WIP. The first attempt to emboss the human face
Northmount replied to ABHandmade's topic in Figure Carving
Really fantastic work. Inspiring to us all. I've only done a small amount of figure carving. Will take me centuries to get to your level of accomplishment. Tom -
Knife sheaths
Northmount replied to Vaelloc's topic in Gun Holsters, Rifle Slings and Knife Sheathes
This question is asked over and over here. Resize the photo. Some phones will let you do it just by selecting the size before taking the photo, others will let you do it during an upload, others will have to run a resizer app to do it. Look at this forum http://leatherworker.net/forum/forum/33-computer-help/ Tom -
If you start marking out your stitching at both ends of a straight run, you will likely need to adjust the distance between stitches near the middle so it looks like they are evenly placed instead of having a very short stitch or long gap. It also works if you mark from one end, you can adjust the spacing at the opposite end to make the stitch lengths fit nicely. Looks like you just lay the template over your stitch line to mark the remaining stitches. Tom
Orders to ship
Northmount replied to Mattsbagger's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
If you hover over the username or avatar, you will see the option to hide the user's posts. I assume that on a phone, you would tap the username or avatar to pull up the same choice. Edit: @RusticLeatherShop has been warned and placed under moderator review. All his posts will require moderator review and approval. Tom -
If you resize photos to 800 x 600 or even 1024 x 768 pixels, there will be no problems uploading as many photos as you want to in a post. If you do a little checking of what size your photos are before hand, and what you can or need to do to make them fit, all should go smoothly. An old saying, "An ounce of preparation is worth a pound of cure" certainly applies here. Photos sized above are more than adequate for most things you want to post. Also reduces upload and download time for those people who live on the fringes of the internet or have otherwise limited internet speed and service. Still lots of places in the world with slow access. Tom
2 industrial clicker presses for sale - Swhabe 25 ton, Fales
Northmount replied to rfkoen's topic in Old/Sold
@rfkoen You have responses that you should be responding to if you are really serious about helping sell these clickers. When you make a post like this you should be checking back at least once a day. I see you haven't been back here since Sep 15. Tom -
@RonJr When the thread is laying on the top, there is too much top tension, or vice versa, too little bottom tension. But first make sure that the machine is threaded properly, especially where it breaks the thread. Are you holding the thread tails when you start sewing a seam? If not, you need to as it can result in a birds nest on the bottom side and result in breaking the thread, jamming the needle, and even bending or breaking the needle. The tension would also be lost for the first several stitches. Tom
Leave it alone for 2 or 3 days to allow the oil to fully disperse through the leather. Areas that have been tooled soak up a lot more oil just due to the rougher surface that collects more oil than a smooth surface. In the future, oiling from the back side may help avoid this problem. Always go easy on the amount of oil you use. Hard to remove it if too much is used and it gets soggy! Nice job! Tom
Note also that these are two different wallets. The first one has the pouch zipper facing into the fold. The second has the pouch zipper facing out. The second one is similar to an accordion purse/wallet. I quite like the second one even though it is more complicated to put together, especially the accordion gussets. Tom Edit: Here is a file that may help. I don't recall where it came from so I can't give credit for it.Long Wallet Templates.pdf
When using a light dimmer (triac) or rheostat to control the speed of an induction motor, the motor will tend to run hot. And the slower it runs, the lower the cooling air flow through it, and it runs even hotter. The motor wants to run at a little lower than synchronous speed (for a 2 pole motor on 60 Hz, that is 3600 RPM, typical running speed would be about 3450 RPM under normal voltage and load). If not supplied with adequate voltage (and current), it can't build up normal speed, therefore can't build up the normal back EMF and will draw higher current, run less efficiently, and run hotter. Without adequate cooling air flow, it then runs even hotter. So could run at moderate speeds with a light load. If it is getting too hot, increase the speed or reduce the load. If you let the smoke out, you will have to replace the motor. Fan speed controllers (triac) will last longer than light dimmers on an induction motor. Always pay attention to the electrical ratings of the triac and the motor. Tom
I never said that white wood glue (PVA) doesn't work. If you re-read, I said it is not a contact cement. Depends on how you want to glue things together. If you have an item that is difficult to clamp until the glue is set, then contact cement is best suited as it grabs on contact. I have used both, and still use both, but with different expectations and requirements. I also use superglue on occasion and leather tape too. Choice depends on what you are making and how it has to be assembled. I made the assumption the shoe glue he is referring to is likely a type of contact cement, whether that is accurate or not. Tom
Lisa Sorrell does a lot of skiving when making her custom boots. She has skiving knives for sale here https://sorrellnotionsandfindings.com/?s=skiving&post_type=product She also has a couple videos on her youtube channel Tom
- 23 replies
- skiving
- skiving knife
(and 1 more)
White wood glue in general is not contact cement and does not perform as well as contact cement during assembly. Contact cement when properly applied and used, adheres upon contact. Parts have to be placed accurately as you may not be able to separate the items again without damaging them. There are lots of threads here about usage of various glues, also many resources on the web that you should review to better understand the types and usage. Tom
Michaels has various sizes of wooden boxes. Tom
Apology accepted. When we are dealing with text only communication, we can't see the person's face or body language or hear the nuances in his voice, so literally 3/4 of the conversation is missing. My apologies to you as well. Differences in cultures can result in huge misunderstandings. I have a friend from Bulgaria. In her culture, nodding the head is a no, shaking the head is a yes, completely opposite to many other cultures. Tom
Really! Your comment is not related to the intent of my comment at all! If you have a beef with the carving/art work, you should take it up with the OP, not me. Tom
Reminds me of a cover photo on the front of a POST magazine many years ago. I like your art work. It is your perceptions that count. It is not supposed to be just like a photo. Tom
Pretty sharp looking spur straps. Very nice. Tom
URL for above https://www.etsy.com/ca/shop/PFLeatherGlass Tom
How to delete photos from my gallery
Northmount replied to JohnnyTremendous's topic in Computer Help
Photos deleted and albums hidden since I can't delete them. Tom -
When you are viewing the gallery, do you see small tick boxes in the upper right of each photo? If you tick them, do you see a bar across the lower part of the screen with a garbage can? If so click each pic to be deleted and then click the garbage can. I'm not sure if you have this access. Try it and see if you do. Else let me know and I will delete them for you. By the way, the items look quite good. No need to be embarrassed. On this site, members in general do not have permissions to delete posts, so I assume that is the problem you are up against. But moderators and administrators can. Let us know if you need help with this. Tom, another Calgarian -
Take Wiz's advice he gave some time ago. Start a new thread with your specific machine and problems. Take photos of the problems you are seeing with the stitching and any part of the machine that is causing you issues. Post the photos. Take video and post on YouTube and link to it. There are several people who will be quite willing to help you. Tom
- 6 replies
- walking foot repairs
- overhaul
- (and 9 more)
Kitchen knives are very brittle and snap or nick easily. My SIL won't buy anymore, low or high priced. Tom
