Agree with Particle. You need greater depth of field so the object is in focus from front edge to back edge. So with a tripod, you should have no trouble using an f-stop f16 to f22 and slow your shutter way down to what ever it takes to get enough light. Nothing wrong with using shutter speeds from 1 sec to 1/15 sec. See also this thread for more related comments and links. http://leatherworker.net/forum/index.php?showtopic=45745&hl=+tent%20+camera%20+light#entry287926 Tom
- 4 replies
- light box
- bifold wallet
(and 1 more)
Check you needle is in the right direction. The scarf (thinned spot) should be on the hook side. Tom
Very Simple Question - How Do You Do This With A Belt?
Northmount replied to laspace's topic in How Do I Do That?
For edge burnishing, see http://leatherworker.net/forum/index.php?showtopic=18101 Check out the forum, "how do I do that" Tom -
As above, and your reach is not limited by the depth of the jaws. Rotary punch is good for a few holes just as convenience. And you can buy several drive punches for the cost of a good rotary. Tom
I'd burnish the edges after assembly so the pieces look like a single entity after burnishing. No misaligned edges. Helps to cut a little oversized as well so you have room to trim the edges even before burnishing. Tom
My First Scally Cap
Northmount replied to Samalan's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looks like some pretty good guessing. Very nice cap. Tom -
The $5 to $10 rotary punches aren't any good. Handles are just thin material stamped out to look like a handle. They collapse under any amount of strain. You need solid steel drop forged type handles, good and heavy. Look at $30 and up. Try this http://www.tandyleatherfactory.com/en-usd/search/searchresults/3230-00.aspx or Osbourne. Tom
Consew 210 Snapping Top Thread.
Northmount replied to shadowryder's topic in Leather Sewing Machines
I suspect you pulled the top thread out and didn't get it back in the same way. Don't start pulling everything else apart to fix the problem. If you take a real close look at the side of the needle, you may find some numbers that identify the needle and size. Go back and ask what thread was being used in the machine. As above, get a PDF manual. It will give you more info about the needle and the proper thread path. There are a number of threads here about needle size and thread sizes. Seems to me cowboy bob has a table of needle and thread sizes. Tom -
Belts shrinking or stretching are all about health. At least if you are overweight, you know what to do. When your belt stretches 3 notches, and you have lost all your energy, dropped 1/3 of your weight for no apparent reason, then you get concerned. Neither situation is great, but I know which one I'd sooner cope with. Back to stiffening your belt. Add a stiffener between the layers, something like Kydex, or poly type sheet. Tom
Use it for stuffing toy animals. Can use some of your leather scraps to make the animals. Tom
Just Another Newbie Tension Question Consew 206 Rb
Northmount replied to HuntingRobots's topic in Sewing Leather
General comment for any machine: Check the bobbin is threaded correctly and seated correctly. If that is all right, then reduce the bobbin tension. There are several threads here about how to set the bobbin tension. When you get the bobbin tension down, you can reduce the top tension. Tom -
See http://www.tandyleatherfactory.com/en-usd/search/searchresults/6015-01.aspx Includes several patterns and types. Once you get what you want working, ask blackriver laser to make a template set based on your drawings and spec. Tom
Admire Someone's Unique Design, But Don't Want To Copy
Northmount replied to spooky's topic in Getting Started
There's an old saying ... Great minds think alike, but fools seldom differ! I'd have to say we have great minds. Hard to change schedule, we're in the same timezone, and not that far apart. Tom -
Different spots, different conchos, different stamps, different order, your choice of colours. Putting stuff on a belt or collar is nothing new. Whether you use hearts, butterflies or elephants, have at it and arrange things the way that suits your mood. Now if you copied the exact layouts, colours, etc., then you would be copying what they have done. And yes, some of your conchos, spots, Tandy 3D stamps may be the same as some of theirs, but it is your arrangement and interpretation. What they have done is not new or completely unique. It's done all over the place. If you copied Lightingale's unique pattern, that would be infringing on her art and expression. There is a difference. Tom -
Thank you for posting it. Tom
One use for some wood carving tools is to use a wide gouge to cut nice round inside or outside corners. Straight chisels also for cutting slits. Tom
How To Make A Leather Portfolio/envelope (Hand-Stitched)
Northmount replied to captain's topic in How Do I Do That?
Yes, glue it together first. Tom -
To get greater depth of field (in focus from the front edge to the back edge) you need to use a smaller lens apeture (f/22 for example) and a slow shutter speed, maybe 1/8 second, all depending on your lighting. Bracket you shots with longer and shorter exposure times so you can pick the best exposure. After some practise with the same setup, you will not need to bracket with as many shots and of course will save a little time. Here are a few links that you may find useful. There are many places on the web with great information. Aperture http://digital-photography-school.com/aperture Seamless background product shots http://digital-photography-school.com/how-to-create-simple-seamless-background-product-shots Inexpensive Light Tent http://digital-photography-school.com/how-to-make-a-inexpensive-light-tent Seamless White Background http://digital-photography-school.com/diy-seamless-white-background-for-product-shots Get your White Balance Correct http://digital-photography-school.com/get-your-white-balance-right-in-seconds-using-grey-card You can build a portable light tent out of some tubing and a flat white bed sheet. You can build it to any size needed for your products. For starters, build something that will fit on your table top. It is much easier to work around than crawling around on the floor. Tripods for camera and lights make it easier to arrange and setup. A boom type tripod is handy for your camera so you can position it above the product if you want to. Photography can be nearly as addictive as leatherwork, so watch out. You may have two addictions to deal with now! Tom
A tent does make a lot of difference. I can see your fluorescent tube reflected in the snaps. Include a piece of white paper in the edge of your photo. Then use it as noted above to set what "white" should be. There is another setting in PS under color. It is to remove any colourcast due to lighting, reflections, etc. when removing colourcast, sample something that should have "no color". Either white, grey, or black. Between the two types of settings, you should be able to come closer with matching your colors. There is also a selection for color correction. Sometimes auto works fine, but some manual adjustments may be required. See if your camera has a setting for manual white balance. If so, use it to get correction started properly in your camera. If you always use same light, same distance, same f-stop, same shutter speed, you should get same color rendition. Auto isn't always your best friend. Tom
The blade needs sharpened, even though new. The typical new blade, especially Tandy, needs a lot of work. There are other threads about sharpening swivel knives. Do a quick search and you should be able to find them. Tom
Question About Hand-Stitching Thick, Curved Leather
Northmount replied to Cameroo's topic in How Do I Do That?
Lay the collar out over a 4x4 or round post so you can keep the curve while you are punching your holes. I would also glue the 2 straps together before punching and stitching. Keep your curve while gluing it up. It is very nice to be able to keep the curve while you are working on it. Makes a more professional looking piece. Tom -
I ocassionally buy kits to get a pattern for cutting out more of the same style. Also if the sale price is really good, and sometimes when there is a great interior or one I want to copy. I rarely buy any of the pre-punched kits cause I don't like round holes for my lacing, or big round holes for sewing. Cost wise, it's usually better to buy some leather and cut and assemble your own stuff. You can decide on the quality of the leather and cut around defects. Tom
