Northmount
Moderator
  1. Hope you are doing much better by now. I would really appreciate some written instructions and source for bladders. I think others here would like them as well. Let us know how you are doing. Tom
  2. Cap the mask cartridges when not in use so the absorbing media is not used up by ambient air. Tom
  3. Sorry I was so slow getting back to you this week. Too many things got in the way. See sketch in attached 3-ring binder clip.pdf and example hardware photos. You will have to play with dimensions to suit your clip. The spacer is a piece of 1/4" NC Hex Nut. If you are removing a binder clip from an existing binder, drill the smallest hole that will remove the rivet. Then you may be able to save any spacer they have used. I didn't realize there was a spacer there so had destroyed it! 3-ring binder clip.pdf
  4. Three posts! Please all, hit submit only once, wait for the server to respond. It gets busy at times because we have so many active members, which is really great. Slow connections may also impact how long it takes to get a response. Tom
  5. I'll put together a little sketch early next week. Tom
  6. I have a 1 ton arbour press, same design. Used it to cut a bunch of 4" (100 mm) circles. I slid a 3' length of 3/4" pipe over the handle to make it easier to pull down. Rear of press was clamped to a solid bench. Had no problems. Tom
  7. Photos so we can see? Grey or bluish? If tends toward blue, then there is some iron contamination in the leather or due to a rack it was laid on. You can bleach out with oxalic acid. The colour is due to the same reaction as vinegaroon process. Tom
  8. From the IP address, he appears to be in the Arcadia, California, 91006 area. Tom
  9. 3/4 oz and thinner are thin. Tom
  10. Try this link Ohio Travel Bag. https://ohiotravelbag.com/shop/search.aspx?term=key plate#f=&p=1&s= Tom
  11. Many will say 50%. Thinner leather may not be able to go that deep. You have to test, trial and error to get the feel and look that you like the best and hopefully your client likes too. Tom
  12. Definitely iron contamination. Keep all iron fillings, etc. out of your leatherwork area. Oxalic acid will remove the spots. There are a number of threads about these spots if you want to search out more information. I would recommend that you be careful trying to bleach out small spots as that spot may now become lighter than the rest of the piece you are working with. I would do a quick bleach of the whole surface to try to maintain consistent colour across the item. Tom
  13. If you warm it up, does the white residue work back in? It would likely be the fat. Need to warm it up and buff the extra back off. Maybe 2 or 3 times. Tom
  14. The ones I tried were pretty cheap too. Princess Auto here in Canada. About $15 for a set of about 10 drive punches. Really thick edges with a steep taper. Tom
  15. Some are pretty hard so may not cut even with a high end bandsaw. I tried touching up a set on a lathe using a carbide tool. No luck. Tom
  16. His works, photos he has posted, can be copyrighted. How he braids, unless he can prove it is totally new, can not be copyrighted. Totally new type of braiding could be patented. If he makes an instruction manual, he could copyright it. Tom
  17. When you let the smoke out, it quits working! And off topic, electronics are nothing but smoke and mirrors. So when you let the smoke out ... Tom
  18. In my early days, I used to use a piece of 1/4" Masonite hardboard about 8" x 8". Placed on a sturdy table works well. Makes some racket, not as good as a marble slab, but works and is more portable. Tom
  19. Check out this FB page, join it. They have photos and a database for Craftaids. Tandy Craftaid Template Database https://www.facebook.com/groups/1373586829381487/ Tom
  20. Just type tandyleather.ca into your browser. Tom
  21. Use a coarse sandpaper to really roughen the surfaces that are being glued together. Gives a "tooth" for the glue/contact cement to get into. Smooth is an enemy in this case. Follow the directions. Apply cement to both surfaces. Let it dry to hardly tacky at all. Then press together. Roll it with a roller, or tap it with a smooth faced hammer to help bond it. Some have more success with heating it a little. Tom
  22. Thanks DQ. Here it is. Tom CHM 30.PDF
  23. Make sure the piece stays flat, don't accidentally lift the left side up higher than the right side where you are stitching. Causes the needle holes to be slanted so the back stitch is skewed compared to the top side. Also watch how it is feeding. If the feet don't sit squarely on the throat plate, it will drag the item to one side of the other. If you are using contact cement properly, it should not be able to skew the top and bottom pieces. Double sided tape is generally not as secure as contact cement. When sewing close to the edge like this, the leather is trapped between the outside foot and the throat plate on the left, but only trapped by the feet and the feed dog on the right side, so will tend to drive you off sewing in a straight line. Not sure if this is what you having trouble with, but hope it helps. You'll probably get some better answers from @Wizcrafts or others yet. Tom
