CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Good point about the motor that's probably what happened I didn't think about that,but this model doesn't have reverse
  2. One of 2 things you might have loosened the feed cam just to the left of the hook gear on the lower shaft or you took the timing belt off & didn't get it back on correctly
  3. Are you threading the thread through 2-holes in the spool pin on top of the machine?If not as your sewing the thread can work it's way out of the next tension unit & if you don't have enough tension it will jam,also are you sure your wrapping the thread around the 2nd tension 1& 1/2x? Also don't forget to give the hook some oil everytime you change your bobbin,it just needs 1-drop in the groove that it rides in.
  4. Parts are not available,the only way to get parts would be to find another machine to buy.
  5. That should fix itself with a leather needle.
  6. I'm no thread expert BUT,the wick thread is for canvas & should expand & fill the needle hole when it gets wet to prevent leaks.
  7. Is the sunstop wick the larger one?
  8. Great job,came out nice!The 111w156 is a great workhorse of a machine.
  9. Here's some that are available. page0689.pdf
  10. It's a lousy repaint by Goldsworthy of either a Consew 226R or Seiko,look how they painted over the rod on the backside,even the needlebar & pressure bar have paint on them!They used to put their name on brand new Pfaff's too,
  11. Here's a pic of the adjusting screw,you want it pull pull just alittle counterclockwise,so the little tab of the hook basket under the needle plate pulls foward so the thread can go past it. Adler 67,167,267 bobbincase opener adjustment screw.jfif
  12. Here's a manual. Singer_29K71_72_73_Manual_hi_res.pdf
  13. I think you might be over oiling it,& just put a couple of drops a day in the reservoir instead of filling it as I almost certain it just wicking out when it's full until it's empty.
  14. These shuttle hooks are still available check with College Sewing in the UK ,there's 4-bolts holding the head to the table.
  15. It's a good machine BUT Pfaff quit stocking alot of parts for it,you'll have to hunt ebay for that back bar or hope to find even a parts machine.There is a good shop in Indy that can work on it.Call Ed @ Indianapolis Sewing Machine.
  16. Can't help you with the serial #
  17. This is a Singer household machine,model #15-88 .
  18. It won't siphon with nylon or polyester ,just cotton thread.
  19. The pulley should slide off by putting a wrench or screwdriver behind it & prying alittle.
  20. This is an older machine I'll need a pic to help you as Juki bought Nakajima yrs ago.
  21. Set the needles side by side,you'll notice the 135x17 is approx 1/4" or 6mm shorter.Lower the needlebar all the way down,mark it right at where it comes out of the bushing.Open the side cover & loosen the set screw @ the clamp(while holding onto the bar) & lower it the 1/4" & tighten the screw & give it a test sew.
  22. Get some large adjustable pliers & grip the pulley in the groove.OR you could put a belt in the pulley & hold on to it real close to the pulley while trying to loosen it.
  23. Start with one around 2&1/4" long.
  24. One more thing to check ,if you loosen the set screw that holds the needle in how much play does the needle have left to right? Sometimes after years of changing needles & tightening the screw it enlongates the hole that the needle fits into & can cause it to hit on the left.
  25. Try pushing the needlebar front to back to see if you have any play,if so look underneath @ the reverse parts while pushing it front to back & you'll see what you need to tighten up.Some of these had a feed dog with a round hole,there is a longer slotted hole feed dog available (which we stock) that might help too.
