Everything posted by billybopp
Years ago, the tourist trap shops in Florida used to sell cans of Florida sunshine for a couple bucks a piece. If you google "Canned Florida Sunshine", you find both vintage and new cans for sale. I'm sure they laughed all the way to the bank on those. Your idea is much better, tho. When the novelty wears off, it's still usable as a drinking cup! - Bill
Last I knew, there are several stories about Rolling Rock's 33 ... but since the brewer who originally had it put on his bottles is long gone .. we may never know. - Bill
Green Elven Knight Helmet & Bp And Mini Tutorial
billybopp replied to Prince's topic in Historical Reenactment
I've been following Princes work for a number of years. He never fails to impress! Check out the gallery on his website, you won't be disappointed. - Bill -
... I literally laughed out loud when I saw this. Thanks!! @Sledzep01 is quite right. WD40 does provide a bit of lubrication but that's not really what it is for. It's pretty fascinating stuff. Developed for Convair Astronautics in the 50's for the Atlas missile program. They needed a product to prevent corrosion while missiles were in storage waiting to start / end WWIII. The name comes from Water Displacement formula 40 (since apparently 1 through 39 didn't work as they wanted). It didn't take long for folks to discover myriad other uses for the stuff, and was made available to consumers in 1958. About 8 or 9 years ago, my bathroom door developed a nasty squeak, probably from the moist environment when taking showers. It used to wake me up during the night when roommates went in and out. Eventually I got tired of that, and give the hinges a spritz of WD40 but that didn't last too long. So, I gave it a spritz again and followed it up with tri-flow lubricant. Now, many years later not only are the hinges quiet, but the door needs a doorstop to keep the door from closing on its own. Pretty amazing stuff. - Bill
Hermes isn't going to tell you this, but they do in fact use sewing machines for the parts of the bag that aren't visible such as liners. They DO hand sewing where it shows and makes a difference. I expect that handmade doesn't have a solid definition - hence you find people selling items made from Tandy kits on etsy and calling it handmade. Bespoke tailors usually use machines, but there are a very few that hand sew at the very highest level, and some in-between that, like Hermes, use machines where the result isn't visible. There is a difference to the trained eye, but most wouldn't notice it. I think that leather is much the same way. Handmade is fairly broad. If I were selling handsewn, I'd state it and use it as a marketing tool. Those that know the difference will understand what that really means - a generally superior product. When it comes to cutting, burnishing, and many other operations, when making a standard product the leather doesn't care how it is cut or burnished. There isn't any distinguishable difference, and where there is use the method that gives the result that you want and your customers want. If an item is truly bespoke, then a cutting die isn't going to be the best solution, at least for parts of the product. That's just my 2 cents - and that's probably about all that it's worth. - Bill
Beiler's Leather Supply 3025 Harvest DrRonks, PA 17572-9756 717-768-0174 ... Not sure if that's what you're looking for... Bill
Book recommendation for beginner
billybopp replied to Brahmus's topic in Floral and Sheridan Carving
I reckon 5 of a pattern is probably a good number. Enough to learn at each iteration, and few enough that boredom doesn't overtake ambition and make you want to give it up! You'll learn something with every one - and it might be fun once you've done with all of those to go back and try each one again - I expect you'll be surprised how much you've learned. -Bill -
Regular dye and pro dye are both good. Pro dye is a bit more vibrant, using petroleum based (IE synthetic) colors in alcohol based carrier. Regular dye is also alcohol based. Colors can be mixed to create different shades ... But mixing between regular and pro can lead to surprises. Both are a bit easier to use and control when diluted with denatured alcohol, rubbing alcohol, or (sinfully wasting) vodka or everclear. Sometimes you can get even the stuff that's illegal in Cali via eBay I've heard... At some point, you may want to take a look at some of the leather color books by Stohlman, or the Fiebings Fantastic Finishes book. Good stuff! - Bill -
