billybopp
Everything posted by billybopp
  1. I think that if I ever tried to count or calculate the number of stitches in an item, I'd never hand sew again. LOL. But, that said it eventually gets easier, faster, and even relaxing - you can listen to music or even watch some TV while you work. It's a lot like driving a car. Remember when you first started driving? It took ALL of your concentration every time you went for a drive. If you tried to change the radio station, you were likely to swerve all over the road. But, as time went by and you got more experience, you could relax a bit and sing along with the radio, change stations with ease. It all got easier and more automatic - you still pay attention to what you're doing but it's just not occupying your entire brain until you get to the tricky curve. You get to that point with hand sewing too, and it can be enjoyable! - Bill
  2. If you look at the sponsor links at the top of the page, you'll see Bruce Johnson Leather Tools. Bruce is a member and sponsor here. Click on his link and give the site a little love! He has a tutorial page with instructions for sharpening edgers, including bissonettes. Just in case you're not seeing links, I'll post it here. https://brucejohnsonleather.com/files/1414/0658/3880/BruceJohnsonLeatherTutorialEdgeBevelerSharpening.pdf - Bill
  3. Thanks Mjolnir! I knew there was a Norse equivalent Orobouros, but couldn't for the life of me remember - I even checked my Viking mythology books but couldn't find it at a quick look. There's even a Native American version and if I remember right a Hindu version. Commonalities in mythology throughout the world are a kind of startling at times! - Bill PS Please don't drop your Mjolnir on any airports when it's finished, thanks!
  4. Unfortunately, there are a few instances of things that are pretty much leather only - edge creasers, bevelers, stamps, stitching chisels and irons, and a few others. Even with those, you can sometimes find a creative substitute. But fortunately there are also a LOT of tools and things that CAN cross over! Sharpening stones and strops don't much care what is sharpened on them - leather tools, straight razors, kitchen knives, woodworking tools - you name it. (now that I've learned to sharpen leather tools, I have to warn the family when I've been at the kitchen knives so as not to scare them). Cutting surfaces are more or less universal. Self-healing cutting mats don't care what's cut on them. While I wouldn't return them to kitchen use, a retired cutting board can be really useful. The same goes for silicone cutting mats - they're really nice for gluing as the glue peels right off. Retired silicone spatulas and basting brushes can be used for gluing as well and clean reasonably easily. Hobby knives (X-Acto) have too many uses to count. The usual #11 blade is a little too flimsy for leather IMHO, but the #2 scalpel blades work great. Same knife handles either way. Good for leather, wood, paper, fabric, even occasionally in the kitchen. For the most part, a ruler is a ruler is a ruler. Same for a square and any number of layout tools. I'm fond of combination squares, and have a few different sizes. They do excellent double-duty as square AND ruler. Being metal they are also excellent for guiding your knife as you cut. Utility knives have all kinds of uses, and most everybody has a few. Worth noting, however, disposable blades such as these and hobby knife blades are OK from the package but can be improved with some stropping! More or less, mallets, mauls and hammers can cross over easily. Same goes for chisels. So there are a TON of possibilities. - Bill
  5. Contact cement of one sort or another is the way to go. As Mutt mentioned, Barge or Weldwood(technically a wood contact cement) will work very well. Some have been reporting very good results using Renia Aquilim GL and 315 which are water-based contact cements. It's a little hard to get in hobby quantities in the USA, but it's a German brand and may be easier for you to get there! - Bill
