Everything posted by chuck123wapati
true words there friend the forest here has so much deadfall due to the pine beetle infestation a couple decade ago that its just a matter of time, then adding to that the development of wilderness areas has stalled any vehicle access for fighting fire crews. Last year we had one and the fire crews just had to watch it burn, they had no safe way to get in or out. The deadfall is sometimes 6 to 8 feet high with downed trees and impossible to navigate. Good luck and god bless to the folks down under!!!!!!!!!!!!!!
Great info there! Thanks
Pretty good video showing the proper sewing techniques but I'm still not buying one lol, the takeaway for me = hole size affects the looks of the stitch dramatically , finishing the stitch work with final seating of the stitch via hammer is important to a good looking stitch. I agree I think with a heavier thread the slant would be more natural looking on both sides, the side with the bigger holes was to big for the thread size while the other was marginal. Is there a rule of thumb for thread size compared to hole size?
LOL its beautiful!! and agree it would take some time indeed no matter how you did it. Your right I do tend to talk to much, its ok to tell me to shut up I get off track easily.
There is a reason they believe that, the importance is what makes the stitch, the diamond cut that doesn't detract from the leathers strength or integrity, the angle of the cut, diamond shape, provides that when the stitch is pulled it seals the hole and provides the tension that keeps the lock stitch locked and the thread itself sewn correctly provides the lock stitch that doesn't fail. Its a micro-system if you will developed over hundreds of years by folks that used leather on a daily basis. Some times we fail to realize that there is much more to such a simple thing as a stitch and why it matters. On a handbag no biggie on the reins of a horse well maybe a biggie ifn he goes off. I an not an expert at stitching or leather work by any means but always strive to learn and understand and am very guilty of over studying the process but for me I have the urge to know why something is the way it is and why it done that way.
yup it depends if your stitches are needed for looks or work! Punch 4 I/8 th inch holes in a one inch strap and you have a I/2 inch strap. cut 4 slots with a chisel and you still have a one inch strap. To each his own. Remember those plastic bags are one use bag, and no they don't work well, is that what you make leather products for? Don't get me wrong I don't care how anyone else does it and if dumbing it down makes dieselpunk a profit then good for him, doesn't mean its the tried and true way to do it all or the correct way, it is the easiest way and why people go for it. Your bag is beautiful stitching and all! I was just saying there is a reason why the methods used for stitching came to be, a lock stich is more than just the thread it is the combination of the leather and the thread and how they work together. There is also a reason why holes came to be, ease of sewing and or used for decorative stitching etc. I use both but depending on the job.
Knives and Sheaths
chuck123wapati replied to AlexOstacchini's topic in Gun Holsters, Rifle Slings and Knife Sheathes
beautiful work! -
Thats a great looking bag
Traditional? How about time proven, like in thousands of years of actual testing! The leather helps hold the lockstitch in place and is a much stronger stitch because of that also that the loss of the leather weakens the leather. Your example is awesome, try and read our nations constitution without knowing cursive then ask yourself if your children need the ability to understand it themselves or have it read to them by an "expert".
Hey Frodo were you able to get the 3 second stitch time?
I think the chisels produce a parallelogram type cut that creates or emphasizes the zigzag pattern of the stitching, these in conjunction with producing the same stitch every time that makes the stitch look clean and even, when I use round holes it becomes much more important that all stitching is done exactly the same as well, the force used in setting the stitches must be closer or the pattern looks messy. I know I have fought this as well and when I really started making better looking stitches is when I got got the right needles so I could use the right chisels without breaking the needles or having to pull them through with pliers lol. I will add when you pull a punched hole to tighten the stitch it stretches out of shape so the stitching can be shorter or longer depending on the amount of force used in each stitch. When you pull a chisel cut with the thread it closes making it appear cleaner as you can see in Tugaduds post compared to yours in yours you see the shadow and shape of the hole which detracts from the appearance of the work IMO.
Always try to get a bit of nfo soaked into dry straps like these or they may crack when you try to undo them from the buckle. Apply let soak in a day or so to get some moisture back into the leather.
Here is my project for the next few days, its an old swiss army rucksack I bought a looong time ago and have used and abused it. Its time to restore the leather and clean it up for another round of livin in Wyoming. You know I think I paid about 20 bucks for this and now they are "in" and worth much more to some folks, I still have all the straps but the leather is dried out and if you look closely the harness has been repaired at some point but I like the repair so will just attempt to restore the leather and fix a few stitches here and there. I have already saddle soaped the bottom and a few of the straps and the leather seems to be coming out of it pretty well.
I-pad case
chuck123wapati replied to Silverd's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
great looking indeed. -
What are these tools used for?
chuck123wapati replied to TargetRockLeather's topic in Leather History
https://www.fdjtool.com/53189-bezel-setting-punch-set-18pcs-plus-handle.html -
Awesome and its a beautiful thing to bring back to life.
could be needle thread combo. ice been using my 401 for some light leather sewing and it was skipping due to wrong needles, when I got the leather needles and right thread it works great now.
Info on lace making and braiding from start to finish
chuck123wapati replied to DirtBagRobot's topic in Braiding
https://archive.org/details/Encyclopedia_Of_Rawhide_And_Leather_Braiding/page/n1 Here is the link to the free ebook by Bruce Grant -
great find at a great price!
give it to your 18 year old son to wear for about two months.
Make a wooden frame like they used for stretching beaver and then hang it on your wall, its mighty cool work! https://www.bing.com/images/search?view=detailV2&id=78A7426524364F7ED0EF390B927F99FEF2E54B9D&thid=OIP.v-3SPzZE0ZxPokXU3wItuwAAAA&mediaurl=https%3A%2F%2Fauctionimages.s3.amazonaws.com%2F63030%2F50792%2F43080922.jpg&exph=480&expw=391&q=stretched+beaver+pelt&selectedindex=22&ajaxhist=0&vt=0&eim=0,1,2,6
Dears Santa is it to late to change my mind? LOL yea for sure I'm going to be watching this guy he knows his stuff and is exactly what I need to know. I've done most of the mechanical issues but now i'm into the body work and the interior this is going to be a great help thanks for the link. After doing some testing I think my old 401a can handle light upholstery work if I go easy on her.
I gotta keep this There's a 75 mgb in my yard begging for new seat covers, and door panels, and , and , and, ……. very cool that guy has done a few seats in his time.
Which one? Definition of buffalo (Entry 1 of 3) 1 : any of several wild bovids: such as a : water buffalo b : cape buffalo c(1) : any of a genus (Bison) of bovids especially : a large shaggy-maned North American bovid (B. bison) that has short horns and heavy forequarters with a large muscular hump and that was formerly abundant on the central and western plains
