Everything posted by RockyAussie
If you are using Curra I think you may be able to just increase the scale in the Y direction to 1.5
I have no idea if this video by Uwe is any help but I have found it useful by following right through the steps to get every thing going as it should.
Guidance Needed replicating compendium
RockyAussie replied to Leathermann00b's topic in How Do I Do That?
Good Guide Gary
I would recommend taking the thread stand off of the patcher as the vibration of those machines in use would do that. Try putting the thread spool off to one side and see how it goes. I think I remember running the thread down onto the floor once to stop that happening on a patcher.
Can you elaborate? Do you mean adding something stiff in between the back and front cover? Perhaps instead i could achieve the same result by using a thicker veg tan? But perhaps that will make opening and closing a problem..? I have been giving this a bit more thought and as a newbie to this leather work stuff I think adding the binder clip will create a lot of headaches for you. Getting the tablet to clear the binder clips as you slide it in would entail putting a gusset section in place I believe. As well a binder clip normally has to have a solid stiffener behind it to spread the load. Rivets just through the leather will quickly tear it apart and wobble all over the place. Below I will attach a few pictures showing a prototype Filofax cover I made ages ago and you can see the construction of the type of stiffening that is required. First pic is the finished prototype Outer cover removed from inner section Outer cover has thinner stiffener right across and note the extra thicker sections on either side. This helps to keep everything in place as it opens and closes. Note also the foam attached to the outer cover inside. Note in this pic showing the lining section, that the stiffener is one complete piece with cut out sections for improved folding when shutting and opening. Now this design although good for a filofax that needs to be firm to be able to write inside of... it will not be so good for holding something like a tablet inside of it. You would still need the stiffening in the centre but you may need to cut away some in the outer sections to allow a more flexible cover. The pics below show some of how I go about achieving this for phone purses and in this case shown a passport/document holder. Ist and second pics shows the finished product Here you can see the cut out section in the stiffener before the outside is attached. Showing outside stiffener,foam and material to be attached together. Here you see the cut out section before I fold the outer covers. I hope that this is making some sense now. Re the 20 mm strip of leather is a tape measure idea of sorts. When I need to get a distance around something like a tablet, phone or product lining I like to have the correct weight of leather for the job because the thicker the leather used in the job the longer the outer cover needs to be. Saves a lot of maths is all. If you want to call/phone me just send us a pm and I will give you my number there. -
My best yet
RockyAussie replied to AussieMade's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I have got to ask what your hole punches look like after doing the lace holes? Works slowed down a lot at present so sort of a holiday. I look forward to you dropping in if you make it up this way again. I don't have any brass swivel snaps but do have a few brass 25mm buckles if that helps. -
My best yet
Good looking stuff there Damien. What hardware you needing, dees and buckle? Is that beady ray you fought you way through or a roo print? -
If your around the Brisbane area I would check out this link https://www.theleathershed.com.au/ They run workshops and such as well sometimes I believe. I have sourced leather from them for 20+ years and they are normally pretty good to deal with. Tell Trevor and Tracey Brian sent you and expects a big discount on his next order - Re the ring binder they will take a fair bit more work to do right and the cover will need stiffeners added into it. I would start of getting one from office works and pulling it apart. To get your length of leather measure, cut a strip about 20mm wide of the thickness you have and use it like a ruler going over the shut folder allowing for about 6+mm overhang on both sides for your stitching and trimming up. Getting the rivets out can be tricky and a sharp drill bit would help. You will need to get some rivets to replace so check if they have them while you get your leather. Mac-lace https://maclaceleather.com.au/ will have some if they don't and is another place where you can get leather and other leather craft supplies. -
You think it should have music? or should I be talking through the steps? I like a bit of music but I've seen a lot here don't in the past.
I had to go and find out about them Cricut cutters. I was a little curious what sort of critter or grasshopper could do that. The elastic I used is 2mm shock cord which so far seems to be well excepted. It will last well at least.
This is just a short 2 minute video showing some of the steps and processes used in making our first batch of these. My granddaughters, son and friends have been all been wonderful to send me some pictures of them being worn. The lady doing most of the work in it is MY wonderful wife. I hope there may be a couple of useful bits that may be of help if you are doing any of these. In case your are wondering how many pieces of fabric I am cutting with the Fiskars circular knife, I found that initially when it was extra sharp I could cut 8 layers but that dropped back to 4 layers as is bluntened off after the first 200 masks or so. The cutting table has a 3' 4" square top of HDPE. The lacing tool for the elastic is a reshaped bicycle spoke.