Good choices, the Figure and Pictorial books are great, but not the thing if you want to learn floral carving. These and others are also available in .PDF format from Tandys leathercraft library online for a bit less cash. If you're a 'video learner", I'd also recommend Tandys video series with Jim Linnell. It's a good intro to floral carving. Also, I concur completely with Bikermutt - Leathercraft Tools book is essential. Your tools HAVE to be very VERY sharp to be effective. I'd also suggest practice, practice, practice. Use some scrap tooling leather and just make some cuts with your swivel knife to learn control ... Make a bunch of "S" cuts - practice easing into and out of cuts. Make your "S" cuts from both directions. Work on making some circles with a cut from left and right - make concentric circles around each other keeping distance between equal and symmetrical. Once you have some lines, you can also experiment with bevelers and learn how to get smooth bevels. (Yeah... It's boring, but like practicing scales in music or lines when drawing - it's the basics and gets you comfortable with your tools). When you are comfortable with your tools, pick a simple-ish pattern and do it over several times - critique and learn from each one. Rounders are a good item to use for these exercises. They're not overly expensive, not too big, not too small, and you can use 'em as drink coasters when they're finished. There's also the opportunity to experiment with dyes, antiques and finishes on these. (PS ... Highly recommend Fiebings dyes, antiques and finishes over Tandy's eco-flo products). Hope that helps! -Bill -
IIRC, Ian Atkinson's wallet pattern on Etsy has variations for script from various countries ... he also has a "more refined" design available with folded edges, etc. - Bill
Awww. Get better, Wiz! - Bill
I don't have one of Terry's knives, since I went a different direction and have antiques with the exception of the two really cheap ones that I bought specifically as "learners" ( to learn to sharpen and use). They are over 100 years old, are still in great shape and very nice to use. If you look at old price lists, these would have cost one to two weeks wages when they were new - a BIG chunk of change. Knipschield or Leatherwranglers are every bit as good if not a bit better than my antiques and with a little care will last as long - Your great grandchildren could well be using them. The prices might seem a little high, but for most of us they are a few days pay - even after taxes. Not at all bad in comparison to the antiques when new. It's a pretty good deal, really. Just some food for thought - Bill P.S. Mutt - When are you gonna make some sheaths for those?
- 35 replies
- terry knipschield
- knipknives
- (and 8 more)
Most use rounders to make drink coasters with. Great for beginning carver/toolers sine they're not too big, not too small, inexpensive and make something useful. As shown here tho. They can have other uses. We'll done. I may have to make similar. - Bill
Not sure if these would work for you, but Lisa Sorrell (a LWN sponsor) has been selling some heat erasable markers that look promising on her Sorrell Notions and Findings site. She also has a youtube video on how to use them. They just might do the trick for you. - Bill
Barbie needs one o' these. She's a classy chick. - Bill
That's gonna look nice - Very worthy of Thor. I bet it'll feel nice too! - Bill
Those stretched leather strops were pretty common (although usually not as pretty as that one) about 100 years ago. They were usually used to strop straight edge razors. - Bill
You might try pencil grips - lots of styles - not free, but not overly expensive. like these @Amazon. Might not fit all stamps, tho. - Bill
Battlemunkys shed looks nicer than some apartments I've lived in. Probably bigger, and better smelling too...especially with leather there. - Bill
The right way is the one that gets you the result that you were looking for. Some dyes get dark really quickly while applying. Those can be made easier to control when diluted. Resolene can be a bit difficult to get smooth when wiped or brushed, which can be made a bit easier with dilution. If you're getting good results .. Don't go changing! Bill
Love it! Outta the park again. Bill
I love eBay ads out of China that have a long string of words.... None of which have anything to do with the actual name of the item.
Heritage Rough Rider Holster
billybopp replied to WastelandOuterwear's topic in Gun Holsters, Rifle Slings and Knife Sheathes
There should be a rule on here where anybody that shows a holster or sheath must also show at least one picture of the gun or knife that goes in it! Lots of us like guns and knives almost as much as we like leather! In any case, nice lookin' rig! Bill
