CowboyBob
Contributing Member-
Everything posted by CowboyBob
Don't forget when you sell something to include the price in the ad.
No,I don't think you want to strip it!! You need to fix it !! If you take the race off (it's held on by 2-screws) there's a screw on the back that holds a u-shaped spring & it holds a ring on,take it all apart & clean it,put it back together & see if the side play is better ,if not you need to buy a new race.Over here they sell for $20.00.Someone has adjusted the needlebar to take a longer needle,if you want the 16x2 to work loosen the set screw on the needlebar & lower it so the needle is just below point of the shuttle point as it passes by the needle as you turn the machine in the direction that it runs.
These are just like a 31-15 machine.you can use 16x2 leather points,or 16x257 round points.all the common parts interchange with 31-15.
We have a customer using the long-arm 2-machines w/o reverse & they have a foot pedal lifter they lift the foot & pull the tarp towards them while sewing.It sure wouldn't look pretty in leather though.
Help On Ferdinand 900B Parts And Attachments
CowboyBob replied to Ken Nelson's topic in Leather Sewing Machines
Darren,the problem with this model is Ferdco made some special parts for it & it's a needlefeed w/a jumpfoot that takes a special foot that only a Ferdco like this model takes.The more common parts aren't a problem I've ordered parts from Consew for people in the past, the machine it was modified from is the model 754R. -
Tacsew/juki 563 Hook Timing Problem: Stitch Length Affects Timing
CowboyBob replied to Uwe's topic in Leather Sewing Machines
When your @ o-stitch length the feed dog needs to be centered (front to back) yours is too far back. -
Help Identifying An Old Singer Sewing Machine
CowboyBob replied to FoxJ's topic in Leather Sewing Machines
Yes,the 95-1 has that belt,there is someone making the belts now.I have seen them on ebay.- 7 replies
- singer
- sewing miachine
(and 1 more)
Double Needle Machine For Double And Single Stitch?
CowboyBob replied to ken sungela's topic in Leather Sewing Machines
We had a customer buy a long-arm double needle with the hopes of using it as a single.I tried to explain to him how it would be awkward & hard to use BUT he thought the one machine would do both his single & double needle work.He even had Tennessee Attachment make some cording feet & zipper feet.The poor guy dumped a lot of $$ in this & then after about a year called back & let me know I was right.Then he wanted to sell it back to me because he's getting out of tarps & just doing upholstery work.I sent him a few people wanting it & I guess he finally sold it. -
Cb 3200 Arrived/setup And Sewing!
CowboyBob replied to eglideride's topic in Leather Sewing Machines
Great looking belt !! -
l2bravo, It's been reported to me that IF you talk to your machine nice BOTH when you make your sample & when you move on to the finished products you'll have much nicer results!! -
Great !! Give us a call if you ever have any questions. -
The 1000H are approx. 1/4" longer than the 97 needle so they can be shortened to work.We have some in stock in #26 & 28 & they only come in a round point.
Let's Talk About Threads And Needles
CowboyBob replied to l2bravo's topic in Leather Sewing Machines
Yes,Sir,I'm looking @ a box of 135x17 & that's what it says on it !!They used to be made in the Czech Republic until last year sometime,they seem to work OK !! -
The Groz-Beckert's are made in India,Schmetz are still made in Germany we just got some 794S in that say it on the package(they have 4-15 date on the package).The leather needle we sell a lot of is the 794S which has a spade point on it that really makes a nice looking stitch in leather,I think looks better than the DIA point(which we also stock in Organ) which seems to make alittle wider hole on the sides than the "S" point.Some Organ needles are now made in Vietnam. -
They must of had the belt marked wrong.All the 153's take the same belt & I just checked a #224195 we have in stock & it's 25 3/8" & has 41 teeth.The belt they sent you is for a postbed 168,138 machine. Uwe, Id say the parts list is wrong.The one you mentioned is for the 47W & would be shorter than what he needs,it only has 38 teeth.
Mystery Vintage Singer Sewing Machine With Top+Bottom Feed
pcox is correct the 188 has a narrow(standard) base,the 88 wide base. -
Could You Please Identify Another Singer?
CowboyBob replied to sandyt's topic in Leather Sewing Machines
I have a Pfaff & it looks a lot like it but the controls are different.I just took a guess on Durkopp because of the way the controls look on it. -
It is similar to a 107w,143w machine but I think it's a Durkopp.Or maybe Adler machine.Singer never had the lever sticking out or had a zig-zag adjuster like that. -
The bobbins 204370 were made for the other type of bobbincase that fits in the 136(see pic).They still will work with the style he has but will fit loose & can spin causing backlash.So you might want to put some felt in the bottom of where the bobbin sets.The bobbins he is using could of been made wrong.
Wilcox & Gibbs had them & since Singer was never one to be outdone, they probably copied them so they could bid against them for the garment industry?
Singer 111W155 Arm Shaft Bushing Will Not Come Out
CowboyBob replied to tammythefactory's topic in Leather Sewing Machines
Constabulary,that's a good idea too!! I forgot & I just had a guy in last week that did that very same thing to his machine.He just bought one of those screws a few weeks before & I told him he didn't need it & he thought well if the factory put it there it should be on the machine.So he puts it on & then overtightens it & when he brought it in after working on the machine for a month he wanted us to fix it.I loosened while he was still here & loosened it up.- 23 replies
The gear reducer servo is no longer being made & yes they were more $$ than the FS-550 we now sell,so all we have is the FS-550 which will need a speed reducer($135.00) to run the 205 @ a slow enough speed & have enough power.
Maybe the bearing by the handwheel is bad? Slide it off alittle & see how it spins.- 23 replies
Sometimes pieces of the old belt & I've even seen a few teeth from the belt in the groove on the pulleys,so you might want to slide the bellt off & check.You can scrape it out w/a screwdriver.- 23 replies
