Everything posted by Doc Reaper
I understand what you are trying to do, I made a friction sheath and "cured" it by the method you speak of. There's an oven you can make using a type of heat lamp, I believe it's a radiant lamp, and the build is fairly easy and doesn't cost that much to make. The interior temperature is around 120 to 170 and you might be able to search for it on here by looking for "heat box" or "drying box"
Common sense just slapped the nonsense from my thoughts. I went over to Hobby Lobby (cause I'm an adult) I purchased six 10 ounce bottles to use on the airbrush. Why waste a large air compressor
I could thin this slightly and actually use an air brush I already have
Has any one tried this method? Found this picture on Facebook, the owner might be on here, I'm going to find a finer spraying nozzle and give it a go!
ok, I see Canada also has the smarts California does. A business purchases let's say 2 or 3 of the 5 gallon buckets. A few cases of 32 ounce glass bottles (or maybe smaller) and it is still legal to supply customers. Plus the glass bottles are reusable! Fight back against corruption and communism - do not be afraid to dirty up your politicians and use a deep hole to hide em!!! Next you will be moving into your moms basement.
There are different types of hardware that are installed on the guitar and on the guitar strap to make them quick connect. Go into any music shop and tell them you want the hardware for quick connection for guitar straps. They come with instructions that tell you the drill size you will need. Most guitarist will have more than just one or two guitars. Having a quick connect system will be wanted so multiple straps will fit multiple guitars.
AZ, I'm digging the quiver! Chuck & AZ - how bout a couple mor pics from top and back?????
Narrow feed dog FLAT Plate for Cowboy CB4500 and Cobra 4
Doc Reaper replied to Patrick1's topic in Leather Sewing Machines
How do you treat the black oxide???? -
Hello from Portugal - just another newbie...
Doc Reaper replied to stitchgearhead's topic in Member Gallery
Howdy Stitch, a lot of these guys have more knowledge than I ever hope to have. Look at this site as a living encyclopedia for everything leather! If they don't know it they will point you to someone that does -
Leather Sap 8.5" impact device, Slapjacks, sap, blackjack, Paper weight
Doc Reaper replied to Adonis's topic in Show Off!!
Just so all of you are clear, using one in self defense is acceptable if the attacker dies, leave him and play the "catch me - screw me" game Im all for self preservation -
Wild Idea
Doc Reaper replied to Stewart's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I'm wanting to know is that a 3D carving or is this a an actual model made with leather??? -
Slim Jim 51 Navy Holster
Doc Reaper replied to JWheeler331's topic in Gun Holsters, Rifle Slings and Knife Sheathes
That gun probably works as good as a rifle -
Brands
Doc Reaper replied to Frodo's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
The eyes have it -
Does to take a half day to get the barrel free??? -
That's the kind of doll you see in horror movies
Love the work, how did you come up with that design, it's what most would call awesome
I recognize those snaps, Tandy has a habit of buying items that are good for their "bottom line"; where the company saves a penny per 100,000 because the male part on a line 24 is a bastard size and it's a wee bit smaller than normal, more like a line 23 and 9/10ths. The buyer for tandy doesn't use these items, he is there to make sure they don't run out. I'm pretty sure he has zero knowledge of what tolerances are or how a slight hardness in metal affects a tools behavior. Most guys (like myself) would pay that extra 25 cents for better quality other than getting an item that is there just to fill a shelf! FJB. Screw it, today I'm calling Tandy and tell them how they are screwing up and making bad experiences for their consumers, because they hire a guy that is better suited to ask do you want fries with that burger??? Sefullef - it's not your placement of the snap - it's that the snap is not made correctly! I hold paper in industrial engineering and that picture of the snap shows me that the problem is on the male parts design. It should be a bit more bulbous. The spring has nothing to hold onto. Tapping the female edge is just gonna bend the surrounding metal jacket. If the spring was a smidgen smaller or the head of the male part (which I would target) was made a whisper of a smidgen larger - you would have a better quality snap! I'm sure I have covered this before - on the same product - sold by the same company - made by cheap methods - in China! See what y'all went and did, now I'm upset and made me rant past my beauty sleep - which I soooo desperately need!
Hey Rocky, have ya thought about finding a wood worker to help with those molds, maybe even using an epoxy pour?? You have an awesome product, seems there is a more efficient way to produce em
Are Basket-Weave Stampers Negligent!?!
Doc Reaper replied to RVM45's topic in Gun Holsters, Rifle Slings and Knife Sheathes
The "half vasted" method also helps save the material between the holster and the skin from early wear, back in the day good trousers (like today) ain't cheap. Seeing as the normal holster hangs below the belt where the thigh moves back and forth as you walk, the leather is a bit harder and acts as an abrasive that will make quick work of a pair of jeans. Smooth leather is better. Now if the holster is at the belt and there is no friction then it's up to the maker. After a few dozen holsters you learn that full wrap around tooling is good on smaller higher hanging holsters is cool. The lower hanging high friction is meant to be smoother -
Send a picture to show us what you are seeing, you might be looking at vegtan latigo
It might also be a scam
The more up to date use a form of tattooing, some with a type of infrared ink. Those folks understand the cost of leather per square inch. Your Mexican leather has branding marks that are all over the hide, usually done by a sadistic employee that needs termination at the least. I use the branding marks to make saddle bag, travel bags, and other carry alls. Some folks are brainwashed to think leather items should be spotless and that a bug would never bite a cow. Those that brand cattle need less time cooking skin and realize that it's a better brand that doesn't damage the hide and is more comfortable for the cattle. That's where tattooing comes in. In most cases it can't be seen with the naked eye.
Pancake for a Kimber 10mm Rapide
Doc Reaper replied to Hags's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I'd love to see more awesomeness -
Reinforcing: Leather case to carry a motorcycle battery
Doc Reaper replied to Littlef's topic in How Do I Do That?
Saw the canon, well damn!
