Leescustomleather
Everything posted by Leescustomleather
  1. Springfield leather has Fenice diamond waterstain in Fuchsia, all of the Fenice colors are vibrant if you mix some white with the Fuchsia you will have bright pink I have been using Fenice waterstains for about a year and I no longer buy Feibings. For the white I have thinned down the angelus paint and they mix well because they are both waterbased.
  2. This looks like a great resource, thank you
  3. Nice work and nice photography.
  4. This is true, as an alternative you can skive around the hole for the stud on the inside, then case the leather at the hole before screwing down the stud, and add a little super glue to the threads so it won't come loose. Also, if the screw is brass, it won't harm a steel blade.
  5. You are doing it backwards apply the Resoline to seal the leather after dyeing then the paste after the resoline dries to get the color down into the tooling then wipe away the excess paste. after it t dries put on a final coat of resoline to seal. The first coat of Resoline seals the leather so the paste only dyes the tooling indentations. If a product has been working for thousands of folks for many years, then chances are it is not the product that is at fault.
  6. Steel Horse Leather.com
  7. Nice work I really love that border, and the way you fade the veins in the oak leaves, nice touch!
  8. If you stick packing tape on the back of the leather before tooling and burnish it down firmly it will keep the leather from stretching out of shape. It will raise the nap on the leather when you remove the tape, but you can slick that back down with your favorite leather finish.
  9. Very nice, is the piece in the back elastic? or nylon webbing? Also, would you mind telling me what those spring-loaded hooks are called? I want to make some for myself. That is a LOT of stitching.
  10. I no longer wonder how you are so darn good at leather work- I frequently say, no lesson is more valuable than having to redo an almost complete project. You do phenomenal work, thanks for sharing.
  11. Both of those are quite nice, The only changes I might make is to not use white thread because with use it starts to look a little dingey and I would also use oval holes for the buckle tang. These things are very minor compared to the quality of your work, I wish I could do as good.
  12. Check out Prince Armory on You tube, I consider the best and great tutorials and patterns if you want
  13. I am not sure if this is what you are looking for, but a brush modified to only have just a few bristles with a thinned down paint might give the effect you want, kind of like shading but with color.
  14. I understand your problem, What I did was thinned the paint with water, 3 parts water and one part paint. Then added several coats to get the desired look.
  15. No photos ... No sale, I may be wrong but if they refused to give me photos I would just walk away
  16. Good Idea! Please let me know how that works out!
  17. It looks like you do very nice work, but the photos taken at an angle make it hard for the camera to focus on the whole image, or the proportions, like a photo of a tree taken from under the tree. I would love to have a clearer view.
  18. I was only offering his video as a method that helped me and might help others. Perhaps posting a video of your method would help even more.
  19. Yeah, seems like that would have a similar effect, The only difference would be not having your hand near the cutting edge with Sam Andrews method, cutting leather is tough and anything that makes it easier or more accurate helps
  20. It takes a little practice like anything, but works very well, especially for tight corners and radii. Also no going back over the same cut and doesn't require as much hand strength.
  21. There is a youtube channel called Hank strange and a video called "Carjacker holster" The man that does the leatherwork is named Andrews and he has a unique method to cut thick leather easily, making tight corners cleanly and accurately. I have never seen this done elsewhere and this is the method I use all the time now
  22. And if it wasn't already confusing enough Springfield leather has a great selection of buckles at good prices and the quality is very good.
  23. The stamps don't seem to index with each other, so you end up with inconsistent spacing that results in disruptions in the pattern. Good starting point, they just need some refinement. I hope you stick with it, you show promise of great things to come.
  24. I have been using acetone for years with good results. It will even work after the glue is set for cleanup.