FACE MASKS 101
RockyAussie replied to Ferg's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I totally agree and well said. Thank you Ferg. -
I reckon your right - https://www.greggrantsaddlery.com.au/stable-and-grooming/leather-care-and-tools/tanning-formula-and-kits/commercial-tanning-knife?gclid=Cj0KCQjwtLT1BRD9ARIsAMH3BtUx1UMzygKMNG6SQ6N7nVDzCbt-n975IS7WiivZATs6jWEte_B_oS0aAs0CEALw_wcB
Pondering over machine size CB3200 or CB4500
RockyAussie replied to TJStrand's topic in Leather Sewing Machines
I believe that both these machines are getting a bit too big for purses. You can not run thin threads through either due to there being no leather point needles less than NM 160 size 23. A CB 341 might be a better choice and will give thread sizes from Thread Sizes: #46 - #207 Needle: #135x16/17: #16-#24. A bell skiver is a must if you are looking for production but maybe a bit expensive if just for a hobby. -
I have seen in a catologue at some time where the pfaff 335 was available with an oscillating dog foot but it is very difficult to find. From memory they have to have the letter P after say 335-H3-P sort of. The best I can find at the moment is possibly in this pdf where there is a difference shown on page 21 and 30. https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=2ahUKEwjtvbiY4oXpAhVCT30KHcNVATUQFjAGegQIBBAB&url=https%3A%2F%2Fwww.supsew.com%2Fdownload%2FPfaff%2FPfaff%20335%20H3.pdf&usg=AOvVaw3_CKC405UTEGZCwwcT3jDf I will try and find the better descriptive one and post it up when I do. Also note that the techsew 2600 cylinder comes with an oscillating dog foot as standard. https://www.techsew.com/us/techsew-2600-narrow-cylinder-leather-industrial-sewing-machine.html Note: There is no dog foot tab sticking out the end as there is in the picture below it. https://www.pfaff-industrial.com/db-downloads/technicaldoc/teilelisten/300/tl_335_06-09_de_en_es_zh/@@download/file/TL_335_06-09.pdf Page 55 on this one above.
That would be hard to get I think but you could try Pfaff direct. If you have a 3D printer available I could send you a file for one that I have done in order to have it smaller than the original.
Here is a couple of pics of my Pfaff 331 close in on the feed dog. My favourite machine. At about 1minute in on this video you can see it action. https://www.themorningbulletin.com.au/videos/wild-harry/43913/
I only ever use a belt sander a rag wheel mop with tripoli polish myself. Check this post out I did awhile back that shows one of the knives in action. If doing a new knife from scratch I would do a sharp belt clean up to start with to keep the heat down then redo with a bluntened off belt to smooth up following.
- 54 replies
- al stohlman
- round knife
(and 1 more)
Well done!!!! Add some turks feet and a head and you got a pet rock dressed I think. PS ...dont forget his little mask
Frustrated by Consew 199 - Timing Issues
RockyAussie replied to spotty's topic in Leather Sewing Machines
Looking at your picture above it appears to me that you have the thread going incorrectly in that the thread should be going from your tension discs straight up to the thread return spring and then back down to the hook then on up. Although this video shows a different machine if you check at about 2.5 minutes in you will see what I mean. -
Help! Which machine for this stitch please?
RockyAussie replied to johnnywalks's topic in How Do I Do That?
A tall post machine would do this quite easily. Remember the leather is flexible and you can do this by stitching one side first followed by the other side by flexing the leather down a little as you go then you do the bottom before pulling the corners up to be stitched across. This needs to be done on leather that doesn't crease up when pulling the corners up or turning inside out to do those corners. This sort of post would be ideal but a shorter one can manage it as well but will be more difficult. https://www.techsew.com/us/techsew-85017-high-post-walking-foot-industrial-sewing-machine.html -
Need Help With Cobra Class 4 ... Stiching Issue
RockyAussie replied to RoosterShooter's topic in Leather Sewing Machines
Check that the screw that gets undone first when adjusting the bobbin tension has not worked its way out and hitting the race occasionally. Check there is no threads stuck down in the race. If they are not the problem..... to quote a very wise Wizcrafts... -
That also would be my best guess. Getting snagged at the bottom on a large spool would be about that sort of measurement I would think. Note that the knot shows its coming up higher as it comes to the missed stitches which also indicates a varying tension somewhere. Crooked sitting cone?
