kgg
Contributing Member
Everything posted by kgg
  1. Since V69 has a breaking strength of 10.6 lb and V92 has a breaking strength 14.2 lbs you could try tying a piece of thread to 14 lb of weight and see if you can lift it without it breaking. If it breaks it is V69 if not it is V92. Just a thought, Merry Xmas kgg
  2. Hi jimi, Merry Xmas, my experience with the 3d printers may help someone down the road. kgg
  3. Adding your $500 premium that may put you in the ball park of a Juki LS-1341. Which you may want to consider. kgg
  4. Definitely is not that ladies first time doing that work. A master. kgg
  5. I would seriously look at the Juki LS-1341which is rated for V138, thread top and bobbin. Lots of parts / accessories readily available at reasonable prices for Juki and Juki clones not so much for the Pfaff. If you don't need a cylinder machine since you are not doing bags maybe the Juki DNU 1541S or better a 1508 flatbed machine. kgg
  6. Simple answer is NO. It is a domestic sewing machine made for fabric probably maxing out at V69 and at $250 it seems to me way overpriced. The Consew even through is more expense I think it would be your better option. Those that use the Consew machine would be better to guide you. Remember "Buy Once, Cry Once" , don't be penny wise and pound foolish. kgg
  7. I thought they stopped doing the V138 upgrade but could be mistaken. All these machines were basically intended for was the offshore repair of sail material but can do decent work on other material as well. The pressor foot and feed dog are very aggressive but that can be somewhat tuned out not too leave as many marks in leather. Stitch constantly can be a challenge particularly as material thickness increases. They will do nicely for the occasional heavy use but are not built to withstand it for long. Unless you really need the zig zag feature you would be better off getting a good used machine in the Juki 1541S (compound feed, rated V138 top and bobbin) class or if you don't really need V138 maybe you could go down to a machine in the Juki 1181n (walking foot, rated V92 top and bobbin) class depending on what your needs/wants are. kgg
  8. My experience is that the 1541S does not like things less then 3mm thick as the feeding is a little too aggressive while on the same amount of material the 1181n happily sews along. The 1541S excels at the mid level of thick stuff while the 1181N excels at the light to mid weight stuff. My 1181n is basically setup for lighter stuff and binding / cording. The pressor foot on the 1181N has a much smaller profile with the feed dog nowhere near as aggressive. The 1181N reminds me more of the feel and sound of a really nice old domestic Singer humming along, just with better capabilities. kgg
  9. Ooops me to I forgot to mention I use V69, V92 and V138 in both the Juki 1541S and 1181N. Both machines came sewn off with V138 threaded top / bobbin out of the box even through the 1181N is only rated to V92. I figure I could push the top thread to V207 but keeping V138 in the bobbin without too much problem in the 1541S. kgg
  10. In my opinion it is all going to depend on what and how thick as well as the thread size you are planning on using. The main reason I got the 1181N was that for the 1541S to do lighter stuff I was spending 15 to 30 minutes dumbing it down if I didn't it would have a tendency to tear stuff up. Then I would have to spend about the same time resetting the 1541S. If you are going to be doing mostly (90 percent) heavy / thick stuff go with the 1541S or larger otherwise get the 1181N. Eventually you should get a second machine. Whatever you decide, if it is possible, try a sample of what you are planning on sewing on both machines see which one works best. There are couple of good video's showing how the 1541S does on thin stuff you should at. kgg
  11. Hi Smithi, welcome to the forum. I have both the Juki DU-1181N as well as the Juki DNU-1541S. The 1181N is a much lighter machine then the 1541S. Personally I would find a 1541S not a 1541 where the "S" destination refers to it having a safety clutch. Better still would be a 1508. To a youtube search for Juki 1541 vs 1181 and Juki 1541 vs 1508. Just my opinion. kgg
  12. I like the cheap disposable thread snips as nylon Rigging said when they are dull toss them, for stuff cutting stuff I really don't care about how the cut looks because it is going to be covered I use cheap dollar store scissors and for the good stuff that needs to be cut nice and proper, I use 440 stainless steel or Titanium scissors. I think it really comes down to your budget, intended use and how long you want to get out of them. My good scissors were expensive but they are 20 years old and back then they were really expensive. kgg
