Littlef
Everything posted by Littlef
  1. along those same lines, Another option: I don't have a bench grinder or a buffer, but I do have a handheld dremel tool, which has grinding wheels and buffing pads. Its sufficient for the "little" bit of occasional buffing and grinding I need to do.
  2. While its hanging, I might try to lightly mist it with water using one of those fine-mist - continuous spray bottles. the little bit of water could help give it some elasticity, and the bit of added weight from the water might help pull and stretch to flatten some of the folds.
  3. Nice, That's a good lookin arm guard!
  4. Littlef
    Shoeing Apron
    Looks Good!!
  5. Nice looking neck holster. and a neat little blacksmithed blade
  6. I got nothing. That'd odd. I have a holster that I made with a usmc black exterior with an oxblood liner. Its vivid deep red. Normally I just use oxblood to mix with browns to bring out a reddish hue.
  7. paint and dye won't mix. Oxblood makes a very dark - very pretty red at full strength. I used the search parameters on this forum, and found a prior thread: it said, "You can also make pink by diluting red about 10:1 with denatured alcohol. 90% Isopropyl will work just as well." I'm sure It'll take a bit of experimentation to get the shade you are looking for.
  8. Thank you sir. Mother necessity at work. shooting out on the plains with flat land, and no shade. I just can't see the laser in mid day. Problem solved.
  9. Thanks Dwight. Thats not a bad idea. I might have to think about how to refine it to look a bit more professional. Its certainly really helpful having it.
  10. This barely even qualifies as leather work, but I was impressed how well it works, and thought I would share. When I go out shooting, its always out in the mid-day sun. If my sights seem to be off, I have a boresight that inserts into the end of the barrel, and I can check where the barrel is pointing versus where my sights or scope is looking. In bright daylight it's really hard (if not impossible) to see the laser. Solution: A shaded reflector box. I took black corrugated plastic to form the back, sides and top shade. I used vinyl/pleather to connect the top and sides, to form a hinge, so it can be folded flat during transport. I used barge contact adhesive, and then I put 2 rivets with leather washers on each side of each joint to keep it from pulling apart in the wind. I used a flap of velcro to attach the joint where the top and sides attach, so it can easily be set up, taken down, and folded flat during transport. I used DOT reflective trucking tape to make the reflector in the back. In the bright mid-day sun, I can now see the green laser at 300 to 400 yards out, without optics. This is a handy tool. I now just automatically set it up with my steel targets downrange. If anything needs to be checked, it just takes a few seconds to insert the laser, and see how it lines up in the shaded reflector. Then make any adjustments needed. Works pretty slick.
  11. Good looking blade Chuck!
  12. That's neat. I've seen similar patterns on etsy. It would make a fun Halloween costume.
  13. I think I might be tempted to use a product like a Sno-Seal, used to waterproof hiking boots and other leather outdoor equipment; especially if it'll be worn for extended periods through rain and weather. Adding any product can change coloration (usually darkening), and could potentially cause leather to bend or flex, so it's always advisable to test it first in an inconspicuous place.
  14. YEA, that's beautiful!
  15. Looks like a good functional holster. that's do the job. well done.
  16. Good Luck! - One thing on doubling the foam. What I was finding is the foam can fold and make almost a 90 degree turn, whereas leather makes a larger curved radius when folding it, which takes more material to round the bend. When I glued 2 foam sheets together its much stiffer, and makes a larger radius when folding it over. It was more a factor of how the dual layers bend and fold that helped me, versus just a matter of really how thick they are. Although when I make holsters, I'm using 8-10 oz weight + 2-3oz liner, so its pretty thick.
  17. One thing I do when I make a foam mock up of a pattern, I bond two sheets of foam together. The extra thickness, and stiffness of the two layers, makes a more realistic radius when I fold over the holster to sew the two sides together. - Another thing I've found, if I happen to cut out a holster, and it winds up being too short to sew when I fold it over. I can add a welt .... a thick welt up to like 1/2 inch, and make up the difference. Then the two sides don't have to stretch so much to come together.
  18. something like this. a brand name doesn't matter. RYOBI Metal Cleaning Compound Set (6-Piece) A92601 - The Home Depot . Home Depot has a little set with various compounds for different metal types.
  19. No, I don't have a recommendation on a type of polish. just look for a metal polish that is for iron and steel. - the aggressiveness of the polish is typically categorized by the hardness of the metal they are intended to polish. You could buff the handle/shaft of the stamps to clean them up, but I would avoid the face. you could use a polish or a wax to give them some protection. I would avoid putting wax or polish on the face of the stamp. I would expect that would just attract dirt that would get transferred to the leather.
  20. +1 on evaporust for rust removal. I use it all the time. From there, I would possibly go over it with some finish sandpaper - 400 grit would probably do it. Or, if it doesn't need sanding, I'd hit it with some metal polish and a felt buffing pad on my dremel. If its iron, you'd want to use a more aggressive polishing compound. probably green -- or whatever color the compound manufacturer made for iron/steel. I wouldn't buff out the ends of stamps. That would only round off the details in the stamp. Evaporust would still remove rust, but if they don't work satisfactorily after that, they might be at the end of their service life. You could always try buffing them, but just keep in mind, the more buffing, the more definition in the stamp would be lost.
  21. looks like etsy has a couple pages of variations. I didn't see a pattern, but they might give ya some ideas.
  22. that's really neat. I'm sure she's thrilled with it.
  23. That is really neat. Well done. I love it! Ballad of Buster Scruggs is a good movie. I've been thinking of trying to make a gun belt like his.
  24. I've never done it on a knife sheath. I've added a toeplug with a magnet in it to a holster, which worked well. I can't image it would collect any more dirt than a regular sheath.
  25. That is nice!
