So, what are you shooting for in the look of the edges and the amount of work/materials you use @canonitr? If you are wanting to avoid the shiny look, then you can just sand them using a higher grit sandpaper. If you are wanting shiny, hit them with a burnisher of some sort, even a piece of sanded wood will work. The whole point in finishing edges is to get the corners of the leather rounded so they don't get fluffy from knocking into things throughout their lifetime and to also close off the edge from moisture penetration as much as possible. I don't know what does that better than burnishing or painting but as long as those things are occurring, your edges can look however you want them to. Also, oils usually make getting a burnish tougher but may help seal the edge against moisture. You don't need gum trag or toconole or anything, water works pretty well on its own. Soft and fluffy rags aren't the best for burnishing I find, maybe for using after you get the burnish perhaps.
Personally, I like how yours look a lot. As long as that is what you were shooting for. They look neat and clean.
