TomE
Everything posted by TomE
  1. I did receive some HO sides in 2021 that were puckered or had more defects than usual. I was told they were behind on production because of an equipment failure at the tannery (a large splitter? was being repaired) so perhaps they were sending out leather that was less than usual quality. Their sales manager answered my questions on the phone. Since 2021 I've had top quality HO sides, purchased from Springfield Leather Co. SLC will accept returns of leather in good condition. I recently visited their store and they opened bundles of bridle sides for me to inspect. Almost all of them were excellent in terms of consistency and minimal defects. Not sure if your distributor is an authorized dealer or getting HO leftovers from other sources.
  2. UHMW polyethylene is different from HDPE. Here is one explanation https://plastichowto.wordpress.com/category/uhmw/#:~:text=One note about the static,would be the better choice.. I bought a 4 x 8 ft sheet of white HDPE from Menards and am quite happy with it.
  3. Agree with @MtlBiker. I am grateful for the wisdom @Wizcrafts regularly passes along. Thank you!
  4. Handsome work! Strap and guitar are beautiful.
  5. The white sheet also brightens up my workshop for these old eyes. I bought 1/8" HDPE in a 4' x 8' sheet at one of our big box stores, Menards. Had to drill and counter sink the holes to screw it on my plywood bench. I was told that the HDPE can be sanded if it becomes heavily grooved from knife cuts. So far it seems fine.
  6. The failsafe is to stitch mark up to the hardware and begin machine sewing 4 holes away, leaving long tails of thread so you can hand sew back to the hardware. As mentioned in my triple stitched halter methods, I have used this method to sew tightly against the 3 rings on a halter. More recently, I've been inserting a wedge shaped welt next to the rings so that I can machine stitch right up to the ring. Two tips -- Be sure to include the welt when wet forming the leather around the ring to minimize the bulge that the machine has to climb. Also, I am having very good results using the narrow pressor foot setup from @Patrick1 at Hennigan Engineering and Precision. These feet climb the change in material thickness without a lot of hands-on manipulation. The Cobra double pressor foot is a bit more slippery in my experience with sewing bridle leather. I am using the narrow throat plate and feed dog from @RockyAussie for these heavy projects (2-3 layers of 9-10 oz bridle leather). I use the extreme narrow plate/feed dog from Hennigan Precision when sewing lighter projects with 138 thread and a #21 needle. For a halter with a round leather throatlatch, I still sew the gullet end against the throatlatch by hand in order to sew tight against the loop that wraps around the throatlatch.
  7. That's a winner! Looks good on him.
  8. Thank you, @Klara. I appreciate it. Thanks, Jonas. Two changes that made me happier with the plough gauge. I finally put a small bevel on the backside of the blade that relieved pinching of the strap against the guide. Also I covered my bench with a sheet of HDPE which allows the plough gauge to glide over the surface. The base was apparently dragging/digging in on the plywood. Also, the HDPE is a great work surface for cutting out leather with minimal damage to the blades.
  9. Pretty work! I am curious what you mean by "to be like what the 19th Century called bridle leather." Different than modern bridle leather?
  10. Bridle and harness leathers are veg tanned and stuffed with oils and waxes to add finish and some water resistance. You still need to oil and condition the leather with use - as for maintaining horse tack. These leathers tend to be expensive and are correspondingly high quality tannage with a dense structure. I have been very happy with Hermann Oak bridle leather that I buy from Springfield Leather. You'll need a splitter if you need different weights for your project - in order to make everything from the same (dyed) hide. Springfield Leather can do custom cutting and splitting. Batz Corp has a number of aluminum clips similar to what I think you're describing. It's easiest to find their products in the catalog, which can be downloaded here https://www.batzusa.com/catalog-download/. I would call them for pricing and availability. Their website is hard to navigate.
  11. This video has some tips that were new to me for even dye coverage and eliminating rub off, particularly near the end of the video. Best of all, he says there are no firm rules and many ways to get a good result.
  12. A two part article on a braided rawhide saddle horn cover was published in the 2003 Mar/Apr issue https://leathercraftersjournal.com/product/2003-volume-13-no-2-mar-apr/ and the May/June issue https://leathercraftersjournal.com/product/2003-volume-13-no-3-may-june/ of the Leather Crafters and Saddlers Journal. Both back issues are available at their online store. See content descriptions at the links above.
  13. I wouldn't think so, but I would test how the CXL leather burnishes and blends with a backer strap. If the edge doesn't look right, you could use the horse hide as inlay for a veg tan belt.
  14. I have exactly one #245 punch and it works great in 9-10 oz leather. Like all Osborne tools, it needed to be sharpened when new. I'll be buying more sizes of the #245, maybe as the #K-245 set of belt punches. I agree that the #147 punch looks like it has more taper and might be best for lightweight leather. I don't see the #145 punch on the current website https://www.csosborneleathertools.com/category/punches.
  15. Although horse hide is denser/strongmer than cow hide, 5/6 oz might be a bit lightweight for straps/belts. If you use 2 layers you could make a raised leather belt. There's more information on these leathers at the Horween Leather Co website. My understanding is the Chromexcel tannage is pull-up leather. Is the football dimpled leather CXL tanned cow hide?
  16. Very nice work!
  17. After lots of buffing, I would apply a light coat of neatsfoot oil, let it soak in for several hours to overnight, and buff some more. What weight leather are you working with and how did you apply the dye?
  18. Beautiful craftsmanship and LOTS of stitching. How are the bells attached to the strap?
  19. Thanks for your reply. Would welcome a digital or printed copy.
  20. Yes, I haven't found it. I read that Weaver Leather had sold this book previously, but they weren't able to locate a copy.
  21. Made a few things while working on a matching bridle. Pushing the envelope with black tack (dressage) instead of my usual brown (jumpers and hunters). HO bridle butt with hardware from Weaver (stud hooks, rein buckle) and Abbey England (stirrup buckles, rein grips). Oh, and I am finally on speaking terms with my plough gauge so I thought I'd show it.
  22. Don't know what machine you're using, but I saw a suggestion for #92 thread in a 441-type machine: reverse the bobbin in the shuttle so the thread draws out the "wrong" way to increase friction and tension.
  23. Since the pandemic/supply chain shutdown, I find it's best to call Batz Corp to check price and place orders. Most of their items are listed as "quote" which means they've been on back order. They are well stocked at present.
  24. Great looking work with lots of character from the start. Would be fun to leaf through these at their 50 year anniversary, but that will be for someone else to do.
  25. https://campbell-randall.com/product/fcf-317-fenice-colorfast-leather-dye-317-metallic-pearl-1-liter-1
