Ferg
Contributing Member
Everything posted by Ferg
  1. Next question: Do you not care how much you make, monetarily, while making these zippers? Or, is this just something you want to try? I am guilty of trying all kinds of way out manufacturing ideas. Zippers require exceptional accuracy. Probably why they are made on rather sophisticated machinery. I too have most of the hand tools, using them for repairs, not manufacture. BTW: You can buy certain parts easily. I have never even thought of buying "teeth" separately. If I need teeth for a repair, I take them from a piece of zipper I have cut from another. Ferg
  2. I am curious. Do you mean that you wish to buy each part of a complete zipper and manufacture your own zippers? If this is true, Check the web for a few of the many videos on how they are made and what machinery is involved. Ferg
  3. JANE, Congratulations on your new digs. I have "stuff" in a shed that was to house only my glass business to begin with. Now it includes some of my sublimation equipment plus leather equipment. You have seen my "Leather Room". That will give you an idea what the room in the shed looks like. LOL Ferg
  4. You need a spanner wrench. The shaft has a centering hole in the end. Is that what you are referring to? Ferg
  5. Ohio Bag Ferg
  6. PhillyRock. Not quite! Ferg
  7. I have very little "spill" over the edges anymore, took awhile. Lol The manner you hold the tool alleviates most of that. I like my paint to be a little on the thick side and try to only make one swipe without going back over what I done previously. This stuff dries very fast so I find it best to correct any little spots on another application of the paint after it dries. I use an old toothbrush to clean the roller after use with cold water running over it. Warm or hot water sets the paint in the grooves. I have tried three different brands of the paint. Giardini is the best in my humble opinion. Ferg
  8. Of course I have a comment. If you wish to sell a product it is usually a good idea to show photos when it was used properly. Ferg
  9. It was meant as a compliment. "Cute" idea. Ferg
  10. I have never had marks left behind with my brass rollers. Perhaps you aren't putting enough paint on the roller or the paint is too thin. Like everything else worthwhile, it takes a "Little Learning". Ferg
  11. Your carving looks like a stamp. Ferg
  12. Unless you intend to do high numbers I would get the roller first. Appears to me that you rounded your leather edge before applying the paint. Plus you didn't continue completely to the end leaving a portion square. I tried the spatula at first thinking it was okay until I got the tapered roller. I leave all my edges square/flat. I then seal with a clear sealer sanding after every application with nothing rougher than 600 grit sanding cloth. Number of applications of color depends largely on how heavy you apply and how smooth and non-absorbent your choice of leather. BTW: I think the design of the rollers gives the rounded effect to the flat edge without the actual round shaping. Ferg
  13. GENGADO, I am right here!!!!! Your staining isn't bad. Practice different ways of application. If you don't have an airbrush you can use try different materials. Stitching is something that can go "wonkie" after doing it for years. Concentrate on your stitch line which I imagine you have free handed. A makeshift tool to mark that line before stitching will do wonders. I like your idea for the pocket shapes, they just need some refinement. Don't try to be too fancy with the shapes and cuts. Simple is beautiful also. Keep at it you are doing fine. Ferg
  14. I ordered product from RUBBER SHEET WAREHOUSE. In Alhambra, CA 91803 Item# NSAPRAB-1-16IN-062-7. 1/16" Neoprene Sheet All purpose rubber. Believe I found it in smaller pieces from other sources. Ferg
  15. Definitely not. I will try to locate my order when I bought the material. Will post when I find it. Ferg
  16. Check all the paths where the thread travels for what you see on your machine in these photos. Some times you can clean them up with a jeweler's file. Best? Get the new parts from Bob Kovar. Ferg
  17. I buy closed cell rubber sheet 1/16" thick, it is black/charcoal in color. I use spray can glue. On both the foam and the leather. Cut the foam so it is about 1/8" shy of the mouse pad all the way around. I apply the foam to the leather immediately after spraying so if I need to adjust it I can move it slightly. Allow to dry over night. Works great. Ferg
  18. How big are your friends coffee cups? You have some work to do on your layout and design, keep at it. Ferg
  19. I have never put a stone to either of Terry's knives. I strop every time I pick them up and also several times while using. There simply could not be a better knife available. Ferg
  20. I have one of knipper's round knives. I use it mostly to "skive". Terry also made two special knife blades for me. Above "TOP OF THE LINE." FERG
  21. Looks to be very thin goat or calfskin to me. Ferg
  22. Good grief!!! How could anyone use that tool properly with the barrel full of paint? I keep thinking of what a mess that would be. I have three or four of them little tools among others. What you describe using is what I use all the time now. Best there is. Ferg
  23. Very ice. You should be proud!!!! Ferg
  24. Last post referring to Rustic. The photo above is characteristic of your sloppy immature idea of perfection. I really feel sorry for you. Your stitching is just crappy and your workmanship is horrible. Why don't you start your own Forum in Paraguay and just quit posting in this forum. We do not appreciate your asinine attitude. I have had it with you!!!!!!! Ferg
