toxo
Contributing Member
Everything posted by toxo
  1. Doesn't mean you have to give it to em. Those bags are better than bargain basement.
  2. Just throwing ideas at you. Having stiff sides may negate the need for foam on the front. Maybe VT or some other stiffener glued to the CT gusset on the inside. As for skiving, you need a really sharp blade. Maybe glue on the CT top to harden it before skiving. Maybe glue the foam to the top of the CT before skiving both. Find out what works for you. No one will be as critical as you.
  3. I'm just a hobbyist also but I'm gonna make an effort this year to get back some of the dosh I've laid out. You're doing really well so far and you're right to ask the questions and learn from other peoples experience but only practice and trial and error will get you where you need to be. So. To keep the cost and labour down, you could just try veg tan for the gussets. That will hold up the sides and the flap should stop the sides from coming in. The top of the front panel shouldn't need too much stiffening (maybe none) and so shouldn't be too bulky. I'd mention skiving the top but it's not that easy on soft leather and it's time consuming. I would try 1.8mm/2mm VT, when stitched it's quite strong but you'll have to try it for yourself. You can ask your leather shop for some samples of different thicknesses but spend a little money on decent sized samples that you can sew else they'll send credit card sizes and if you're gonna dye it you can use the economy grades.
  4. Veg tan has lots of advantages over chrome tan. The thickness will depend on the size of the bag but even lightweight VT is a joy to work with compared to CT for many (not all) bag designs. The problem you had in your first post goes away with VT. firstly it doesn't need to be so thick and VT is much easier to skive than CT even by hand after some practice so you can have a turned top edge that's the same thickness as the rest of the panel and so allows a lining to be trapped and sewed between without being too bulky. The stitching when using a gussetwill stand up really well with even thin VT. This first pic was around 2mm, the second pic started life as a soft gym bag at around 1.2mm CT but I realised that the size of the bag needed more so I lined it with 1.6mm VT and now it's more like a stylish suitcase. You have to try these things
  5. I've read a few posts about folk struggling with sewing and a thought came to me, (didn't hurt that much). Like a lot of people I've done a few patterns that use holes instead of slits for sewing. I don't want to get into the purity of it. I just want to point out to some that may not have tried it that it's much easier to get two needles through a 1.5mm hole than a tight slit. It's quite tedious to get all the holes done with a single punch. There are multi punches of course but getting the right spacing as per the pattern may not be that easy although the spacing can be adjusted at the end in the same way as you would with a stitching chisel. Even with such a tool it's still a chore for arthritic hands. Then I thought, what if there was a hole instead of a needle in the sewing machine? That could be a game changer for dodgy hands. Then I happened to be watching the maestro Cechaflo sewing a steering wheel and guess what he used for the stitching? If you don't want to watch the whole thing, get to 1.04 but it's only there for a second so look sharp. Now I'm thinking how do I fettle something like this for my Adler.
  6. Nice work and I like the design although the open holes at the sides always make me determined to do something about that next time. Have you considered veg tan for the gusset? I see your gusset goes all the way around. A veg tan gusset would hold it up and enable a thinner front and back panel which would enable you to trap the lining between the turnover without it being bulky. Can't see the clasp well but does it just hold the flap down? If it does you might consider one that locks it in place which would help in it standing up.
  7. What is it that you're making that needs such a thickness of material? And is the lining designed to come out or not? I assume you want the stiffness so it stands up? Are you trying to not sew through the turnover at the top?
  8. Just wash it with a mild soap. The water won't hurt it, people wet mould all the time.
  9. Not a definitive answer but the best part of a hide (and usually the thickest) is the top part of a side. it can also be the longest if you're making belts. It's also the most scar free part of a hide because the shoulders and rump get itched a lot, sometimes on sharp stuff like barbed wire.The lower part of a shoulder and the belly can be thinner and stretchier. Someone will correct me if I've got anything wrong and no doubt come up with more answers.
  10. Thanks chuck. I finished up at the head, saddle stitching the sides to the underbelly and I use long needles.
  11. There's some very tricky sewing in this. I had some fake croc left over.
  12. I did that one Fred. It's a bit discoloured now. Might have to dye it.
  13. Thanks guys nearly finished the pencil case, will post pics later. Chuck, I like your thinking but I want to make him something that he'll use for a few years. Maybe I'll end up just lasering some Dino images on a veg tan flap.
  14. On the same YouTube page there are others that might suit you better Bert.
  15. My 3 yr old Grandson is going to start his first uniform school soon and I've promised to make him a dinosaur backpack but struggling to find the right pattern. I could just laser an image on the flap but I'm looking for something with a bit more to it. In the meantime I've started this pencil case. Finally got it cut/punched out. Will start building tomorrow. He's Dino mad and knows a lot of the names already.
  16. Thanks Sheila, no just rivets. The pattern comes with a cat face and a couple of others also.
  17. This might help Bert. https://www.youtube.com/watch?v=taQAM4i33OI
  18. I got a commission yesterday for my Owl Bag. Never sold one before so had to come up with a price. We'd had a bit of a conversation where I told her I was getting away from bags in favour of smaller items because some of my bags sell elsewhere for £300/£400 but as a non brand I couldn't get anywhere near that. Then she saw the Owl and asked the question. With no clue (It's been a year since I made it.) I spun it back to her and asked what she'd pay for it. She said £150. Now this woman has so many ailments the poor woman took 5 mins to to tell me what they were. Then she said she wanted it lined with an internal zipped pocket so we agreed on £200. Now the good guy in me wanted to give it to her for cheap but the devil sitting on my shoulder told me that she's getting disability benefits and somehow I'd like to get back some of the money I've laid out for the skiver and the two sewing machines etc. I have the leather for it so it's just time really. What are the hives thoughts?
  19. Good practical project. Well done. I do wonder if it really was for him or for you.
  20. I can only think there's too much pressure. Have you got the tension on the feed roller too tight? Have you tried slackening off the top knob and then, with the lever down turn the top knob until it starts skiving?
  21. It's not as easy as it looks. Good job. I've only done it once on the end of a rifle butt cover.
  22. Dieselpunk.Ro's patterns are digital downloads and so instant and can be printed and used again and again. They also come with a video tutorial. Some are free. He also sells the hardware packs for some patterns. https://www.leather-patterns.com/ https://www.etsy.com/uk/search?q=dieselpunk.ro
  23. toxo
    Skivers
    Great news (for me)! A bit of judicious force with a screwdriver, a faint crack and the two pulley clusters came unstuck. Everything is now working as it should.
  24. toxo
    Skivers
    I think I've got it. The pulley train IS in two parts (see the pic) and the clutch can only move part of the train backwards but my train seems to be one solid unit so can't move back. So much pressure has been applied to the clutch shaft causing it to deform. I can only assume (hope) the bolts numbered S141 need adjusting to bring things back to normal by letting the two stone pulleys to come forward and thus be free of the drive.
  25. toxo
    Skivers
    I'm gobsmacked. The most important pics for my question and I didn't post em. I still don't know how the clutch lever engages/disengages the stone. The only way I can see is if the pulley cluster is in two separate sets and the sideways movement of the lever separates or brings the two sets together but my pulley train is as one and I can't separate any of it so how does the damn thing work??? I have no idea if there's anything missing from the shaft but in the interim I drilled out that sheared pin and replaced it with a round headed set screw to no avail. On the vacuum side I experimented with the position of the scoop and ended up putting it where yours is. The good thing is I managed to fine tune the chain switch so initially the vac doesn't come on but there's enough speed to sharpen the knife. If I want to skive a little more pressure on the treadle starts the vac. Apart from the clutch thing it's all good.
