TomG
Everything posted by TomG
  1. We've used the acrylics from Hobby Lobby with no issues. I have a key fob that my wife painted a dragon on using the $1 a bottle stuff. I've carried it in my pocket daily for 2 years and it still looks good.
  2. Yup. Use some Denatured alcohol or rubbing alcohol. You can even use water if you have to.
  3. Believe it or not, 2 things work really well, but are a but awkward to apply. The first is liquid latex rubber. I got mine from Hobby Lobby. It's kind of pricey at $19 for 16 fluid oz. They often have 40% off coupons that help. It has a VERY strong ammonia smell and has a shelf life of maybe a year or so. Then it begins setting up in the bottle.. like contact cement does. The second is rubber cement. Sounds weird, but it works just like the latex rubber and a heck of a lot cheaper. I apply a couple of coats. Most of what I do is stamping and I apply it with a brush. I have some that I only use with the rubber cement. Clean up with DA or Acetone. If you get it where you don't want it, let it dry and scrape it off with an xacto. You don't want to scrape the leather if you can help it. As for the awkward to apply part, you need to try to get it down into the recesses of the stampings or cuts. If you don't, the dye will flow down into the grooves and seep under the resist at the edges. And of course, you probably don't want to dip dye as you have a good chance of seeping through from the back. Good luck and let us know how it works for you.
  4. There is a 2 page thread about dip dying at the link below. It goes into lots of detail about different techniques and ideas.
  5. Tandy in Atlanta has it, although it's not in the catalog. It is the Pro OIl dye
  6. They have a walnut dye. Looks pretty good
  7. I generally dilute around 4:1. But, it also depends on the color of the dye and the color you want to achieve. For example, Red. Most of the time, I've cut it 2:1. maybe a tad more. For Pink, it's closer to 20:1`. Also, I've recently discovered that the Oxblood makes a better Pink than the red does. In addition, every time I make a new batch, I do 2 things. 1) I use an empty container and measure the alcohol and dyes and mix it in that. I then pour it into my dip tanks. I usually just mix enough to fill the tank. I don't pour the full strength dye and alcohol into the dip tank and try to mix it. You really don't know how much room you have left in the tank, unless it's totally empty or it's got graduations on it that you can still see. Say you figure that you need 15 oz to bring the level up to where you want it. So, at 4:1 you need 12oz of DA and 3oz of dye. If you really only needed 12oz, you've got to fiddle with how much DA you've poured and how much room you have and mess with adjustments. Just get an empty screw lid milk jug and mix it it that... and 2) I cut a piece of whatever side I'm currently using the most and do a test dip. As others have said, every side can dye differently. A test dip let's you know where you are right now. I also have some Preval glass jars I get from Tandy and some air brush jars. I can use a syringe to make small test samples and figure out ratios without a lot of waste. I know it's kind of anal, but I spend half my time, it seems, answering customers questions on colors. So I like to know that when I dip 50 straps, they will all look reasonably identical. Play with it and to test strips at different dilution rations. And for your sanities sake, write the results down. In 2 years when you need to make a duplicate of an item that you make Baby Blue, you can look up the mix.
  8. At the very least, this is an inconvenience to him. I'd be willing to bet that he will be back under another name/ID in short order. People like that are hard to stamp out.. like roaches... As for cradom's note about Pinterest, I believe you can post most anything, as long as you do not claim it to be yours and leave or note the source or owner of it... But I may be wrong. Someone correct me if I am.
  9. I picked up this Craftaid today and in my opinion, it's a great aid. I haven't worked with it but a short time, and noticed a couple of issues. 1) For best results, make sure that the stamp you are using is sized so that the ends do not overlap and that they don't leave hardly any gap. If they overlap, you get depressions at that point. If they leave too much of a gap, it leaves the grid line visible. 2) Use the lightest impression that you can still see the grid lines. 3) Make sure you have good lighting on all sides of the stamp to help with positioning the 4 points of the tool. Other than this, it seems like a good item to have in your tool bag. Thanks to JLS for the info.