  13. Here in Ontario, Canada the Pfaff's aren't very common and can be expensive to repair. If I am not mistaken the Pfaff 145 and 545 are older versions of the 1245. I have a German casted 1245 706/47 walking foot with a clutch motor that I am planning on selling. kgg
  14. On the less expensive side depending on how much your carpet pile will compress and the type of backing on the underside of the carpeting. Your portable sewing machines may do the job and fairly inexpensive on the used market. Those that may work could possibly be your Sailrite LZ (USA), Techsew 611(Quebec) , Reliable Barracuda (Ontario) but check with the suppliers and if possible test drive with a piece of carpet using the thread and binding you are planning on using. kgg
  15. To add to Constabulary links: Mitsubishi DU-105 -- Very Clear https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwicsf2MqNHtAhWoElkFHbVLBe8QFjACegQIBhAC&url=https%3A%2F%2Fwww.supsew.com%2Fdownload%2FMitsubishi%2FMitsubishi%20DU-100%2C%20-120%20Instruction%20Manual.pdf&usg=AOvVaw3uTFUneRig7cFyUxoVSoNu Singer 211g 155 -- Very Clear version better photo's https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.supsew.com%2Fdownload%2FSinger%2FSinger%20211G155%2C%20211G156%20Service%20Manual.pdf&psig=AOvVaw2fFVFzIkTEfn8WS-q4xSKd&ust=1608166909268000&source=images&cd=vfe&ved=0CAMQjB1qFwoTCKCC392m0e0CFQAAAAAdAAAAABAI For a start stop turning the main pulley wheel away from yourself should only be turned away from yourself in small amounts to reset the safety clutch or help clear a jam of thread at the hook otherwise it could cause timing issues. The Mitsubishi and Singer manuals should help you with a lot. From the Mitsubishi Manual: Stitching length can be adjusted with the stitch regulator push button on the bed and the balance wheel. 1) Pushing the push button down and turn the balance wheel slowly to ward you. 2) So that the push button goes down further and the balance wheel running. (I guess they mean free wheeling.) At this time set the graduation of the dial on the Balance Wheel with the marking on the arm and then release the push button shown in Fig. Caution: NEVER depress the button while the machine is running. Out of curiosity what size of needle are you using as it appears you are using V46 thread.
  16. Some of you may know that I like my 3d printers for this hobby and other stuff. I figured I share some of my experiences those planning on getting into it or planning on upgrading equipment. I first purchased a Prusa i3 MK3S it came not assembled to save a few hundred in assembly costs. That in itself was a 12 hour assembly journey. Used it for about 120,000 meters and started to notice some minor print changes and decided to get a second machine so we bought another Prusa i3 MK3S and a Bear upgrade kit along with the Bontech extruder assembly. That assembly made the first look like a walk in the park, definitely not for the faint of heart. It took about 40 hours to assemble. Thankfully we had the Bear Prusa Upgrade completed as we had a catastrophe fan failure at about 160,000 meters on the first machine so we then replace it with a whole new Bontech Mosquito extruder. We got about 20 hours of use and then had a stepper motor support failure. Which we suspect was why we were having previous minor print changes related to belt tension. Upon examination of the failed part it was obvious Prusa cheaped out on proper infill needs for that stress location. We printed on the Bear Prusa Upgrade a much better stepper motor support and for the other side a better tensioner mechanism. We installed a 1mm nozzle in the new Bontech Mosquito on the older Prusa i3 MK3S machine. What a difference in print time. As a comparison we printed a simple 6.5 mm thick part on the Bear with .4 mm nozzle and the same part on the rebuilt Prusa i3 MK3S. The Bear Prusa took 10 hours 58 minutes to complete and the rebuilt Prusa i3 MK3S took 2 hours 58 minutes to complete. Does it ever lay down filament. That is a significant reduction in print time, saving 8 hours. Guess what is getting upgraded next on the Bear Prusa Upgrade. If you are planning on going the Bear Upgrade route, which I would strongly suggest, buy: 1) HiWin, not the chicom rails and linear blocks (H and C). Chicom are no where near as good. C were out of stock and had to mix in match 3 to get one 'good enough'. HiWin "just works". 2) Extruders are Bondtech Prussa Mosqutio Kits. Dont bother with the E3D v6 based Prusa upgrade kit. Not worth it. Go for the mosquito. Much better results. BUT pay for the SLS printed parts. MUCH better quality. For other details or links to parts drop me a note. Photo 1 --- Rebuilt Prusa i3 MK3S with the part showing the time. Photo 2 --- Bear Upgraded Prusa i3 MK3S and UPS in background for both machines. Photo 3 --- Rebuilt Prusa i3 MK3S new stepper motor support. Photo 4 --- Rebuilt Prusa i3 MK3S new belt tensioner support.
