Everything posted by chuck123wapati
that's is a great tip to share thanks!!
That is an interesting way indeed to make that clamp piece, what wood are you using? I would love to try steaming and bending wood maybe this summer some time i will take a crack at a new stitching pony. Mine is very similar to yours in shape and function but just made from scrap wood.
First off have you tried the search function? I have seen quite a few saps on the forum. If I were to make one I would use heavier leather, hand sew or lace and not turn it inside out. I've never made a sap but most I have seen are flatter so you can put them in a pocket or hide them easier. Some even have spring steel sewn inside to give it some snap. You may even consider lacing instead of sewing. I haven't seen a pattern for a four piece sap you will probably have to think that one up yourself. This is a ball bag for lead balls I made 6/7 oz. leather to show you how much you could wet mold a simple two piece sap. I used bbs and just mashed them in with a dowel rod to get the leather wet formed. it is a three inch circle and formed to about 1 1//2" thick at the center, plenty for a sap.
yea dress it as any outdoor leather product would be or if the weather is really bade try one of these.https://www.bootbarn.com/boot-barn-hat-protector/2000213392.html?msclkid=fc136922fdd310ed4b160f0bf352467a&utm_campaign=Shopping&utm_content=hats&utm_medium=cpc&utm_source=bing&utm_term=4583176819036973
yea that's over the top!!!
i agree those are nice indeed.
6 inch hollow ground Splitter blades need sharpening
chuck123wapati replied to Doc Reaper's topic in Sharpen it!
you will just have to start with a courser stone. Not the coarsest for that small Knick but not the finest either, take your time. I sharpen a lot during my off time setting on my butt when time doesn't mean much.- 11 replies
- splitter blades
- 6 inch splitter
- (and 3 more)
i wanna see some of this. I just spent 30 bucks in leather and six hours of life to make a pair of three dollar mocs lol.
we all suffer that, when ya don't know ya gotta ask. That's why we are all here. Reading leather and creating work arounds is a skill born through experience more than anything else.
No piece of leather is without flaws. It comes from a critter that lives in the outdoors. Consequently there's a lot of waste sometimes if your project needs that type of perfection. Obviously more so in economy grade leathers. Buying leather first hand is my suggestion for decreasing those types of problems no matter the grade.
you like old books buy this one it will answer most of the questions you ask. https://www.amazon.com/Leathercraft-Tools-Al-Stohlman/dp/1892214903 yw good luck!
xactly that's why the awl rules in this case over trying to figure punch holes its a no brainer with an awl. As you can see its just a matter of marking the main body holes, a guideline in the bottom as dikman said then pushing the awl through towards the dead center of the bottom.
yes that would work well i think.
i watched the video and you can sew that up in minutes with an awl with nothing but a stitch marker around the outside piece. Even the video maker is making this way to hard. Make a form so you don't have to hold the thing and sew. I just had a thought for an accurate coozie form fill a can with plaster of paris or maybe even that expanding crack filler foam crap and insert a couple of pins, dowels or some such that you can clamp in your stitching pony. simply slide the sewn outer piece over it then you can easily glue the bottom in and start sewing. Step away from your calculator very slowly and have a beer instead. remember people made this stuff before rulers were even invented.
I fought this problem to the death on moccasin toes last month. you cant just glue up and sew those with an awl at least I couldn't figure out how to. yup you can mark the holes on the outside piece then draw the same diagram to find the inner hole spacing measure it and you have the answer pretty close. On 2 mil leather it would be a very small difference on a miter joint type. That's why I didn't draw the thing to actual proportions, probably should have.
You have it made then, mine work twice as hard as my gson lol, you could get some things done with five.
- 11 replies
- splitter blades
- 6 inch splitter
- (and 3 more)
lol must have been one snag to much for the guy.
From "Leathercraft Tools" By Al Stohlman in other areas its mentioned that burnishing makes the leather brown while slicking doesnt.
excellent work!! and now brings up the question how are you connecting the two pieces?? . Butted up together like with thicker leathers , formed inside like Frodos, formed opposite of Frodos or some other method ? maybe a pic of what you are trying to do would help.
It works the same if you have a form to sew on. If the leather is that thin then the difference in circumference isn't very much between the two pieces but your making it way to hard for no need. Another way, get a compass and draw a circle the same size as the bottom circumference. Draw a second circle the size of the main body circumference. mark your intended holes on the inner circle then with a ruler mark lines from the center of the circle through your intended stitching pattern to the outer circle. this will give you the measurement you want. easily and quickly. The problem with finding that "principle" is that the distance from the edge of the leather to the hole is part of the equation as well as the thickness of the leather so you have more than one variable to the equation. you will see and understand this problem better when you make the above template.
i should turn some wood and makes some koozie forms for folks, i just grabbed a tree limb and cut off a piece one day for a sewing form but a nice turned one the right size would be better.
