Everything posted by oltoot
16 oz maul for most stamping, 48 oz for geometric, 8 pound for punching or die cutting (also mallets range from 8 oz to 4 lbs)
Great idea!!! Would add, make marks while seated on or as would be a horse then when making a paper pattern add +/- 1/4", depending on how tight the pants fit from the knee up, then measure hardware that will be used how it will be used to come up with final shape for leather
Think about sitting on a horse and, for show chaps, what to emphasize and what to distract attention (judge's) from
Suspenders
oltoot replied to Dwight's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
made mine adjustable in the back, as well, with a 232 buckle -
Design and hardware for balanced-ride saddle
oltoot replied to Squilchuck's topic in Saddle Construction
Monte Foreman put out a book, I think. Trees were custom made. All-in-all, try to convince customer that it should not have been allowed to use word balanced. Required tension for 'balance' -
Best (but not without struggle) place for a swell cover is in the front leg crease. Horn hole right at the firm/stretchy break. (Transition from firm to belly, not either/or) Start at the horn hole, then the gullet and hand hole, then pull the front down starting where welts would be and then 'splitting' the gaps around and there will be no second trys, it will work the first time or go in the scrap box, and best shot is well cased, not real wet. I have even seen Little Wonders without welts but why? Welts are better on swells over 11" IMHO
Did you try Quality Mfg. in Monticello, Utah?
S K's and horses: Take the time it takes; don't rush
Another 'trick' . Rather than try to acquire and then ruin a series of stones, get a series of grit sandpapers from coarse to fine and lay a sheet of sandpaper down on your tooling or skiving place (big smooth spot) and back and forth with your blade in the little Tandy roller guide. When you have the metal 'scored' with a series of lines to match the grit then repeat with a finer grit till you are down to emory paper and just polishing. Finish with hard strop and enjoy!
It was good but things got better with Landis #3, #16, and so on . What is your budget? A modern Juki 441 clone would be better, but a #1 sure beat handsewing for lots of things.
And a book by Julie Hough on horsehair
Remedy for broken Cheyenne roll?
oltoot replied to Squilchuck's topic in Saddle Identification, Restoration & Repair
hard to visualize. If there were a filler in there (attached to the tree) and a join in that is separated, at any rate, glue just sounds like a 'hail Mary'. -
My "standard" was a combination of strings through everything, lug strings, and a screw(s) in the gullet and under the cantle. I did not like pocketed bars, also most that I built were skirt rigged and had additional attachment with rigging set up. Never experienced a skirt move that way unless involved in one of "them big wrecks" (Pole or post or trailer door) Not hard to repair either if I just stopped and thought a moment about sequence. MY own were easiest as I had replaced most nails with drywall screws and had figured out where to taper and skive to avoid jerks and pops which tore and broke things. And all (most of) my strings left the shop extra long so they could be double wrapped and release tied. You can always cut a little off of a string but rarely can you make them longer
Notice too, that that all stems from having used the stuff and knowing what works and doesn't before figuring out how to make it.
Wild Horses were getting along with native wildlife before bison and Indians were killed off and replaced by domestic livestock and so on. How far back do you go to put things right? Today's wild horses must be managed, not eliminated
Saddle Identification please
oltoot replied to Janis's topic in Saddle Identification, Restoration & Repair
Hardware can be pretty time specific. Brass is either new or pre war. Aluminum is newest (probably post war) while plated steel is from the war years, generally speaking. Screw heads have time periods, too. -
The "best way" and not too readily available way to start would be to repair a lot of stuff that is actually being used and make careful and complete observation of what works and doesn't.
Looking for saddle maker to replace horn cover on old saddle
oltoot replied to JJP5956's topic in Member Gallery
Probably made in Mexico in the 70's. Not buckstitched but painted -
Pre-made latigo holder with breast collar tab
oltoot replied to DirtyDusty's topic in Saddle Supplies, Tools & Trees
The whole setup needs to fit snugly with the conformation of the horse including the connector from the middle to the cinch, then 3/4 is enough. If it is loose anywhere and can pop and jerk then stress is concentrated, not well distributed. Fit, fit! -
you may also be able to let the needle come up, catch the loop, then turn before the loop is pulled back down to the shuttle. Pressor foot should be free and loose at this point
Best leather for motorcycle saddle bags
oltoot replied to Sturmtrupp702's topic in All About Leather
What I came up with was: shoe sole composite for side next to bike (chain & grease resistant) along with 9/10 oz black harness for gussets and 11/13 oz black harness for fronts and lids. Held shape and lasted well. -
And fold cased (better than dripping wet)when possible
Ride a lot first before settling on things like rigging design and seat shape. In all analysis, think about a naked man on a naked horse and enhance that relationship. Then focus on execution and eye appeal
Roughly wet mold first, then stamp the stretched piece, then finish. If basket stamping, consider a wider, more overlapping border and touch the wet molded piece up a little before final assembly
Sometimes I would use whatever was handy and maybe have 2 or more braided layers till I reached the core size I was after. Tended to make softer cores that way. But you could make them stiffer by braiding the cores smaller and tighter. 2 or more layer cores are not as fast to make but can be more challenging. The big bosal that I liked the best had a small twisted core with three tightly braided, small string layers over that. Really lively and springy but not steely. There is a difference when they are for sale vs personal use. Happy trails
