Everything posted by fredk
Integrity of an old tree
fredk replied to Alexis1234's topic in Saddle Identification, Restoration & Repair
One thing to check for is wood-worm. I was once given an old saddle. Someone thought I'd be interested in restoring it. But it was absolutely full of wood worm holes right through the leather. Just some shoving and pulling proved that the wood tree was only being held together by the remains of the leather. I did strip part of it back and the tree just crumbled away. I dumped it all. With mild word worm wood can be infused with polyester resin to fill the holes, pores and strengthen it. -
For one thing; I'd turn the shears over so the handles/grips sit on the back piece, then the blades will not sit too far out.
- 18 replies
I'm interested on how you've got on as well
This may help with ideas. I make a cheap version of notebook cover using chrome tan upholstery grade leather. I got a great lot of this leather from my usual supplier. It was off-cuts from them recovering leather furniture. It cost me then about £1 per kilo, works out at about £0.50 sqft. I just glue the leather together, and use ready-rivets where needed. Cheap corner protectors added. I supply a note book in it. The books can be bought here in the local £1-shop, (dollar shop to you) so replacements are easy to get. This cover costs about £2.75 ($3.50 ?) to make in materials which includes £0.50 for the notebook The chrome tan leather can't be tooled but I've made these with an applique veg tan panel sewn on which had a person's name stamped on it. That added all of, maybe, another £0.10 as I just used a bit of scrap leather trimmed to size, stamped and dyed. In a way that is quite handy as I have a number of these ready-made in a box and just need to add the applique panel for personalisation The pattern for this is real simple. One large rectangle about 25 x 17 cm, and two rectangles of 9 x 17 cm for the insides. Two pieces about 3 cm x 14 cm glued flesh to flesh for the closing strap. On the reverse this strap goes thru a slot into the main piece. It has two rivets to hold it there. By going into the cover the strap looks neater and its ends do not catch on anything and they do not really interfere with the book slipping in hth
1. wet your leather first. wet enough as if for tooling, but not as wet as for moulding
Your location is important to us. But Birmingham where? There are several around the world. However, I see from another posting you made you may be in Birmingham, UK My first stop is Le Prevo, Newcastle, http://www.leprevo.co.uk/hides.htm others would go to Abbey https://www.abbeyengland.com/leather-and-materials.html
buckle & strap placement body or lid/flap?
fredk replied to ASAuLTCases's topic in How Do I Do That?
It depends on their use. What they are required to do. On a tool roll where you just want the whole roll not to un-roll, just about any leather will do for the strap.. Generally, on a ladies handbag, lightweight leather can be used as well, but on a dispatch rider's bag where the bag may be bulging over-filled you want a stout leather that will not stretch. an off course example; the bonnet and boot lid on my 1930 Austin 7 are held closed by leather straps. The belts need to be pulled really tight to hold the panels secure. Sometime prior to me getting the Austin someone had replaced the belts. They used too thin and too stretchy a leather, you could see the wear in each successive hole where the belts had been pulled tighter and the next hole had to be used as the leather stretched. I replaced all the belts with 3.5mm thick from a back-bone area. Very minimal stretch after 15 years of use. -
As we are sharing photos of our phone holsters, here's mine. About 18 - 20 months in daily use. The area around the hole for the stud has softened over time. It could do with improving
6 of one 1/2 dozen of the other. As for 'rules'; what ever suits you or the construction. On shoulder/handbags bags its better to have the buckle attached to the bottom then you're not fighting gravity to get the strap up through a buckle, but gravity helps to get the strap down thru the buckle. I always prefer the buckle strap to be short, on the 'bottom' end of anything. -
Some snaps are incredibly difficult to open. If I have any of these I run a file around the ridge above the groove which the spring grips. I take just a smidgen off it. This loosens the grip just a tad. The snap still hold tight but it just doesn't need that screwdriver to open it. Another thing I've had to do is put a piece of thin brass between two layers of leather. A hole in the brass for the snap's shaft to go thru and the brass extending to where a person grips to pull the snap open. This was on a repair - improvement where the leather had stretched and pulled out over the head of the snap
I find that with frequent use velcro becomes useless. tbh when I make a new phone holster I'll be doing the the strap & loop closure. The SB stud can be a nuisance
I use a 'Sam Brown' stud on my phone holster. Inside the holster the screw part is covered with a piece of pigs-skin lining
yup. 6 oz = 2.4mm, Main belt also about 2.4, = about 5mm, the minimum sort of thickness for a sword belt. Sword weighs in at 1.25 to 2 Kg. Some sword users like to wear the scabbard as well, thats another 1kg with its bits. Too thin or too light a leather and the belt just twists and collapses I only ever had to do a really thick belt, 6.5mm or so once. Most sword belts were in the region of 4 to 4.5 mm 1 oz = 0.4mm 6 oz = 2.4mm 5 mm = 12.5 oz 6.5mm = 16 oz 4 mm = 10 oz
I read it over there. All I can think of is its a chrome tanned split. Good for thin belts, lining thicker belts or for making handbags/shoulder bags with a 'rustic' look
I got my US and CS stamps from duckcreektraders, aka Bunk House Tools https://www.shop.bunkhousetools.com/Embossing-Plates_c4.htm About 1/4 way down for the CS and 2/3 down for the US Heres a better look, different sizes, closer to the top of the page https://www.shop.bunkhousetools.com/Embossing-Plates_c4.htm?sortOrder=2
homemade recipe for preparing liquid carnuba wax.
