shoepatcher
Everything posted by shoepatcher
  1. late 80's machine. Probably a B class with high lift. Nice machine. Uses #92 thread top and bottom. Can use #138 thread but has to have a few modifications on it. glenn
  2. Everything seems to be there. Machine needs a good cleaning. glenn
  3. First thing you do is clean the machine up so you can work on it. Rusty and dirty. I do not work on any machine until it is clean so I can see what is going on with it. glenn
  4. When timing a shoepatcher, the bobbin and hook to sits on top of the shuttle carrier has to come back to 10:00 meaning it has to go back past the needle. Needle is at 9:00. If it doe not go past that before it starts forward, will never pick up the bobbin thread. The eccentric screw and nut is what you adjust to advance or retard the travel of the hook to the needle. glenn
  5. C, That machine has been fobarred a little. I think I can fix it. Some parts needed. What the hell went in #4??? The lifter to manually lift the foot is correct. glenn
  6. I think Esty has the flatbed attachment for the 3200 cowboy. He is now in Chicago not in Michigan. glenn
  7. Hirose hooks are very good hooks. Aftermarket but excellent quality. Have used them for years. Should fit for you. glenn As to presser feet, I get my generic ones from M.J. Foley in Detroit. have used them for years. glenn
  8. the stitch length clamp is not on properly. Will not feed because of that. glenn
  9. you can run #138 in the Brother which is like a 227 Consew. glenn
  10. parts you are looking for? glenn
  11. These late models were all H4 I believe meaning 14mm lift. Hope that helps
  12. pics please of the 68-RT72 glenn
  13. It is Wiz. For the light. glenn
  14. more pics of the head please glenn
  15. 26 Cobra us a clone of a Juki 341. The mechanics manual for the 341 will work on the 26. No problem. Order the machine. The 26 is not a hybrid. It is a clone of the 341. Parts are interchangeable. glenn
  16. yes Machines are stretched all the time for specific applications. Delker out in Mass. I think was one of the best. glenn
  17. It was stretched. Not the best job cosmetic alloy but looks nice. How good is the drive belt in the machine? The regular 167 manual will work for operations. Parts list in a lot of places still valid. You need a custom top for that one and a longer table stand. glenn
  18. pics of the machine please. glenn
  19. I have a manual for the 30-15 and parts list. Color of your machine? glenn
  20. the 30-1 stitch length is a max. of 5mm. As time goes on the lobes in the bell crank wear reducing the stitch length to under 5mm. Your black machine was made before 1950. Adler started building them in 1900. Copied the Singer 29K. I have some parts. glenn
  21. I believe it will sew 12mm. The lift is that I know. I have never seen a 105-64 with a roller foot. People have thinned the foot thickness to sew thicker. Pics would help. glenn
  22. The cam at the end which is has the race on one side and the pulley slot on the top of the wheel is out 180 degrees. Need to be depinned and moved 180 degrees. glenn
  23. contact Eli Schlabach at Landis sewing in Arthur, IL. He can help. glenn
