sew it up thats why you hammer it a bit to set the thread and close the holes. i also wrote this to tug. Most of the miscommunication comes from us because we all make diferent products with diferents leathers and diferent personal opinions. Beating a chisel through three layers of 10 oz is not the same as running a chisel around the edge of a 2mm wallet and takes alot longer to do than just useing an awl and neither is sewing the two the same by any means. I can easily sew a wallet without re-opening the holes not so much with a holster.
  21. yes finish with an awl.
  22. the dif between a car and a sewing machine. every house still has a couple or three cars so there is still a mechanic in every town maybe two or three. sewing machines have gone away as a houshold item so the service and repair shops have too. some more of my post. "I had the great fortune in my working career to buy equipment for a number of trades including textiles it was always in our purchasing contracts to provide initial setup and training but on our part we had to know what we were going to be making start to finish, we had few problems but most all the machines no matter the trade had to be setup or fine tuned for what we wanted. I don't see how any company could provide this service to the private citizen without it costing a lot of money that the private citizen or the industry simply doesn't have." and With that said if you cant get reliable training and service and have to be self taught buying a brand new machine isn't cost effective imo.
  23. wing dividers are used for more things than just creasing. Marking, measuring and creasing.
