chuck123wapati
CFM
Everything posted by chuck123wapati
  1. these steels can be screwed up just as easily and produce bad blades it is a matter of proper heat treatment that makes the blade. As well most folks don't have the equipment to test the hardness.
  2. Not always lesser quality steel maybe not as good quality control in thier manufacturing processes but the steel is only a fraction of the equation in making a good blade. I choose and buy old blades quite often but buying a used blade that is still good is also a crap shoot, you dont know how well the old steel has been taken care of it could d have for example been ruined by heat already, left rusty for way to long so that you cant get a clean edge or whatever. When choosing or bidding on used blades i always take extra time looking at the pics for any wear or misuse, in the case of knives, such as this one, with no collector value I am even more particular. This is a good first blade to experiment on it certainly has seen some use but should still be servicable.
  3. Ditto what Dikman said also what Frodo says clean it up and have a new edge put on and enjoy it, your way over thinking this whole process. After the new edge is on you can then more easily learn to keep it sharp.
  4. thats over the top! i like the way you did the buckle end.
  5. Awesome indeed i think cutting out all those washers is going to be a pain but i guess not as bad as fleshing out and scraping the hide was lol. i have a hole saw that should work nicely it uses a drill bit in the center so two jobs at once
  6. Thank you i guess i'm getting the hang of it. Thanks
  7. So did you finish this maul? If so how is it holding up? I am thinking about making one.
  8. "if the cost of going that direction is affordable" that's the rub, new ones are only 70 bucks so how much does a guy want to spend?
  9. a prior thread that might help also.
  10. after that final toothpaste polish he will be able to do one handed push ups lol i wouldn't use electrolysis at all i use vinegar fast easy cheap and non toxic lol and works as well as anything. I would leave the pits alone and leave the patina you will never make a new knife out of an old one just one that is cobbled up looking. if the edge is pitted then no filler will fix that you will need to regrind the edge and that will take some power tools and alot of water not to ruin the temper. Any collector value is long gone if its that rough if there ever was any so you can do about anything you want to the blade shape. Good luck and post some pics when you get finished.
  11. you might as well leave it natural after using neats foot or any of the other methods it will be very dark. especially after a few years of reapplying. Beautiful knife by the way!
  12. there is a lot of info here, you can find about anything by searching the threads i have seen many on watch straps. welcome to the forum.
  13. Native Americans leather turned out white due to the tanning method, they used the brains of the animal to tan the hide then it was smoked to help with water resistance which turned it a light tan color..
  14. gun shows, and bulletin boards always get some business especially at the local shooting ranges. Take a drive and hit all the ones around your area, the trips may even be deductible.
  15. Right on that is an awesome bag and is every bit as nice as the car its going in.
  16. that came out pretty darn nice, i like it.
  17. its friggin beautiful but be careful selling other peoples logos.
  18. i may have to look into one of those didn't know there was such a thing lol.
  19. i use the heat shrink on my home made stamps works fine.
  20. welcome and you are one talented hole puncher for sure that is awesome work friend.
  21. wow! that's some nice work indeed.
  22. or you/he could dip the one he has in that dip and grip rubberized coating. https://www.amazon.com/Grip-Rubberized-Plastic-Coating-Green/dp/B016J1ND9I