fredk replied to paloma's topic in How Do I Do That?
My opinion on this. Carnauba on its own might be fine for edge burnishing but not for surface polishing on flexible leather. Carnauba is a very hard wax. Its used on wood furniture because of its hardness. Its used in the French Polishing technique, as a final coating polish because of its hardness. On leather, the leather first absorbs the turps, but the leather does not absorb the wax which remains on the surface of the leather. The wax dries out and the wax continues to harden. As it hardens it will form cracks and eventually crack and break off the leather surface That is why its usually mixed with beeswax. Beeswax is actually a bee reprocessed honey. A honey bee is fed honey and it processes it in its body and extrudes platelettes of wax. For every 6 to 7 pounds of honey 1 pound of wax is made. Beeswax has a lower melting temperature and also contains more moisture which helps it to be absorbed into leather. But beeswax on its own is a poor polish so carnauba, which is from a tree, is added for hardness My qualifications on this are; Once upon a time I was a bee keeper. I used to make polishes for car-finishers, furniture polishers, leatherworkers and more. I attended certain instruction courses to learn about polishes so I could mix polishes to suit the end users. Some end users used to travel from all over this island to search me out for my polishes. I wasn't in the Turtlewax league but specialists preferred my polishes -
The only 'Gorilla' glues I can find locally are an expensive Cyanoacrylate (aka CA, or Superglue) or an expensive PVA. (about £10 for 125ml)
I've made light-weight 'medieval' style shoes and ankle boots. The thickest I've used for the sewn on sole is 2.5 mm. Then I've put inside an insole of about 1.5mm thickness with and extra heel piece of 1.5mm under the insole. All veg tan. I used to make children sized slipper shoes in medieval style out of chrome tan upholstery leather which is about 1.2mm thick. 'Feedback' was that both the parents and children really liked the slipper shoes as they were so light and flexible (and cheap too!) My dottir had new pairs every season from when she was 18 months old until she was 5 y/o. Only stopped cos we stopped going to events. Even outside of the events dottir used to choose her medieval shoes for playing in.
This Art Form Is Going Straight To Hell
fredk replied to Reegesc's topic in Leatherwork Conversation
I think that is a very condescending statement -
B203 = OK B935 = OK P217 = (Not really needed here) but could be used instead of a B199 if really stuck P703 = Not really needed here C491 = Not really needed here U851 = Not really needed here V407 = Not really needed here You have drawn a line inside the ribbon. I would a. use a wedge end stylus to press that line down as a shallow groove or b. cut with a swivel knife then use the wedge end stylus to press down into the cut line and shape it Backgrounders: A104-2, (optional) A105, A114 or A888-2, (optional) A888, A889, or A104, A118
I just had a look see. Those are the books and Craftaids they've always sold. I can't find the 'tip sheets', basic pattern ideas etc. Good thing I got about 90% of them when I did
ok. I'll start the list 1. Swivel knife with a fine blade 2. a selection of bevellers, from wide to small eg, B200, B201, B203 3. a lined beveller, eg B199 4. A stylus with a wedge end
I don't know if this is much use to you but I'll add it in anyways. Le Prevo, Newcastle. England has pigskin lining, suede (113) and 'topgrain' (087) http://www.leprevo.co.uk/hides.htm
I got that as well to my saved/bookmarked links also; I get a 404 'page does not exist' page when I try to access the pages to download the patterns I've bought or acquired off the Library