  17. I figured I share how I finish the edge binding using a cylinder bed with regular folders made for flatbed machines. This way I can without any mechanical changes to the machine share binders from my flatbeds with the cylinder bed otherwise I would probably have to buy a new needle plate, presser foot, cover arm and use 90 angled folders at about $200 CA. Equipment: i) Kobe LS-1341 10" cylinder bed ii) V138 top and bottom thread iii) Mini 8" x 8" mini flatbed conversion table iv) 3/4" (19mm) raw edge binder made for flatbed machines which is inexpensive less then $20 CA The photos show 3/4" (19mm) edging on 3mm thick material, not perfect finish but will stop fraying. All comments welcomed. Stay Safe, kgg
  18. I used a spray bottle of good auto de-greaser in combination with diesel fuel to get rid of the gunk in a Pfaff with good results. I used a couple of old toothbrushes to scrub those hard to reach dirty spots. Then basically gave it a good flushing / bath with regular sewing machine oil before doing a full oiling. Did most of the cleaning outside because of the diesel fuel. I have found diesel fuel when let to sit for a day to be a good fluid for freeing up seized parts. kgg
  19. That is excellent work. kgg
  20. Yes, I had to get another 100 yd spool of 3/4 " Polyester Twill Tape to complete the edging of some 60 - 3' x 3' puppy incontinence pads. I still don't have my edging tape machine fully up and running. Price was reasonable at about $16.00 for the spool. Their complete list of products is at http://amefird.ca/products/ . I do like the A& E stuff they put some engineering into manufacturing a quality thread but you do pay for quality. kgg
  21. Why not call American & Efird Canada they are not far from you and discuss your needs / wants. Their products are made in Canada as well as the US and they should have a thread to meet your needs like maybe their Sunstop line. Prices are good, delivery is fast and most importantly a quality / consistent product. My V138 thread and edging arrived in under 24 hours. kgg
  22. Thanks dikman, I actually really like the little "Tinker" and the 3d printing helps me solve problems inexpensively on all my machines as well as my other interests. kgg
  23. To help with broken thread in seams and reduce the thread from cutting through the material I would consider the seam construction possible use of a reinforcing backing material. Maybe using a semi flat or flat seam construction. Just a thought. kgg
  24. Some other resources would be kijiji.ca for your province (used machines). I don't know how close these would be to your location but Longview Leather in Longview, Alberta carry the Cobra lineup, Mac 1 in Calgary, Alberta carry the Juki and Reliable lineup. I guess it depends on what you want to sew (thickness), what size of thread and of course the dollars you want to spend. I do agree that adding a flatbed attachment to a cylinder bed makes it much more versatile but each type of machine has a purpose. If you are sewing mostly items that are better suited to a cylinder machine 90% of the time and only need to occasionally use the flatbed feature then buy a New cylinder machine and later a Used flatbed machine. For me it was Flatbeds (Juki 1541S, Juki1181n, Pfaff 1245) first then Cylinder machines (Consew 223, Kobe 1341) somewhere in there I a got a Chinese Patcher. Stay Safe, kgg