  10. Duh. Now I feel stupid. I've seen those for years now and never even though of using them for straps. For some reason, I guess I though they were for things like folders, covers and larger items. Thanks for the info. I'm going to pick one up and work with it.
  11. I had the Consew model with that knob and I could not control the speed at all. It was either on or off. I took it back and got the CSM-1000. Much better, but it still needs the reducer pulley to make it truly slow.
  12. It IS impressive. So let me ask again. Is there a technique that helps keep the stampings so perfectly aligned? I use a set of dividers and a square for some on my stuff, but it would not work well for this type of pattern... Thanks
  13. I always struggle with keeping the stamp pattern lined up . What method do you use to keep everything lined up?
  14. I always try to make them tight and make sure at least 1/2 of the thread length is engaged. Where did you get the clamp? I'm using one I got from OTB. It's a high impact plastic material (can't remember the name) and works pretty well. But the rubber stop on the bottom is tearing and I don't know where to get a replacement.
  15. I have a 24" Laserpoint vinyl cutter and have tried to cut some 7oz vegtan on it with moderate success. Have any of you had good luck using one? I was able to cut about 1/2 way through, but trying to cut all the way caused the blade to hang in the cut and lose registration. I used high pressure, 60 degree blade, multi cut, and had it glued to a backing sheet. Anyone else have experience with it?
  16. What tool do you use them in?
  17. I would rubber cement the 2 halves together and use a pricking iron through both at once.
  18. Has anyone tried one of the Ozone generators to kill mold? On anything (not just leather )?
  19. I need some expert help here. I have the Tandy High Tech Leather Splitter and it has been great for years. Today, I needed to split a 3" wide 20" long strap of 8 oz down to 6 oz for a repeat job. I had used it to do this a few weeks ago. I have noticed it dragging just a tad, so I took off the blade to strop it. As I was putting it back on, I noticed one of the roller posts not touching the side adjustment screw. So, I loosened the nut and turned it in until it just touched and secured it. Now, it is splitting fine for a very short bit and then shearing through the strap an an angle. Repeatedly. I moved it back out but it's still doing it. Stupidly, maybe, I tried to adjust them both so that the roller posts are equal distances in. I've started with the blade edge just past the center of the roller and worked it out until it's just before the center. I'm at my wit's end. I have to get this job out. Any clues? Thanks
  20. Going to PM you about this
  21. I disagree with your blanket statement. It is not that black and white. If the package is insured, the shipper is responsible for recouping the value of the lost shipment. In that case, yes.. the seller should replace the items at no charge. But if the buyer is offered insurance and declines it, that is their gamble and they take the hit. Once it is accepted by the shipper it is totally and completely out of your hands and control. While I sympathize with the buyer's loss, it is not my fault that it was lost. Why should I HAVE to take the hit. Before you try to rip my head of... Personally, I will, in general, make the order over and ship it. But, don't tell me I have to if they have declined the minimal cost of insurance. And NO.. I do not and will not include the shipping costs into the item price. It's too bulky and unwieldy to manage with a wide range of products and destinations. Especially international. $8 to Canada, $16 to UK and $23 to Australia. I put the weight into the shopping system and let the customer choose how they want it shipped and if they want insurance. I add $1 to cover the cost of the envelope/box and the system adds the exact cost of the postage in.
  22. Crying??? there's no crying in leatherwork!!!!
  23. Try 10% and 25% dilutions. I think I settled on 25% but don't remember
  24. Actually, for the money, the GoldStar is not a bad little press. I do up to 200 double caps a month and it had been a real time-saver. You just have to be aware of the little things like using 9mm dies for Tandy medium double caps instead of the 8mm that Tandy claims their rivets are. And their Line 20 dies don't fit Tandy Line 20 snaps without modifying the dies. But those are really Tandy issues and not GoldStar. But, if I was going to be setting caps for hours a day, I'd definitely go with a better quality press and die set, for the durability, if nothing else.
  25. Did almost the exact search years ago when they were discontinued and all I got back were references to Tandy and it's various distributors. Good job finding them
