Everything posted by RockyAussie
Honestly....save up a bit and get yourself a bell skiver. You can use them well enough for splitting when you need to and you also then have the advantage of being able to do skived edges way quicker and easier than mucking about doing it by hand. I am doing up a manual at the moment for the new Cowboy version here in Australia and that will also come with a few " How To videos" which will assist new owners on how to use these machines. If you want to have a talk pm me a message and I will give you a call. If you check this old video I did awhile back you can see a little on how you can use a bell skiver to split leather down.-
- 6 replies
- splitter
- cobra class 14
- (and 4 more)
Yeah if I remember right the first awl like that I got I could not get the blades to fit either. In frustration I ground down a screw driver which now and then I still make use of. You can get blades that do fit but being able to knock up your own comes in handy caus you can make them to suit the job better sometimes. Here's that old screwdriver one -
I came up with the same results. I hope that the model numbers have been mixed up and we are wrong. I have to say I have a few Pfaff's and I although they are great machines I could not think of any that would be suitable for this sort of normally heavy duty work. That is why I had to go look.
Wish you a very happy birthday mate
Glue and fabric combination (for wallet card slots)
RockyAussie replied to Spyros's topic in How Do I Do That?
From my experience I would not try Kwik Grip as I found that it does not hang on all that well. I usually use a solvent based contact adhesive which is the type most shoe rrepaires use for sticking the soles down. As I buy it in 20 litre drums that probably does not help you much. The fabric I use is a Jacquard fabric from Tabru in Italy. It has a seal coat on one side that stops the glue from penetrating through. Prior to using that I used to get some taffeta and spray a watered down mix of pva on it to seal it. Not so nice if you want both sides nice but could be wortha try if you like. Red pink tan orange brown and black I have in stock of the Jacquard from Tabru. If you want a metre I could do it for $20.00 per lineal metre plus post. Should have mentioned that the Jacquard also does not fray at the edges when you cut it. One of the reasons our wallets last toooo long. -
Can you show me a picture or drawing of how this looks? Is one raw edge finishing with an outer edge or part ways? Contact gluing that shape may be difficult. It might be worth considering to make one up to feed straight into a sewing machine a bit like a binder does. I have not ever had any issues to date but then I never put wet contact glue straight onto them either.
Hi @Anubis78, Should be alright I think. I thought these machines came with an adjustable for width guide set up. What is not working with them? I will need to know fairly closely the thickness of strap you want when folded and the width. I see I never got around on this thread to loading any of the video's showing my guides in use so here is one now (bit long and boring but best I could come up with at the time)
Adler 467 FA 373 / G2 HP (Air Lift Cylinder)
RockyAussie replied to jthroneburg's topic in Leather Sewing Machines
Three things I can think of that may cause this....first, is the presser foot shaft well lubricated? Second, is the air supply supplying the right psi pressure to start. It may be a regulator problem. Third, as a temporary fix try and get a few drops of oil into everything that moves on the air lift cylinder. On one I have I put a few drops on the rod occasionally and that seems to soak in a swell the seal enough to keep it going for a few weeks at a time. Another thing to watch for is that the switch that activates the ram is not bypassing the air and releasing it in the wrong direction. -
@TjcGoods I dug up some info on the 8020 leather splitter and the blade sharpening. I talked to owners of Cowboy Australia and found out where they get their blades sharpened. Unlike some dealers they DO get them sharpened up before they send them to the buyer. What I have to say is that if you want to get thin soft done then forget it as that will not happen well. A second blade will set you back $250 from them. The person to speak to who sharpens the blades for them is Doug Timbs (0419678571). Doug is also a fellow leather worker and knife maker as well based in Toowoomba. (Nice bloke). He charges $40.00 on these long ones and $20.00 on any of the shorter ones I believe. If it can work for you a shorter version may be better as they can run a bit truer in thickness. Some models do NOT split well and Doug can explain that better if you want to call him.
- 6 replies
- splitter
- cobra class 14
- (and 4 more)
On fixed blade splitters it is common to get someone with the right sharpening gear to sharpen them up when you need it. Having 2 blades is the best way to go if you can so that you are not held up when the other is being sharpened. I will see if I can find out about the double hollow grind and who is capable of doing it and get back to you. I have a couple of band knife splitters myself but am up in the Rockhampton area. If you check with Lefflers they may be able to tell you of someone close by that can split for you. Texon Australia may know someone as well.
