Everything posted by TomE
Good tips! I will look into the speed reducer. Here's a link to the video.
Welcome! I make bridles as well, and the Antares bridles are a favorite. Your friend @FrenchMich is friends with sellier Jean-Luc Parisot whose work I have long admired. Not sure if Jean-Luc is doing leatherwork these days but his Instagram account has pictures of many beautiful items.
Happy Easter, @chuck123wapati.
Cobra class 4 foot pedal: Thread Release
TomE replied to DieselTech's topic in Leather Sewing Machines
Probably an easy fix. I have assembled the release incorrectly before, when I had the cover plate off to adjust the walking foot mechanism. -
That pointy tip should insert between the tension discs when engaged. You can remove the beige cover plate (2 screws) to reassemble the tension release lever. I would first try just repositioning the lever and reassembling. If it is still misaligned then I would consider that either the tip is bent or the tension disc assembly is missing a spacer that holds it out away from the beige cover plate, more aligned with the lever tip. The first 2 pictures are with the tension release engaged. The third picture is the lever disengaged and the tension discs closed together. -
I think depends on your starting point and process for belts. I have a 4x8 ft work bench in the middle of my space with machines around the outside. I am rolling out sides on the bench to cut straps. I use hand tools on the bench for cutting, edging, creasing, skiving, dyeing, burnishing, and assembling. I like being able to spread out my work.
The link didn't work so I couldn't see the defect, but it sounds like lifting of the grain. There is a natural junction between the grain and the underlying flesh layer (corium) that is rather weak and open in structure. It is vunerable to breaking and more so in low quality leather, a defect referred to as "looseness." The "break" of the leather refers to the ripples created when the grain is sharply flexed (concavity). Good quality leather makes fine ripples (fine break) and low quality leather makes coarse ripples with more separation of grain and flesh layers. Blistering caused by uneven wetting of the leather is the same phenomenon. If you're interested in the structure and chemistry of leather the book "Tanning Chemistry. The Science of Leather" by Covington and Wise is a very detailed (685 pp) reference.
Where does this piece go? Cobra Class 4
That's a thread guide and it goes where you put it, I think. My Class 4 didn't have one and it is not mentioned in the LMC instructions for threading. My Class 26 has this guide and you can route the thread straight through one hole, or make a serpentine pattern through additional holes to add tension to the thread. My Class 4 has been happily running for 3 years without this thread guide. -
I did a Google search "site:leatherworker.net stitching pony" and found quite a few designs.
How to fix this mess? Bicycle seat cover.
TomE replied to panchoskywalker's topic in How Do I Do That?
I suggest you cover the seat with a smooth grained leather or vinyl. The suede will create friction and it won't wear well. My first job (51 yrs ago) was working in a bicycle shop assembling bikes. The top bikes had Brooks saddles that are still made today. -
I think gluing and sewing all the layers would do the trick for constructing it flat than curving into a circle. I'd consider sewing the strap with the dee rings to the wider strap before sewing the pad on the back, unless you're OK with the additional stitching going through the padded layer. Could add some wedge shaped welts on either side of the dee rings. JH Leather videos show this method for the dee on a padded dog collar. Since you're hand sewing with an awl you'll be able to jump over each dee, and possibly overstitch the dee as shown in her videos. That's how I've been fixing the dee to the buckle turn of a dog collar.
- 21 replies
- foam padding for leather
- layer
(and 2 more)
No room for two needles in stitching holes (pics)
TomE replied to Dannyman's topic in Sewing Leather
I didn't watch the videos, so this might be redundant. To avoid piercing the thread when pushing the second needle through pull the first thread backwards as you advance the second needle then pull up the stitch. This requires clamping the work in a pony/horse/clam so you have both hands free to manage the needles. In the perfect world you would use a sewing awl instead of chisels. Pliers are sometimes needed especially when overstitching at the beginning/end of a stitch line. I wax the thread with beeswax, or a mixture of pine resin-beeswax, which makes my fingers slightly tacky and improves grip on the needles. Stohlman's book on hand sewing covers basic technique and some construction methods. -
I think at the end of the day if the collar fits then you've made the right choice. How tight/loose it fits is a matter of the owner's choice (in my experience for dogs and horses) so this is not an exacting process. I typically measure a collar/bridle that fits to the owner's satisfaction and make mine the same size (plus padding allowance if needed). The calculated padding allowances are small and I only recently did the calculation out of curiosity. I haven't had a problem making dog collars and nosebands as flat straps then wrapping them in a circle. The noseband above is made from 2 layers of 9 oz leather and I've made dog collars in a similar manner. They close in a circle without a problem. I sometimes bend the buckle turn with my fingers to match the curvature (3 layers thick and skived on the end). I am using Hermann Oak regular veg tan or bridle leather. I typically apply a light coat of neatsfoot oil followed by conditioner at the end of the project. Perhaps you could show us pictures of a collar that isn't shaping up.