  6. I've seen similar on eBay being sold as hole punches for leather. - Bill
  7. Uh oh. NOW you've runed it! - Bill PS .. Lookin' really cool!
  8. I've thought I'd give bissonettes a try, and they work nicely on thick leather, but not so hot on thin. They're kinda wide, and to get to the edge you need to prop up the leather on something. They aren't so easy to sharpen IMHO. So far, my favorite is an old unbranded set, similar to the round-bottom Tandys. I'm still looking for "the right ones" tho. - Bill
  9. If you're using linen thread, you can run into some problems with really long runs as the thread will wear a bit with each stitch that you pull through and eventually will get ragged and break. With poly thread, such as Ritza, that's not a problem and you can do very long runs with a couple of caveats. The thread will wear a little bit around the knots where attached to the needles making it a bit harder to pull through the holes. To deal with that, just make your thread a couple of feet longer and re-thread the needle when it gets raggedy. Lighter colored thread can also pick up dye and dirt as you go along and start to look a little dingy, but that's not a problem with darker colors. Probably the hardest thing to deal with on really long runs is when the thread gets tangled and knotted. For that, it just takes a little extra time and care. Watch the thread as you pull it through and look for tangles and knots. They're not all that hard to deal with before they are pulled tight, but a real pain after! Taking a little care to keep your thread separated on each side of your work can help prevent the nastiest knots. It's also a good idea to keep your work area very clean where the thread lies on the floor or work surface to keep it from getting dingy. I've done several belts and guitar straps in a single run with poly, so it can certainly be done. Hope that helps! - Bill
  10. I've been using ziplocks too ... 2 gallon for largish patterns, other sizes for smaller ones. Even for something as large as a briefcase, the smaller parts go into bags and bigger pieces get held together with punched holes and chicago screws. Bags then go into big plastic bins on a shelf. Bags come in darned handy for keeping already cut parts together for individual projects when working on more than one at a time. - Bill
  11. Now THAT is a workshop with a view!! - Bill
  12. Barry King is a sponsor here on LWN. Look for his banner ads at the top of the page and use that to get to his website. Give LWN a little love that way! - Bill
  13. This might help a little ... Somebody posted it on here awhile ago. Not by any means complete, but it'll give you an idea. - Bill Craftool Conversion Chart.pdf
  14. This is the book I picked up some 40 years ago on brain tanning ...https://www.amazon.com/gp/aw/d/B008GE55U2/ref=mp_s_a_1_13?ie=UTF8&qid=1518051048&sr=8-13&pi=AC_SX236_SY340_FMwebp_QL65&keywords=deer+tanning
  15. I'm 53 by the calendar. 25 in my mind, and 70 in my arthritic body. So it goes!! - Bill
  16. @rodneywt1180b Give "deer tanned" leather a try. It's very soft with a good amount of stretch - It would have a very nice feel for what you are doing. Deer, Elk and Moose are usually tanned this way, but cow can be too. I don't know how it is made in tanneries in the modern world ( I suspect some variation of chrome tannage ), but it was traditionally done with brain, sometimes eggs added and other things. Native Americans supposedly said "Every animal has enough brain to tan its own hide". If you look about on youtube, you'll find a few videos on brain tanning - they tend to be a little gross tho. - Bill
  17. Leather tends to distort and "grow" a bit when tooled. If you punch holes then too, they likely will not align again after. As Mattsbagger said, punching holes for sewing is usually near the end of the process. - Bill
  18. Sounds like you might be describing Renia?
  19. A tag of some sort is a great idea. Depending on what you make, another nice option could be a simple fabric presentation bag made of flannel, satin, or cotton - whatever suits your product - can be nice. They cost little, can be put together in minutes, and provide a little bit of protection for your product in the shipping box. It gives the customer the idea that you've taken that extra care for the product you've made for them. - Bill
  20. While I normally subscribe to the "Buy once, cry once" philosophy, that really only applies when you have a pretty good idea of what you want / need. To my way of thinking, that's where Tandy level tools come into their own. No, they're not great but they are good enough and cheap enough when on sale to start to get an idea of what you want to do. A good option for you might be to poke around on ebay and find somebody that's selling a good sized collection of tools for a good price and go to town! I'd try not to pay more than a couple bucks per tool buying that way. After six months or a year or so experimenting you'll have a MUCH better idea of what good tools you want to buy. Keep those Tandy tools that you don't replace around too - you never know when you might need to do that one-off tool that's just good enough. Just my opinion - Bill
  21. My Dad's family are from near Latrobe. I think Rock was the first beer that I ever tasted. Dad gave me a taste of the beer that he was drinking when I was six or so years old. I still remember thinking "'How on earth could anybody like this stuff" .. much like I did with coffee. Now I can't imagine how I didn't like it, and subscribe to the notion that "Beer is proof that God loves us and wants us to be happy" (often attributed incorrectly to Ben Franklin, who did actually say something similar about wine). - Bill PS .. These days my favored everyday brew is another great Pennsylvania beer, Yuengling Lager.
  22. Mutt's almost got it .. not a bar grounder, but he's right about the clue near that bottom right snap. It looks like a Tandy A104 for most of the area and possibly A105 at the edges - but there are a few others in that general family of tools that it could be (and could also be a similar tool from another maker). Go to Tandy's website and search "background". Additionally, they look to have used either a lined or checked beveler around the outside border, also likely Tandy. P.S. Sad that Netflix hasn't yet released the rumored season 5 of Arrested Development. *Cue the Charlie Brown sad music* - Bill
  23. Years ago, the tourist trap shops in Florida used to sell cans of Florida sunshine for a couple bucks a piece. If you google "Canned Florida Sunshine", you find both vintage and new cans for sale. I'm sure they laughed all the way to the bank on those. Your idea is much better, tho. When the novelty wears off, it's still usable as a drinking cup! - Bill
  24. Last I knew, there are several stories about Rolling Rock's 33 ... but since the brewer who originally had it put on his bottles is long gone .. we may never know. - Bill