- 6 replies
- splitter
- cobra class 14
- (and 4 more)
I and I am sure a few others here may be able to help but ....so as to not highjack this thread it would be worth starting a new thread of its own. Please post some pictures showing what you are calling a mess top and bottom as that will help to narrow down the problem. There are many different reasons that can cause a mess underneath like wrong needle wrong thread combination to start with. Remember that pictures need to be reduced in size before posting to a maximum of 1.4mb in total.
Advice on sewing machine and accessories please !
RockyAussie replied to Hairic's topic in Leather Sewing Machines
Just one more thought ...make sure that table is the pedestal type and not one that is closed off on the end. They use less room and can be tucked away better but mostly they don't stop you because the table gets in the way. A quick check on my you tube channel will show you why. -
I think you are on the right track. For gun holsters and a lot of other stuff you mention you will want a cylinder machine and a big one at that. A cylinder machine can be a flat bed but a flatbed machine can not be a cylinder. Personally I am used to using a cylinder machine and almost never have a seen any worthwhile reason to put on a flat bed attachment. Even a belt I prefer to stitch on the round caus that's the way it get worn anyway. Only thing I can think to mention is that on any of these 441 type machines the smallest leather point needle they make is a 23 and that means the best smallest thread is a 138 or m20 in metric. -
Hey @toxo, In case it helps some I have done something similar with some feet on a Adler 69. I did make the back foot in this case years back before I knew where to buy them. I will put a couple of links up that may be of use in buying. This one you would need to smooth off the bottom of the feet and maybe grind away the edge some more. https://www.ebay.com.au/itm/264766542768?hash=item3da550d3b0:g:on8AAOSw7O9e6bUi This one is a full one which you can grind back to what ever you think suits https://www.amazon.com/Standard-Presser-Durkopp-Sewing-Machine/dp/B07QKB5WZC Here is one of the jobs I use these for which is a bag handle As you can see here I have ground it away a lot Here showing that only the back part behind on the rear foot does any holding down
My Roy Rogers version
RockyAussie replied to Thescandall's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Gotcha, I don't get to do much with holsters over here. Last one I done was probably 5 years back. -
Looks good for a quick draw I reckon. Why have you used the rivets may I ask? -
Anyway to sew this bag seam with a Machine?
RockyAussie replied to Willbury's topic in How Do I Do That?
Not a hope on the little structured bag I showed above but yes On the op bag it should be possible. -
Ha ha...don't I wish. Another 2 would be better but then I'd be wanting more again I'm sure. Thanks @Thescandall. I hope all goes well and we get to see your new gunbelt when its finished.
Yes I do as well. Check at 5 min 40 seconds in on that video and you will see with the scrap in I don't hold it when I put the needle in.
Good idea there @Spyros I always have handy some scraps by my machines and I also like to have some handy to check my tensions before I start the job. What I do is run a few stitches in the scrap and that gives me something easy to hold most of the time to start off the main job. The scrap stays there generally until I am finishing off. At about 40 seconds in on this video you can see my tension checker scrap piece - https://www.youtube.com/watch?v=wdloxyjeB1w&t=436s
That is quite possibly the reason. You would need a very solid and firm base to do the peening well. Once you have cut the rivet to length (1 or 2 mm longer) I normally tap around the outer edges of the rivet before finishing off with the dome tool.
Just reduce the pressure. When it is too tight it makes it hard to get a clean start without cutting in too deep.(Hard veg will need to be a bit tighter) With good settings and a sharp blade it does not matter. Its quicker to rotate the job clockwise but sometimes it is safer to go anticlockwise. When you offer the skived edge into be skived you hold back away from the guide a little and curl up the edge so that you have a start on top of the bell. If you don't have a roller in that can be a bit harder to do as you have to overcome a fair amount of resistance at the start with a standard foot. Your knife has to be very sharp and not have any rough feel at all. The pressure setting have to be just right for the leather being skived. Being able to go slow with the feed without the bell going slow as well does help. On Fortuna's and FAV's etc the bell runs at a constant speed always with the feed stone being independent from the bell speed. If you were using a router on wood would you be happy if the spindle slowed down when you slowed down? Many people have opted to put a separate motor drive on these 801 skivers to have the bell run separately. The new Cowboy versions in Australia are now selling with an independent motor set up for this reason. There are a few tips that just may help in this video I did on circular skiving awhile ago- The skived pieces above are for the wedding ring boxes I make which if you go to my profile and look in the about me section you can see the topic which shows how to make them.