- 21 replies
- layer
(and 2 more)
Looks like a winner! That is an interesting girth. Guess you have materials to make all your relatives suspenders for Christmas.
That's some nice craftsmanship, Jonas. Not sure if this long dee ring would be large enough. https://www.weaverleathersupply.com/products/571-long-dee
The stretch of leather is of interest for saddlery and harness making - how much the length changes with use. I'd be interested in comparing different tannages for stretch under a controlled load. Bridle, harness, and regular veg tanned of similar weight. Also there is some debate about how much the grain contributes to the strength of a strap versus an equal thickness of a flesh side split. How much leather would you need for testing?
I knocked my machine out of time when I was learning to sew and this video by @Uwe got me back on track. He also has a video on adjusting the walking foot that is very well done.
I quit leathercraft ~50 yrs ago to work on cars (I discovered that girls liked cars). This time around I'd rather work with leather than fuss with machines. Happy to pay a dealer to sort out the machines. Anything other than thread tension and shuttle timing is above my pay grade.
For my one experience with sewing a zipper, my double stick tape did not hold so I used a light coating of Barge cement. I was told that this basting tape works well for zippers and will try it next time. https://www.wawak.com/garment-construction/tapes/basting/wawak-hyperstik-super-strong-double-sided-vinylleather-basting-tape-clear/#sku=tpe14
Springfield Leather Co has been a good source for me of HO and other leathers. When I go to the store they will open up rolls of HO hides for me to choose from, and most of them look good. When I call in an order I tell them what is important to me and they have delivered, mostly sides of HO bridle leather.
Thanks. I think I should have added more attachment points for a pack because my niece won't be wearing this from her belt. I have avoided leather tooling since returning to the craft, although my Tandy tools from the 1970s are sitting in my shop. Was never very good at it and decided to instead focus on cutting and sewing for a while. This sheath is made from the leftover belly of a bridle side. The machete and sheath only recently arrived at my niece's house, a full month after mailing the package. The Saint Louis mail sorting facility swallowed the package for a few weeks. Then there was a problem with the zip code at the destination and it took several weeks to reroute the package to a neighboring post office. All's well that ends well.
Help with getting a nice frayed belt edge with fibers
TomE replied to blackandblue50's topic in How Do I Do That?
Bridle leather has prominent fibers and might lend itself to this look. I assume this is related to stuffing the leather with fats and waxes. Rough edges are likely to wear smooth(er) so it might be difficult to preserve the look. -
Welcome! @Northmount provided a tip to use Google's more advanced search engine to search for topics on this site. In the Google search bar type "site:leatherworker.net YOUR SEARCH TERMS HERE" I am finding useful/older threads that I hadn't seen before.
I am probably the only one who finds this interesting, but look at how he applies dye. I thought his method produced a pretty shading. I sometimes dye the back of bridle leather after splitting off the pasted/colored back. This looks like a handy way to avoid saturation/bleed through to the grain without the expense and maintenance of a spray gun.
This author states "Tokonole's first ingredient is white glue." https://www.fineleatherworking.com/blog/gum-tragacanth-leather/ I haven't purchased Tokonole so I don't know where he got this information. There have been numerous discussions here about using glue-dye mixtures to finish edges as an all-in-one treatment. My tendency would be to apply the dye, wait a few minutes for it to soak in and even out, then apply the bunishing compound and smooth the surface with a glass slicker. I would be concerned that burnishing will obscure the brand.
