toxo
Contributing Member
Everything posted by toxo
  1. I started my business with nothing.... and I've still got most of it!
  2. What a race that that turned out to be. As a Hamilton fan I was getting despondent with his tyres going off and Verstappen catching him with time to spare. Then Verstappen overtook him but had to give the place back because he'd exceeded track limits to do so and Hamilton goes on to scrape a win. The thing is, Hamilton had exceeded track limits many times earlier in the race until Mercedes were warned not to do it. The difference being that when Hamilton did it he wasn't gaining a place. Surely this needs tidying up. Supposedly there's a different rule on track limits for qualifying and racing. But if it's allowed on race day why was Hamilton warned to stop doing it? What say you?
  3. Welcome Klara. You're doing well so far. Maybe look at coursing dog collars like Greyhounds, lurchers etc for inspiration. They use quick release all the time.
  4. I've seen that done before. Never realised how quick and handy it would be. Nice one.
  5. I use a Scharfix lookalike in black. Cost me around £90. When I first tried it I almost threw it in the bin but as I got used to it'd little foibles I found it to be quite capable in a limited way. It's ok with veg tan types but I found it stretched the edge on softer leathers. Then I found a little trick that all these type of skivers can benefit from. Say you want a 20mm skive. Using a smallish roller start off at the 20mm mark and work outward. When you get to the edge you'll have a small area left meaning less pulling pressure and less stretch. You'll have to play around a bit. You may have to start at 25mm to get the best result. Of course you need a sharp blade so here's another trick. The blades come in different thicknesses and the thicker ones can be resharpened but I couldn't find any at a decent price until I found these, https://www.amazon.co.uk/gp/product/B07BH7CNC3/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
  6. Not too squishy.. Defo not hard.
  7. I'm no expert but I know some just trap both threads under the presser foot in the down position and don't hold it at all. Don't know if you can do it with all machines.
  8. Nice job. He's gonna love that.
  9. Welcome and enjoy the forum. There is much to be learned here.
  10. Welcome. Get some layers of foam under that granite.
  11. Nice job Alberto. Nice and neat around the corners.
  12. If this is doable as a retro fit and is robust and consistent you should expect an offer for the patent from every servo manufacturer sometime soon.
  13. That thread is never going to sew consistently. In fact I've never seen bonded nylon that looks like that. Maybe you're winding it on the bobbin in a strange way or someone switched labels on you.
  14. Where's that "like" button again.
  15. The needle has to be inserted with the long channel on the left and the shorter scarf on the right, The thread has to be inserted from left to right.
  16. Awesome work. They're certainly not gonna wear out any time soon.
  17. All you need to emboss that size stamp is an arbor press. Check out my post on DIY hot foil. My arbor press is now able to do all the rivets/ snaps etc but also clicker duties. On the bigger size dies I just walk them around. And now it will emboss names and stamps and hot foil as well. And it's only a 1 ton press. I'll update the thread soon.
  18. You're all the wrong way round. If the brown is the underside either the top tension is too loose or the bottom tension is too tight. When adjusting the top tension only a turn or two at a time. Sometimes just a half turn will make the difference.
  19. The spring on my 69 wasn't in the best of condition and college didn't have one. Folker suggested the spring on my Durkopp 239 would psobably fit and if so I could order a Singer one but I couldn't get the damn spring out of the Durkopp I was pulling as hard as I dared but I didn't want to ruin it. The 69 worked fine until it had done around 3/4 inches of sewing and then it would miss a stitch. I reasoned that the spring was catching somewhere so I got the needle nose pliers on the job to ensure it wasn't touching anywhere. Job done. No more missed stitches.
  20. I built a large work table outside my shed and I thought I'd put enough braces in to hold a battleship BUT it has a full size vice on it and has seen some serious pushing and pulling and now it's a bit wobbly along the length. If you want to go with ply 3/8th is plenty, even 1/4. But if you don't see any serious action on it just a couple of diagonals from the leg/shelf to the center in 2x2 3x2 4x2 will do the job whatever you have handy. Of course if it's going against the wall, a couple of rawlbolts will do it. You've done an excellent job Rob, I just wouldn't like to see it loosen up for the sake of a little bit extra.
  21. There are various ways to brace it. The strongest of course would be a full sheet of ply covering the whole back but that's not an option if it's gonna be an island. depending on how you see your storage you could put your base shelf in and then run a sheet of ply on top of that down the middle which would give shelving on both sides. Even small diagonals half way or even two thirds up each leg would help a lot and not impede your shelf space too much.
  22. I would have thought it obvious but maybe you don't plan on doing any serious pulling/pushing. The joints aren't even getting any help from the table top because you have them sliding.
  23. Looks really good but if you're not gonna screw it to the wall I would defo put some diaganal bracers on the long sides else it won't take long for those joints to loosen up.
  24. After a couple of failed soldering irons I bought one of these and this thread got the grey matter working and remembering that one of the blades was a sort of knife blade without an edge I had to run upstairs to try it. It comes with two standard blades and the "knife" blade which I think is for cutting synthetic rope or fabric to stop fraying. The downside is you're not able to set the temperature and it only applies heat when you pull the trigger but this can be a good thing. Anyway, the top line was applied after the smoke wore off the new blade, the next down was around 10 secs and the bottom line was peobably half that. Clearly some experimentation need for whatever application but I'm happy I've got something else to play with. Sorry about the pics. Can't seem to get the hang of the camera fone.
  25. Rebuilding old sewing machines gets old for those who don't do it. Also if you don't live in the US so does saddles chaps and holsters. in fact if you took those away from the forum there'd be precious little left. It works the other way too. If I post about handbags/purses there's precious little response. If you really want to be a global forum you might want to think about encouraging other stuff. Just a thought. I know there are sub forums that cover a lot of it but newcomers to leather don't even know what questions to ask yet. Sometimes those that are very knowledgeable don't always like to give away their secrets so I'd like to see that opened up. How about a sub forum where we can give away our secrets without being asked for the benefit of all? I for one am champing at the bit to share what I know, I'm old enough to have racked up a considerable wealth of knowledge ranging through engineering, fabrication, construction and even retail. I don't professs to being a guru at any of it but I could sure help out a lot of people. I would even be available should anyone take an interest in anything I've done to help out via messenging on here or email. I'm still relatively new at the leathering but I've been getting/making the stuff to make things easier and people will be surprised at how cost effective it can be.
