Northmount
Moderator
  1. @sold2018Need photos, shipping etc. Please read the marketplace rules and update your post. http://leatherworker.net/forum/forum/70-announcements/ Tom
  2. Northmount
    Boy and his Pet
    Looks great. I like the colourful stones! Tom
  3. Will not be USB powered as it uses far more power than the USB port can supply. It should have USB connectivity for programming and operation. Tom
  4. IP address resolves to Sydney. Tom
  5. @Reddturtle moved to leather sewing machines. You should get more responses from the experts here. Tom
  6. When installing zippers, make sure the centre of each side of the zipper lines up with the centre of the edge it is being stitched to. So staple or tack or what ever method you use to hold things in place before sewing, starting at the centre and working both directions for both sides. It helps prevent skewing the zipper and making it hard to zip up as it is fighting with the heavier leather on each side. Tom
  7. Try this "Flat Plate Open Three-Way". I'm no saddle expert at all, but found it at http://www.saddleonline.com/blogs/content/different-styles-western-saddle-rigging Did a Google searched for "saddle rigging ring dee plate" trying to catch the different terms I have seen. Also found this. It references 3 way plate and a source. And take a look at the bottom picture on this page. They may be able to tell you where they source them. http://www.madisonsaddlery.com/saddle.html Tom
  8. These are the settings that work for me. For some period of time, I wasn't receiving any email notifications. I don't remember which setting I changed. I suspect it was "Send me news and information" Tom
  9. If you are making a 2 layer collar (lined) add a strip of poly webbing between the layers. It won't stretch and therefore the collar will retain its shape better when subjected to water and other abuses. There are some other posts about eliminating the stretch problem somewhere here if you wish to search for them. Tom
  10. Unplug it, leave it sit for a while, then try again. May have to re-do the setup. This happened to someone else on the forum, but don't remember who or when. Another party had damage due to lightning strike nearby when it was left turned on. Some electronics seem to be very sensitive to power line transients. Good luck/ Tom
  11. Looks like it was folded/bent tight towards the flesh side. That stretches the grain side, and when released, wrinkles the grain side. Tom
  12. Looks to me like it was done with an embossing roll. Don't see any joins that you would normally see if it was stamped. Tom
  13. @RB12 If you are not wanting to use foil to make coloured impressions, you can use it cold to make impressions in veg tan leather. You can also use it hot without foil to burn an impression into many types of leather. It will need to be able to operate at a higher temperature to burn impressions. You can have a die made by a photo engraving process, or by CNC milling, or other processes and use an arbour press to stamp veg tan. There are lots of routes to go. Do a search for hot foil press here on leatherworker.net and you will find several threads with more information. Tom
  14. You could purchase an eBook from Tandy that describes the use of several tools. https://www.leathercraftlibrary.com/p-1141-leathercraft-tools-by-al-stohlman.aspx There a a number of other helpful books there too. Tandy and YouTube have a lot of videos describing tooling and how to do it. If you are close to a Tandy store, you could check to see when they have free tooling classes. Tom
  15. Never suggested that there were any on my website. I pointed you to look/search for posts/threads done by Gottaknow. Here is the particular post I was referring to that you could have searched for. Also suggested that you look for comments he has posted to help various people. Here is a link for all content he has posted. http://leatherworker.net/forum/profile/33297-gottaknow/?do=content You should also look at content posted by Wizcrafts. http://leatherworker.net/forum/profile/11118-wizcrafts/content/ There are other sewing machine experts here besides Gottaknow and Wizcrafts. But this should be enough to get you started. You'll find the others as you peruse the site. Also many manufacturer's manuals and catalogs, some posted here, some links to other sites. The search function is just below the banner ads at the right. You can use it to search any topic you wish. Tom
  16. IP address resolves to Red Bank New Jersey. @MaryMac I would recommend all users add their location to their profile. You will get better answers to your queries if they happen to be area related. Might even make connections with someone just down the road. Tom
  17. @Game Moved to Sewing Machines. You'll get more response here. Search for the member @gottaknow. He has posted some training material for sewing machine mechanics. Also has posted a huge number of helps. Tom
  18. 2" equals 50mm (actually 50.8mm) so is considered the same size. With your Consew, you are not sewing 3/4" of leather, so don't need the higher wattage/horsepower. Depending how slow you want to go, you still might want a speed reducer pulley set. But why not test the setup with your servo first and see how it behaves before spending the extra on the speed reducer? Tom
  19. Rub some wax into the zipper. Often helps. Stiff zipper is sometimes due to a little misalignment between the 2 sides. Tom
  20. This is what happens when 3rd party hosing is used and the files are moved or permissions are changed. There is plenty of room on the server to accommodate storing your photos here. If they are too large, reduce the file size. When pictures disappear from a thread, it becomes useless to all. @Deemer Please upload your photos. Thanks. Tom
  21. @RJLamie moved your post to Leather Sewing Machines (instead of How do I do That.) Likely to get more visibility from sewing machine people here. Have you looked in Marketplace under used and like new sewing machines? Tom
  22. Is that like "slow boat from China"? Sorry, couldn't resist. Tom
  23. Patience is a virtue! We are not sitting here waiting for you to post. We are all volunteering our time and knowledge. We have a life outside of this forum that is our primary focus. Tom
