fivewayswelshcobs
Everything posted by fivewayswelshcobs
I could be interested. I'm based near Warwick uk
I've used the small clamp on led lights from IKEA.
Where abouts are you and have you got pictures?
Replacing girth straps on jumping saddle
fivewayswelshcobs replied to TomE's topic in General Saddlery Discussion
I use the rawhide girth straps as well. -
Dog collar bling: spots or rivets?
fivewayswelshcobs replied to ButtonLady's topic in Collars, Cuffs, Leashes and Leads
I would never put metal prongs against any animal so all my harness and collars etc is lined as is most of what I've seen . The only evidence of no lining is some which has been botched by an amateur or foreign made. -
Leather Tack repair questions
fivewayswelshcobs replied to KeriYokie's topic in Leatherwork Conversation
Personally I have some elastic already made up with the chapes so an easy swap. I hand stich using existing holes. If buckle OK will reuse but not always worth it.- 4 replies
- tack
- english bridle
(and 2 more)
Bakers in Colyton Devon, I also use Cracks, Metropolitan and Abbey (Sedgwicks) Sorry forgot Midgley in Cheddar
First Show, thoughts and questions...
fivewayswelshcobs replied to austinious's topic in Marketing and Advertising
I've been been selling leather goods at craft markets for around 15 years people do like to see me hand stitching, it is a good way to start a conversation. Belts out of English bridle leather along with dog collars and leads are the best sellers. Key fobs made from off cuts also sell especially bright colours. Purses, wallets etc ok but everyone seems to compare them to mass produced. Most of my orders are for made to measure items - it is impossible to carry everything possible in stock, it is quite easy to make up afterwards and post, that way I can offer a wider range of colours, widths and buckles so make it individual. I rarely stamp items because of the leather I use but did one show with a chap carving bags , he had quite large group watching all potential customers ! I hope this year is better and easier than last 2 years with more customers and fewer restrictions. -
Abbey England sell Tilbury tugs and I believe they ship to the USA.
Any reason not to use PVA instead of contact cement?
fivewayswelshcobs replied to Rocky143's topic in How Do I Do That?
PVA glue is very useful on lighter leathers especially before stitching when contact adhesive is too much and repositioning of layers is often needed. It also has the advantage if it drys it can be rewetted and will stick again. I wouldn't use it on bridle leathers or saddles except when added to edge stain to finish the edges - it saves time and gives a good finish. -
Halter from the old German book on saddlery.
fivewayswelshcobs replied to Mulesaw's topic in Saddle and Tack Accessory Items
I'd swap your workshop for mine anyday. We are about as far from the sea as you can get in the UK. -
How to make padded crowns
fivewayswelshcobs replied to BaroqueLeatherGal's topic in How Do I Do That?
Commercial ones may be pressed out, most of us either make a template or cut the head using measurements. Experience will help decide which to use. I tend to cut directly if one off. To make pad use the head shape but keep the edge of the pad very close to the front as there is no point shaping around the ears then extending the pad 1/8th inch forward hence the pad showing more at the back. Remember when covering the pad allow for the thickness of the soft leather so the foam may be same or slightly narrower than the head itself. Remember to taper ends in at the ends for a good finish. -
Cut taper to top strap, glue then stitch. Once stitched trim back piece using top as guide by cutting straight down along the edge. Finish the edges.
Dog collars - always worked flat?
fivewayswelshcobs replied to Klara's topic in Collars, Cuffs, Leashes and Leads
I always work flat but usually trim the padding to length at the end of stitching, ie before stitching over the end. Keeps the padding flatter rather than forcing it to be the same length. It still lies flat but much less wrinkled. -
What are you looking for?
Fish Leather Have You Tanned It Or Used It?
fivewayswelshcobs replied to Otzi's topic in Leatherwork Conversation
Bought mine in Iceland, usually use it as an insert for colour and texture. -
French style hand stitching process - where is the mistake?
fivewayswelshcobs replied to justanil's topic in Sewing Leather
Hi, Justanil, From the pictures your sequence looks OK but the thing that struck me is it looks like you're stitching downwards rather than fairly level to the floor. A slight slope is OK but the pictures make it look very awkward. Yes you need to look down on where you are stitching but also along it (technically you shouldn't even look at the backside but most of us do). The main thing to get even stitches is to practice putting the needles through in the same place everytime. I was taught in Walsall always to sew towards you holding the awl and making holes as you go and not putting the awl or needles down as everytime you did the stitch altered. It is worth watch some of the stitchers on YouTube and then practicing the method that suits you the best as we all stitch slightly differently depending on where and how we learnt. I hope this helps. -
English stirrup leather buckle - unusual?
fivewayswelshcobs replied to Xanthoria's topic in Saddle and Tack Accessory Items
Have you looked at the T bar stirrup leathers, instead of a buckle there is a T bar fitting , when in use a cover slides down over the fitting to help protect the saddle. Abbey sell the fittings. I've not used them but many people do to reduce the bulk under the leg. -
Try Dave Budd, saw him at Torm last year and kept his card (www.davebudd.com). UK based and the knives looked useful.
You can also buy leather for stirrup leathers as strips from Abbey which reduces the cost, no idea what shipping would be.
- 14 replies
- english saddle
- stirrup leathers
(and 2 more)
Perhaps I'm cheap but I use snips that were made for gardening as much better value than leather ones , mine came in at about £3 but nice and sharp.
Yes heat the creaser. It needs to be fairly hot , I use the old wet finger method to test the heat if it doesn't feel hot it is too cool and if it sizzles it may be hot enough, alternatively use a scrap piece of leather if it burns through the top layer it is too hot etc. Mostly it comes with experience and again practice. I would use a clean flame as anything that can produce soot will stain the leather. I have used a small blowtorch before now but currently use a camping gas stove top as it is easy and controllable (the blowtorch tended to get too hot very quickly)
The picture of the saddle hanging up gave me best laugh I've had for weeks. It shows what can be done when challenged. Personally I have done many by hand without dropping the panel and a number where you have to take the flap off as there is no access but have never tried saddle suspension!
- 16 replies
- english saddle
- knee rolls
(and 2 more)
To clarify the 2 hours I normally do a belt in it is 8 or 10 to the inch and sewn traditionally with the awl and needles held all of the time and leather stitch marked. I may add it has taken some years to get to this speed and lots of practice and I also like hand sewing.
Usually one thread per side and 2 hours.
